Question about the F-22 and it's radar.
Old April 3rd 04, 11:54 AM
John Cook
There is where you go wrong--accepting the GAO report at face value. Don't
you know they have a well known reputation for shading things in the
direction they want, or just plain ol' incompetency in some cases? What they
are describing is the spiral development program that the USAF has already
articulated--nothing new about it, and nothing shocking.
OK don't like the GAO? ..... fine! How about Lockheed or the
USAF who have a IPT team to find the obsolete items, and find Form Fit
and Function replacements using 'commercial products' where they can
(Note the COTS reference).
General Musala lamented in 1998 that non of the 339 F-22 will be
built the same because at least 500 parts are already obsolete!!!
(As quoted in 1998!! use your imagination in regard to that number
today, Oh thats right! in your world its probabley been dealt with
already and only minor issues remain like coffee cup holders etc. )
Let's see, 155 out of a possible total buy of some 269 aircraft, or a
more
likely buy of 200-220, would seem to indicate that the first few *years*
of
production are covered. Nor has it been conclusively demonstrated that
these
processors are incapable of handling the aircraft's air-to-ground strike
needs during it's initial gestation; more in the form of not being able
to
handle the *ultimate* (post spiral) capability that is envisioned.
Conclusivly demonstrated!!!!, it can't demonstrate stability yet
Uhmm..you missed the USAF statement that it can indeed carry and deliver
JDAM's? What, you think JDAM is some kind of air-to-air weapon?! And that is
with the current processors--I believe Harry Andreas has already addressed
that particular issue much better than I can...and oddly, you don't seem to
have replied to his comments...
Its all very well that it can drop a couple of JDAMs around a target
area, but it does need to have a running system to perform this
rudimentary function, something which is not happening at present.
You are sytil avoiding the question of how you rate the F-22
development? well whats it to be..... paragon of industrial/military
cooperation or balls up......
how would you describe it....?
The Glabal Strike Ehanced program is slated to start in 2011, thats
when the Raptors system architecture is officially obsolete,
Uh, what?! "Officially obsolete"? And where do you come up with *that*
little factoid? never heard of any US program going forward with an already
"officially" established date of obsolescence...
The current processors can't handle the workload, they need to be
replaced before the F/A-22 can do the job, from the data supplied by
the USAF they expect it to be able to 'do the Job' from 2011.
what would you call a system that can't do the job, come on its an
easy question!!
I quote again the GAO-04-597T report directly
You just never learn, do you? GAO does not equal either competence or
accuracy in terms of military developments, organizations, etc.
At least there getting their figures from the team thats testing the
F-22, where are you getting your figures from?.
What figures are you putting into this debate, whats your assesment of
MTBAA??, Go on I'm interested.
"The stability and performance of F/A-22 avionics has been a major
problem causing delays in the completion of developmental testing and
the start of IOT&E. Because the F/A-22 avionics encountered frequent
shutdowns over the last few years, many test flights were delayed. As
a result, the Air Force Operational Test and Evaluation Center wanted
assurances that the avionics would work before it was willing to start
the IOT&E program. It established a requirement for a 20-hour
performance metric that was to be demonstrated before IOT&E would
begin. This metric was subsequently changed to a 5-hour metric that
included additional types of failures, and it became the Defense
Acquisition Board's criterion to start IOT&E. In turn, Congress
included the new metric, known as Mean Time Between Avionics Anomaly
or MTBAA, in the National Defense Authorization Act for Fiscal Year
2004.5 As of January 2004, the Air Force had not been able to
demonstrate that the avionics could meet either of these criteria.
Testing as of January 2004 showed the program had achieved 2.7 hours-
54 percent of the 5-hour stability requirement to begin IOT&E. While
the Air Force has not been able to meet the new criteria, major
failures, resulting in a complete shutdown of the avionics system,
have significantly diminished. These failures are occurring only about
once every 25 hours on average. This is the result of a substantial
effort on the part of the Air Force and the contractor to identify and
fix problems that led to the instability in the F/A-22 avionics
software. However, less serious failures are still occurring
frequently."
snip
claims that at present, "The F/A-22 also has an inherent air-to-surface
capability." It can already lug a couple of JDAM's. So how does that even
*require* an optimized ground mapping radar to allow it to strike ground
targets with significant precision?
