Don't you just hate it when the propeller departs the aircraft?
Old December 18th 13, 04:54 PM posted to rec.aviation.soaring
Dave Nadler
Default Don't you just hate it when the propeller departs the aircraft?
A prospect was checking out the nifty Antares 18T
sustainer system somewhere over the forest west of ZWB,
when to his great surprise, the propeller departed.
Hell of a way to impress a prospect.
The problem is with the Solo propeller shaft with the
belt reduction system as used on, IIRC:
- Ventus CM (not V2)
- Duo T
- DG-100T
- Antares 18T
Apparently there have also been recent incidents with DG1000T.
The propeller is not identical on all the above so the
failure rates will differ.
Axel Lange has worked with Solo to redesign the offending
part and is working on EASA approvals. IIRC this will be
the 3rd or 4th AD on this part, but Axel can calculate why
it failed and also how to make a part that won't...
I don't know if there's been any communication from SH
or who else uses this particular (front belt-reduction)
Solo system.
I see DG has published some info he
http://www.dg-flugzeugbau.de/index.p...1349&tx_ttnews[tt_news]=147&cHash=cd1730aca0037e72c7b2911e83136b2e
Another reminder to always operate your motor with a
plan for failure at any point...
Aaarrrggggg....
Be safe out there,
See ya, Dave "YO electric"
Old December 18th 13, 06:14 PM posted to rec.aviation.soaring
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
I think the Duo T uses the Solo 2350D engine/prop shaft whereas the others use the Solo 2350C.
http://aircraft.solo-online.com/
John Galloway
Old December 18th 13, 07:17 PM posted to rec.aviation.soaring
Dave Nadler
John Galloway
The issue is the prop shaft (supporting the reduction
pulley and prop hub), not the motor itself.
While the Duo uses a different assembly and prop hub,
I thought the prop shaft was the same part, but I
am not sure... Also the Duo T's banana-prop may
produce lower fatigue-loads than a two-blader,
again I'm not sure... Anybody have any info from SH?
Be careful out there,
Best Regards, Dave
Old December 19th 13, 03:33 AM posted to rec.aviation.soaring
Morgans[_2_]
"Dave Nadler" wrote in message
- Duo T
- DG-100T
I'll bet any money the problem will turn out to be torsional harmonics.
Remember the problem with the BD-5? Some excellent research was developed
out of the problems of using a 2 cycle engine in that aircraft.
Seems I remember that one fix involved a sprag clutch (one was slipping) to
get over the torque reversal at some rpms.
Jim in NC
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
Old December 19th 13, 05:41 AM posted to rec.aviation.soaring
darrylr
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Did he buy the glider? :-)
Old December 19th 13, 06:36 AM posted to rec.aviation.soaring
Frank Whiteley
- Duo T
- DG-100T
Jim in NC
Russia AC-5m's have had some prop departures due to broken shafts. I believe one resulted in a fatal at North Las Vegas about two years ago. Inspections have uncovered cracks in others. IIRC, there was a fix worked.
Frank Whiteley
Old December 19th 13, 11:51 AM posted to rec.aviation.soaring
Dave Nadler
This is way over-simplified, but useful to think about.
And I am absolutely not expert in this area! But...
You can think of the assembly as a set of springs:
- the drive belt
- the structure between the engine and prop hub
- the prop itself
When the engine fires, it:
- stretches the drive belt on one side, loosens on the other
- flexes the support structure
- bends the prop (in both torsion and load directions)
These produce fatigue loads on all components involved.
All of which have conspired to produce numerous failures
in many different makes and models over the years,
on all of the affected parts.
Hope that helps!
Be careful out there, and ALWAYS have a plan for a failure
at all points during motor operation,
Best Regards, Dave "YO electric"
Old December 19th 13, 12:15 PM posted to rec.aviation.soaring
Muttley
I would say a further point on the SH Turbos is that they are only started by Windmilling and do not have a Starter Motor, therefore maybe less stress with slower Windmill starts on the Belts and prop shafts!!!!
A SH Turbo Driver
Old December 19th 13, 12:31 PM posted to rec.aviation.soaring
Dave Nadler
A SH Turbo Driver
Um, no, the start mechanism has no affect on fatigue problems.
However, do review the TNs and/or ADs on the support structure
in your installation...
Old December 19th 13, 07:29 PM posted to rec.aviation.soaring
Craig Funston[_2_]
A SH Turbo Driver
There's a very nice article describing the engineering mechanics of prop drives at this link. If the link doesn't work, just google "bd-5 prop shaft analysis" and choose the top link.
Craig
http://www.google.com/url?sa=t&rct=j... d.cGU&cad=rja
http://www.google.com/url?sa=t&rct=j...187178, d.cGU
F-16 Norway Departs for Mission Maple Flag Maple1 Aviation Photos 0 February 27th 11 09:44 PM
Oil door departs the airframe Jack Allison Owning 5 June 15th 05 12:28 AM
Propeller for aircraft engine ground test Guy Deraspe Home Built 0 July 21st 04 04:41 AM
