On Wednesday, December 18, 2013 8:33:51 PM UTC-7, Morgans wrote:
"Dave Nadler" wrote in message ... A prospect was checking out the nifty Antares 18T sustainer system somewhere over the forest west of ZWB, when to his great surprise, the propeller departed. Hell of a way to impress a prospect. The problem is with the Solo propeller shaft with the belt reduction system as used on, IIRC: - Ventus CM (not V2) - Duo T - DG-100T I'll bet any money the problem will turn out to be torsional harmonics. Remember the problem with the BD-5? Some excellent research was developed out of the problems of using a 2 cycle engine in that aircraft. Seems I remember that one fix involved a sprag clutch (one was slipping) to get over the torque reversal at some rpms. -- Jim in NC Russia AC-5m's have had some prop departures due to broken shafts. I believe one resulted in a fatal at North Las Vegas about two years ago. Inspections have uncovered cracks in others. IIRC, there was a fix worked. Frank Whiteley |
Not at North Las Vegas (VGT). Perhaps you refer to the Russia that went down about 70 miles north of Tonopah at Kingston NV.
IIRC he tried to bail but had problems. BT |
On Thursday, December 19, 2013 4:47:20 PM UTC-7, Bill T wrote:
Not at North Las Vegas (VGT). Perhaps you refer to the Russia that went down about 70 miles north of Tonopah at Kingston NV. IIRC he tried to bail but had problems. BT That's the one. You're right, Kingston, NV. FW |
F-16 Norway Departs for Mission Maple Flag | Maple1 | Aviation Photos | 0 | February 27th 11 09:44 PM |
Oil door departs the airframe | Jack Allison | Owning | 5 | June 15th 05 12:28 AM |
Propeller for aircraft engine ground test | Guy Deraspe | Home Built | 0 | July 21st 04 04:41 AM |