Dropping a couple of JDAMS whohooooo!!!,
Cutting edge that... well worth the money of investing in a system
thats equivelent of a couple of cray supercomputers.
All of that computing power helps it get to the target area so it can drop
those "whohooo" JDAM's. And last i heard the JDAM was judged a particularly
accurate and lethal munition. Now, I do believe you were crowing that the
F/A-22 is incapable of performing the ground attack mission? How do you like
your crow, rare or well done?
Listen Matey don't put words in my mouth, the F-22 can drop JDAM's, it
can also strafe the ground with its cannon, But a ground attack
aircraft it ain't, and won't be until an upgrade to the avionics
occurs.
My point is the super duper cray like performance that has be repeated
touted can't hack a AtoG mission, don't you see anything wrong with
this??? why 11.7 billion what that for then? if everythings fine and
dandy why would you want to spend 11.7 billion on a perfectly capable
AtoG aircraft.
one wonders what there using that processing power for?. must be a
very nice graphical interface....
what the USAF have stated they want is, but cant have because of the
limitations of the system are :-
2011
Improved radar
capabilities to seek and destroy advanced surface-to-air missile
systems and integrate additional air-to-ground
weapons.
2013
Increased capability to suppress or
destroy the full range of air defenses and improve speed and
accuracy of targeting.
2015
Capability for full intelligence, surveillance, and reconnaissance
integration for increased target sets and lethality.
Gee, can't have any of that, huh? And why not?
Because it would cost 11.7 billion to get it, If they pay they get it.
(or at least some of it, I'm not that confident of their cost
projections. Are you?.)
I don't hate it, I just think its not worth the money, if it had been
half the price and worked as advertised I would be impressed.
As it is the price is $150M and development is not mature, production
has started, How would you describe the F-22 process?.
LOL! By your definition, no aircraft would ever enter service, as
"development is not mature". I guess you have kind of missed out on the
*continuing* development of the F-15, F-16, and F/A-18, huh? I'd describe
it
as about par for the course, especially when viewed against
contemporaries
like the Typhoon and Raptor,
Difference is they have demonstrated their requirements and have been
accepted, now they are in production.
Have they now? rafale was in production while its ground attack capability
was in the pure ghostware stage--which is why the French Navy went to sea
with them being capable *only* of performing air-to-air missions. The RAF
wants to retune the Typhoon to perform in the multi-role strike manner
before they had originally planned--meaing that their aircraft were not
optimized for that mission when Typhoon went into production. Sounds a bit
like the F/A-22, doesn't it?
Planned being the operative word here, they planned to have an Ato G
capability for a number of years, they developed the systems as per
that plan, and produced them.
The fact that they can pull forward the requirements to an earlier
date seems to prove the systems are capable of doing the job,
Actually _Doing_the_Job_ and not - 'give us 11.7 billion and we will
see what we can do'..
I'll ask you again How would you describe they F-22 process??
Like most current advanced aircraft projects--that you still can't see that
is hardly surprising, given your obvious bias and reliance upon the *GAO* as
your primary source.
If 10 is a perfect development program, and 1 is an utter fiasco that
results in over priced, marginalised product thats ripe to be
cancelled, whats the Raptors score?
Your evading the question!!!, whats its score?.
Yes, it is amazing--you, Cobb, and Tarver are the only ones gifted enough to
realize what a true dog it is, huh? All of those blue-suited folks being too
darned dumb to figure it out, right?
Some of those blue suited folks are questioning its utility, stop
trying to evade the real question by comparing my opinion to others,
Is the F-22 program value for money? and if you think it is (why
bother to ask I thinks to myself) at what point in your mind does it
become too expensive to field?. dollar values are fine by me!.
Again, thank goodness you are not in the decisionmaking chain.
From your view point I can see why you said that, but that doesnt mean
your view point is correct.
The F-22 program is in trouble, the system is very very expensive,
the system has been so long in development that the ambitious system
it pioneered have become obsolete, the program needs addition funds
and also input from the JSF program to make it more reliable and
update its avionics.
