Question about the F-22 and it's radar.
Old April 2nd 04, 06:54 PM
Harry Andreas
In article , John Cook
Just the official reports!!, Lockheed has only purchased enough
processors for 155 F-22's because there out of production, the demand
for Air to ground operations has increased the demand on processing
power, something the original processors are not quite upto hence the
_need_ for the 'upgrade'.
So the processors are obsolete, (too old)... the Avionic architecture
needs to be replaced before the F-22 can become the F/A-22 because the
present system is based on the old processors and rewriting the code
is pointless on an obsolete system, that would only support half of
the F-22 fleet
Methinks there's some confusion there between processors, avionics
architecture, and software.
While it's true that Intel tried to shut down i960 production causing a
chinese fire drill, there are enough assets to get by until a new processor is
ready. That has nothing to do with the avionics architecture, which is
not changing. Plus the whole point of writing all the OS and AS in Ada was
to be as platform independent as possible, so that upgrades to the CIP
could be relatively painless and not force re-flight testing of the A/C.
Ideally, one would not re-write the code, but re-compile the code for
the new platform, then do a LOT of integrity checks, and take it from there...
They have to go with a more COTS based system (similar to, if not the
same as the JSF), which they are working on now, for fielding in (very
optomisticlly) in 2007.
Other than using commercialy available processor chips, what is "COTS"
about it?
Hint - nothing.
Other facts (what a concept in RAM)
The F-22 is also based on commercialy available processor chips (but
not a commercial architecture)
Avionics systems require a much higher level of security and determinism
than any "COTS" package will ever offer.
COTS is not necessarily cheaper when talking avionics
COTS is one of those words that everyone thinks they understand, until
it comes down to brass tacks.
A simple analogy for you, the old 486 computer still works, but when I
wanted to run XP on it the demands of the system increased to the
point where it was useless to try, and you couldn't buy a 486
processor anywhere to support it.
I call that an 'obsolete system', it worked great running win 98.
Your analogy is seriously flawed for several reasons:
A processor does not stand alone, it's part of a system, and many,
many other things affect the system performance besides processor
speed. Backside bus bandwidth, memory architecture, frontside bus
bandwidth, etc.
Plus the system in this case contains MANY processors in parallel.
The system is officially termed a heterogeneous multi-processing system
which means that it has several different kinds of processors as well
as the i960, and all running in parallel. I think someone calculated
the actual processing resources are equal to 2 Cray Y-MP supercomputers.
Software also matters. Comparing avionics software to microS's
bloatware is ludicrous.
Now the Raptor can't run the software to do its air to ground mission
for the same reasons what would you call it?. "processor
challenged???"
I'd say, take a hard look at the above assertation and explain how it
can be true, given that other AESA radars, in service, and with smaller
avionics processors, don't seem to be having these problems.
BTW, I worked on AFT, F-22, and several other current AESA programs,
including airborne processors, and integrated avionics systems.
Harry Andreas
Engineering raconteur
Old April 2nd 04, 11:36 PM
Tarver Engineering
"Harry Andreas" wrote in message
the F-22 fleet
processor is
ready.
Intel has agreed to provide mil-spec i960s, thanks to a very fat check from
USAF. The new processor has already failed to be integrated, due to a loss
of tracability. (ie scrap)
was
there...
about it?
Hint - nothing.
Wrong. Name for us the one and only modern processor that is mil-spec,
Harry.
Old April 3rd 04, 12:25 AM
Scott Ferrin
On Fri, 2 Apr 2004 14:36:49 -0800, "Tarver Engineering"
the F-22 fleet
processor is
ready.
was
there...
about it?
Hint - nothing.
Harry.
I don't know if it's milspec but ISTR reading that Intel donated the
Pentium 1 design to the US military to do with as it pleased. I also
remember reading an article on some Russian naval electronics in which
the advertiser was boasting that they were "Pentium" powered.
Old April 3rd 04, 05:23 AM
Paul F Austin
the F-22 fleet
processor is
ready.
from
loss
was
A/C.
there...
(very
about it?
Hint - nothing.
Harry.
Intel did donate the rights to Pentium 1 to the USG and Sandia has been
working on producing a rad-hard flavor but it seems to have been overtaken
by events.
In general, MIPS and PowerPC processors are favored over Intel parts because
of power vs performance metrics. Intel parts deliver lots of performance but
put a heavy burden on the designers trying to get the heat out.
The main issues in using commercial parts in military applications are 1.
Quality level, 2. Operating temperature range and 3. Packaging.
