Charging multiple glider batteries
Old January 7th 14, 09:32 PM posted to rec.aviation.soaring
Mike J.
Default Charging multiple glider batteries
On Monday, January 6, 2014 1:53:37 PM UTC-6, Don wrote:
Our club (US) keeps 8 batteries charged in two banks of 4 batteries. We use two Battery Tender Junior chargers, one for each bank. The charging rate is not very fast, but they have at least 20 hours between use and often a week. Mostly this has worked pretty well, but we are more often finding batteries that are not fully charged, even though the battery tender is green indicating full charge. Once fully charged, the charger just floats them. The batteries are the popular glider batteries, 12 volt 7 amp hour sealed lead acid. How do other clubs, commercial ops keep multiple batteries charged up? I realize charging problems can occur when one battery is damaged, won't take a full charge or is simply dead. Or if the charging rate varies markedly from batt to batt. It may be possible to overcharge the other ones. Ideally each battery would be charged individually, but that is expensive and takes more space. What solutions are out there?
Glider Batteries and Chargers Grider Pirate Soaring 29 September 1st 10 05:52 AM
FA: multiple used glider/soaring related items Mark Zivley Soaring 0 February 12th 06 05:20 PM
Still interested in Lithium batteries for your glider? Eric Greenwell Soaring 5 March 5th 05 02:32 PM
Charging? PaulaJay1 Owning 25 February 2nd 05 06:03 AM
Cessna 210 charging problem John Clonts Owning 9 July 14th 04 03:08 PM