I could equally say the Nimrod AEW project would have been the best in
the world if only the Software would run and the equipment had of
worked, But then again I know that having the software run and the
equipment work is the 'project'.......
Cheers
John Cook
Any spelling mistakes/grammatic errors are there purely to annoy. All
opinions are mine, not TAFE's however much they beg me for them.
Email Address :-
Spam trap - please remove (trousers) to email me
Eurofighter Website :-
http://www.eurofighter-typhoon.co.uk
  #32
Old April 3rd 04, 03:38 PM
Frijoles
Kevin,
Ye doth protesteth too much...
F-22 is not a 'dog.' But its clear that absent SIGNIFICANT upgrades to its
avionics suite it will have nowhere near the AG capability of the F35.
That's why the USAF is spending the money, and for their efforts, they
should get a nice capability to go with the signature, speed and other
attributes possesed by the airframe.
Remember, that's a capital 'B' behind that $ sign. These are not trivial
amounts. You remember that line -- a billion here, a billion there, before
you know it we're talking real money...
"Kevin Brooks" wrote in message
"John Cook" wrote in message
snip
You might be right, it may go into service, and if reports are to be
beleived - despite the cost, despite the reliability problems, despite
the obsolete architecture, the only credable justification is avoiding
an embarrising procurement fiasco, 200 odd hanger queens.....
astounding...
enough
to
too
Oops--spoke too soon; looks like you can add Denyav to your rabidly
anti-F/A-22 cohort! My, what a fine, reputable group you have there... :-)
Brooks
Brooks
Cheers
John Cook
Email Address :-
  #33
Old April 3rd 04, 03:58 PM
Tarver Engineering
Don't
they
already
COTS is no longer optional, as it is the only game in town. Any reference
to mil-spec components is a reference to an obsolete basis.
  #34
Old April 3rd 04, 04:59 PM
Kevin Brooks
"Frijoles" wrote in message
ink.net...
Kevin,
its
Actually, any protestations "too much" are due to trying to correct the
ridiculous assertion that it has *no* air to ground capability as is. I
understand fully that the optimization of that capability requires
money--which is why there is a spiral development plan in place. Recently in
this NG we have seen folks try to claim the $11 billion estimate was solely
directed at turning the F/A-22 into a strike platform; not the case, as it
also includes air-to-air upgrades, ISR upgrade, etc. IMO, the F/A-22 does
indeed have its share of problems, chief among them being the change in the
nature of the threat it was originally intended to counter; I went on record
supporting a 180 aircraft buy before that number even became fashionable in
the DoD rumor mill. Currently I'd support a 200-220 number. Nobody has (with
any factual basis) accused me of being a rabid supporter of the program--but
I don't think there is any point in making up negative points about it
either, which is largely what we have been seeing of late.
Brooks
snip
  #35
Old April 3rd 04, 05:16 PM
Henry J Cobb
So let's make lemonade here.
Give the F/A-22 as close to the same sensors, computers and software as
the F-35 as possible so that not only is the JSF kickstarted but also
the F/A-22 will have an upgrade path in the future as improvements are
made to the JSF.
-HJC
  #36
Old April 3rd 04, 05:36 PM
Kevin Brooks
Don't
they
already
No, in my world the folks that are managing this program, and who are
confronting the very real challenges inherent to developing and fielding the
most advanced fighter aircraft in the world, are more capable of handling
these developmental issues than some amateur rotten tomato tosser who has
amply demonstrated that despite his attempts to sound as if he has a real
grasp on the issues, doesn't. You earlier posted a long-winded diatribe
including "calculations" which were purported to support the claim that the
F/A-22 has insufficient range/endurance capabilities to perform its
originally intended air-to-air role; when a gent with an obvious real
understanding (i.e., a design engineer) of issue countered your argument,
IIRC you ignored his trashing of your faulty assumptions and merely shifted
your anti-F/A-22 rant into a new direction. You obviously are a rather
intelligent fellow, and your arguments would be taken with a bit more
seriousness if you had not established such a firm record of trying to
oppose the program on each and every level, in regard to every issue; as is,
it just sounds like more shrill, "I don't like it, no how, no way" ranting.