As far as quality level is concerned, there are several MIPS and PowerPC
CPUs available screened to -883B and also to class S (space grade). Both IBM
and Moto PPC603Es and -750s of various flavors are available screened to MIL
standards. You have to buy upscreened parts (by second parties) but that's
the way it's done. Aeroflex sells a 600MIP MIPS processor that's also
available compliant with MIL standards. .A secondary problem is support
chips. That's most often done with IP hosted on FPGAs.
As for temperature, all the high performance CPUs operate over a restricted
temperature range smaller than the mil -55 to 125C. Instead, you have to
work within industrial temp range (-40 to 105C) but that just makes life
hard for the thermal designers.
Packaging can be tough. There are a few sources for hermetic, flat-pack high
performance CPUs (Aeroflex is one). Mostly though, we've had to learn to use
ball grid array parts, some of which are ceramic and others plastic.
Depending on the application, the plastic ones are used as is or repackaged
(which is expensive and risky). Either way, BGAs present major challenges in
avionics applications because of temperature cycling induced ball failures.
Each vendor is working to develop processes that will survive but right now,
it's a black art.
Old April 3rd 04, 06:43 AM
Tarver Engineering
"Paul F Austin" wrote in message
because
but
Intel went out of the Mil-Spec processor business and Motorola kept making
them. The Mil-Spec components specifications were abandoned in place in
2000 and Intel had no incintive to continue to support a fantasy world.
AKA the Rome data, as based on the RPL Model. RL has a pretty nice software
reliabilty model as well, but of course the F-22 was to early for COTS. I
am optimistic about the F-35, with it's injection of the RPL model.
Old April 7th 04, 04:53 PM
Tarver Engineering
"Scott Ferrin" wrote in message
It is all gone Scott and I think Harry expressed the frustration of trying
to build a super fighter without access to parts. The mil-spc componencts
market completely collapsed coincident with the engineers trying to build
this electric airplane. You can't really blame them for the way things
turned out, as somone high up decided to ride mil-spec to the end. (ie FY00)
Old April 6th 04, 06:51 PM
Harry Andreas
In article , "Tarver Engineering"
the F-22 fleet
processor is
ready.
was
there...
about it?
Hint - nothing.
Harry.
You have my comment exactly backwards.
I claim that JSF is NOT more COTS that F-22 because F-22 is using commercial
parts, too. And that JSF is taking commercial parts and building a full
mil-spec system, the end item being non-COTS, although made from
COTS parts.
The usual process since the early 90's.
Harry Andreas
Old April 6th 04, 07:05 PM
Tarver Engineering
demand
architecture
the F-22 fleet
a
processor is
ready.
from
loss
Ada was
A/C.
there...
(very
about it?
Hint - nothing.
Harry.
commercial
parts, too.
Steidel was at F-35 after his successful engagement at F/A-18E. COTS is a
disaster waiting to happen without the constraints of the RPL Model. The
first thing Lockheed did when they got Power PC processors in was lose
tracability. They do not even have the dicipline to control Mil-Spec parts,
how can anyone expect them to understand the new reality?
COTS parts.
The RPL Model is all there is, incarnations available from Federal Electric
Corporation, Rome Labs and SAE's as AS9100 large shop adaptation. (see new
CFR14 Part 145)
You are way behind the power curve Harry. Have a look at the fleet numbers
for reliabilty for the F/A-18E vs the F-14s. Think about how the F-22's
target number compares.
Old April 6th 04, 10:39 PM
Harry Andreas
Ummm, let me check....yep, one of my radars is on the F/A-18E/F, and it
uses COTS parts. Oh, and the new AESA radar is on the F/A-18E/F, and it
uses COTS parts, too.
Digging a little deeper; yep, I worked on the F-14D's APG-71 and that
one uses Mil-spec parts.
And, of course, I worked on ATF and F-22 back in the day.
And JSF currently.
You're trying to teach me what exactly?
Been there, done that, doing it presently, with COTS and high reliability.
BTW, the current system I'm working has a reliability number higher
than the airframe life.
Harry Andreas
Old April 6th 04, 11:06 PM
Tarver Engineering
numbers
snip of non-sequiturs
Even if the F-22 were to hit it's target it would remain inferior.
COTS in a vacuum is a disaster waiting to happen. Do you mean that your
application of my RPL model is driving your COTS application, as it is
everywhere outside USAF and even with the F-35, or do you mean you are just
making the numbers up? The sample of Mil-Hbk 217F is dependant on certain
procedures and processes, as are all of the related datum.
