Don't you just hate it when the propeller departs the aircraft?
Old December 19th 13, 08:48 PM posted to rec.aviation.soaring
Dave Nadler
Default Don't you just hate it when the propeller departs the aircraft?
On Thursday, December 19, 2013 2:29:53 PM UTC-5, Craig Funston wrote:
There's a very nice article describing the engineering
mechanics of prop drives at this link.
Excellent read, Thanks Craig!
Old December 19th 13, 11:47 PM posted to rec.aviation.soaring
Bill T
Not at North Las Vegas (VGT). Perhaps you refer to the Russia that went down about 70 miles north of Tonopah at Kingston NV.
IIRC he tried to bail but had problems.
BT
Old December 20th 13, 03:12 AM posted to rec.aviation.soaring
Ralph Jones[_3_]
On Wed, 18 Dec 2013 22:33:51 -0500, "Morgans"
"Dave Nadler" wrote in message
A prospect was checking out the nifty Antares 18T
sustainer system somewhere over the forest west of ZWB,
when to his great surprise, the propeller departed.
Hell of a way to impress a prospect.
The problem is with the Solo propeller shaft with the
belt reduction system as used on, IIRC:
- Ventus CM (not V2)
- Duo T
- DG-100T
I'll bet any money the problem will turn out to be torsional harmonics.
Remember the problem with the BD-5?
Yeah, I remember the problem with the BD-5. I know a few people who'd
like to get their hands on him.
Old December 20th 13, 06:08 AM posted to rec.aviation.soaring
Frank Whiteley
BT
That's the one. You're right, Kingston, NV.
FW
Old December 22nd 13, 09:19 PM posted to rec.aviation.soaring
Dave
The LBA restricts the AD to DG1000. The EASA mentions "with unfolding propeller". All gliders in your list have unfolding propellors except the Ventus CM which means the AD doesn't apply to it (yet ?).
Dan G
- Duo T
- DG-100T
- Antares 18T
Apparently there have also been recent incidents with DG1000T.
The propeller is not identical on all the above so the
failure rates will differ.
Axel Lange has worked with Solo to redesign the offending
part and is working on EASA approvals. IIRC this will be
the 3rd or 4th AD on this part, but Axel can calculate why
it failed and also how to make a part that won't...
I don't know if there's been any communication from SH
or who else uses this particular (front belt-reduction)
Solo system.
I see DG has published some info he
http://www.dg-flugzeugbau.de/index.p...1349&tx_ttnews[tt_news]=147&cHash=cd1730aca0037e72c7b2911e83136b2e
Another reminder to always operate your motor with a
plan for failure at any point...
Aaarrrggggg....
Be safe out there,
See ya, Dave "YO electric"
Old December 22nd 13, 09:43 PM posted to rec.aviation.soaring
Dave Nadler
I have no idea what EASA means by "with unfolding propeller".
On the list above, only the DuoT has a hinged (flapping)
propeller, which would I think reduce fatigue loads. All the
others have conventional one-piece propellers (except maybe a
handful of early Ventus CM which had some kind of asymmetrical
prop; I can't remember if those were hinged)...
I'll try contact SH after the holiday break.
Have a great holiday,
Old December 22nd 13, 10:54 PM posted to rec.aviation.soaring
Check this out http://ad.easa.europa.eu/ad/2013-0217-E.
Yes The Ventus CM has an asymmetrical prop that probably reduces the torsional vibrations.
Dan G (Ventus CM Owner)
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Old December 22nd 13, 11:20 PM posted to rec.aviation.soaring
Dave Nadler
IIRC, only a few early Ventus CMs - later ones have "normal" props.
Old December 24th 13, 02:26 PM posted to rec.aviation.soaring
John Firth[_4_]
What kind of asymmetry?
At least you can retract the engine; not so if the belt breaks.
John F
At 22:54 22 December 2013, wrote:
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
Old December 24th 13, 04:22 PM posted to rec.aviation.soaring
Dan Marotta
Is this what you mean?
http://www.glidingmagazine.com/Image...lerPylon01.jpg
"John Firth" wrote in message
John F
Check this out
- Duo T
- DG-100T
- Antares 18T
Solo system.
Aaarrrggggg....
Be safe out there,
F-16 Norway Departs for Mission Maple Flag Maple1 Aviation Photos 0 February 27th 11 09:44 PM
Oil door departs the airframe Jack Allison Owning 5 June 15th 05 12:28 AM
Propeller for aircraft engine ground test Guy Deraspe Home Built 0 July 21st 04 04:41 AM