more
*years*
of
these
strike
able
to
is
addressed
to
"Drop a couple of JDAM's around a target area"? LOL! The JDAM's record for
accuracy/precision has been rather well proven--mate it to the survivability
capabilities inherent to the F/A-22 and you have a system that can go deep
early and take out critical targets with great precision. Hardly a
"rudimentary" capability. You see, this is what i mean; first you said it
has NO ground attack capability, and when corrected, instead of just saying,
"Oops, yeah, it does indeed have a precision deep strike capability in its
present form", you instead head off on this ridiculous, "Being able to stike
a target with a JDAM does not really mean anything" crap--thus destroying
any credibility you may have had in terms of offering an unbiased critique
of the system.
already
easy question!!
Show me where the USAF has said, the F/A-22 "can't do the job" in terms of
either air-to-air or precision deep strike with internally carried JDAM's.
And they then twisted them--read your own GAO report; their commentary
seemed to indicate that the $11 billion was required in order to give the
F/A-22 a strike capability, but the actual explanation of the breakdown of
that $11 billion made it plain that it was instead the total estimated cost
for the program's spiral development. It ignored the fact that the existing
F/A-22 coupled with JDAM (and later with SDB) is indeed capable of
performing the strike mission.
Talk that over with Harry--he actually knows what he is talking about,
instead of spouting off acronyms he has recently read about. Oh, that's
right...you have not addressed Harry's comments about your claims, have you?
frequently."
snip
air-to-surface
even
ground
drop
particularly
like
occurs.
Listen up yourself, "Matey" (who the hell are you, Popeye?); you said quite
clearly that it is incapable of performing the ground attack mission, and
the fact that it can indeed deliver JDAM, in a stealthy manner to boot, and
the inherent accuracy of that munition, lays that particular claim of your's
to rest. Now what you *may* have meant was that the initial gestation of the
F/A-22 won't be able to handle independent retargeting while in-flight due
to its radar not being optimized for the terrain mapping role--but that is
not what you said, nor does that equate to not being able to conduct the
ground attack mission, period.
AtoG aircraft.
The $11.7 billion is for spiral development; it includes upgrades to both
the air-to-air capability and the ISR capability as well. Reading
comprehension problem?
2011
Improved radar
weapons.
2013
2015
I am quite confident that we will continue to provide spiral development
funds to support F/A-22 during its lifetime; how many billions have we
dedicated in the past to further development of the F-15, F-16, and F/A-18
(heck, in the latter case we even developed the Super Bug...)?
been
production
describe
it
contemporaries
capability
bit
Uhmmm... you think those programs did not require additional R&D funding,
and won't require additional future R&D fundiing, to bring them to actual
fruition? Take a gander at that whole Nimrod R&D program and its costs...
that
as
Only you want to play this ridiculous "give it a score!" game. You want a
score? OK. The USAF is fielding the most advanced and capable fighter
aircraft in the world--how do you score that?
to
too
I have seen only one former blue-suiter come out against the F/A-22--and his
record is a bit spotty, as he seems to have a certain well-demonstrated bias
towards "lightweights only". Name of Ricconi, IIRC.
That would be the same JSF program that you have also attacked? It appears
there is only one advanced fighter program that truly meets your approval,
and that is Typhoon...
Brooks
Cheers
John Cook
Email Address :-
  #37
Old April 3rd 04, 05:43 PM
Kevin Brooks
"Henry J Cobb" wrote in message
Recently in
solely
it
does
record
in
(with
program--but
made to the JSF.
Yah, and just restart the development prgram for the F/A-22 all over again
while you are at it, too, huh? I don't think so.
Brooks
-HJC
  #38
Old April 3rd 04, 06:33 PM
Paul F Austin
I
Recently in
solely
as
it
does
in
record
fashionable
in
(with
program--but
made to the JSF.
Although F-35 hardware may be rolled into F-22 production as a block change
later. F-35 benefits from F-22 development and vice versa.
  #39
Old April 3rd 04, 06:53 PM
Tarver Engineering
"Paul F Austin" wrote in message
is.
I
Recently in
solely
as
it
does
in
on
record
fashionable
in
has
(with
program--but
it
as
made to the JSF.
again
change
God bless BAE Systems.
  #40
Old April 3rd 04, 11:09 PM
John Cook
So the processors are obsolete, (too old)... the Avionic architecture
needs to be replaced before the F-22 can become the F/A-22 because the
present system is based on the old processors and rewriting the code
is pointless on an obsolete system, that would only support half of
the F-22 fleet
Methinks there's some confusion there between processors, avionics
architecture, and software.
While it's true that Intel tried to shut down i960 production causing a
chinese fire drill, there are enough assets to get by until a new processor is
ready. That has nothing to do with the avionics architecture, which is
not changing. Plus the whole point of writing all the OS and AS in Ada was
to be as platform independent as possible, so that upgrades to the CIP
could be relatively painless and not force re-flight testing of the A/C.
Ideally, one would not re-write the code, but re-compile the code for
the new platform, then do a LOT of integrity checks, and take it from there...
The question is does this 'new' processor conform to the 3 F's, Form
Fit and Function?, If not then the processor demands a new
architecture to support it, with the new architecture comes the the
burden of porting it over, couple that with the reliability problems
now being experienced and you have a flakey system thats being ported.
AFAIK there is no 3F for the i960, therefor the system has quite
neatly side stepped the reletivly painless CIP upgrade path.
The F-22 is under enormous pressure to perform right now, with the
review reporting back in the next few months, any talk of obsolete
systems in the state of the art jet are being downplayed.
They have to go with a more COTS based system (similar to, if not the
same as the JSF), which they are working on now, for fielding in (very
optomisticlly) in 2007.
Other than using commercialy available processor chips, what is "COTS"
about it?
Hint - nothing.
Other than the Raptors costs its the cheapest fighter in the world...
seriously the F-22 team will be levering the development work on the
JSF for all its worth, anything to shove costs away from the f-22
program.
What is the new processor? I always thought that a federated system
had certain advantages with regard to upgradeing.
Other facts (what a concept in RAM)
The F-22 is also based on commercialy available processor chips (but
not a commercial architecture)
Avionics systems require a much higher level of security and determinism
than any "COTS" package will ever offer.
COTS is not necessarily cheaper when talking avionics
COTS is one of those words that everyone thinks they understand, until
it comes down to brass tacks.
A simple analogy for you, the old 486 computer still works, but when I
wanted to run XP on it the demands of the system increased to the
point where it was useless to try, and you couldn't buy a 486
processor anywhere to support it.
I call that an 'obsolete system', it worked great running win 98.
Your analogy is seriously flawed for several reasons:
A processor does not stand alone, it's part of a system, and many,
many other things affect the system performance besides processor
speed. Backside bus bandwidth, memory architecture, frontside bus
bandwidth, etc.
Plus the system in this case contains MANY processors in parallel.
The system is officially termed a heterogeneous multi-processing system
which means that it has several different kinds of processors as well
as the i960, and all running in parallel. I think someone calculated
the actual processing resources are equal to 2 Cray Y-MP supercomputers.
Software also matters. Comparing avionics software to microS's
bloatware is ludicrous.
It was a simple analogy, not designed to compare avionics and M$ code,
but to show why an upgrade is required, if it can't hack the
requirements it needs upgrading, its that simple, If it can hack it,
no upgrade is required - simple as that.
Now the Raptor can't run the software to do its air to ground mission
for the same reasons what would you call it?. "processor
challenged???"
I'd say, take a hard look at the above assertation and explain how it
can be true, given that other AESA radars, in service, and with smaller
avionics processors, don't seem to be having these problems.
Take it up with the USAF, their requirements call for a certain level
of capability in the AtoG role, the F-22 currently does not have the
software or the hardware to fullfill that capability - hence the need
for upgrades, what other reason is there for an upgrade...?.
BTW, I worked on AFT, F-22, and several other current AESA programs,
including airborne processors, and integrated avionics systems.
Great, here' s a couple of questions for you.
Do you think they will combine the AESA antennas for the JSF and the
F-22 to a common 1200 module system? (I saw the number of modules for
the F-22 was at 1500). I had heard a rumour that this was on the
cards for cost savings etc.
Why is the Raptors Software so troubled?.
Cheers
John Cook
Email Address :-
