Is the 200ft below Min Finish Height Rule Working?
Old January 23rd 14, 04:12 PM posted to rec.aviation.soaring
Dan Marotta
Default Is the 200ft below Min Finish Height Rule Working?
All this talk of "safety" and you post a picture you took of your
speedometer while driving at 72 MPH? And probably on a two lane road.
Sheesh...
"Dave Nadler" wrote in message
On Wednesday, January 22, 2014 2:55:32 PM UTC-5, Luke Szczepaniak wrote:
I finally got to try a line finish in a contest at Hobbs last year.
In my opinion it is the safest option available...
Perhaps you were absent when a pilot blew a final glide from
the North, and landed on a street in a housing development
close to the airport?
See race day 7:
http://www.nadler.com/public/2013_Hobbs/2013_Hobbs.html
Some of us will make sure to have safe options,
but not all, and it cannot be legislated to cover
all conditions anyway...
Old January 23rd 14, 08:46 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Thursday, January 23, 2014 10:12:42 AM UTC-6, Dan Marotta wrote:
All this talk of "safety" and you post a picture you took of your speedometer while driving at 72 MPH? And probably on a two lane road. Sheesh...
Yeah. That is way too slow, Dave. I have taken pictures of the speedo at upwards of 100 MPH on two lane roads. Step it up, will ya?
Actually, Dan. Dave's picture was of the odometer. Just happens you also get to see the speedometer. :-)
Steve
Old January 24th 14, 01:01 PM posted to rec.aviation.soaring
If a 700ft finish is too low for a 18 meter national contest, then it is probably too low for a Regional. Yes, I understand the caveat of diving off a ridge and would not have a problem with that.
Last year at Perry and at Cordele, I was racing my Silent-IN, the 12 meter, 31/1 L/D.
We had 700 foot finishes at both sites. I understand this is comfortable for a modern 15 or 18 meter ship and leaves plenty of margin.
This does not leave much if any margin for me, and found that I needed to take extra height to be safe.
I am racing too, and this leaves us essentially racing to a different finish points. You are racing to a finish height that gives you an adequate safety margin and I am racing to the same point, but having to take more altitude for the same safety factor.
I understand UH's comment about immediately joining the pattern in an orderly fashion, but I think this could also be done with a 1000 foot finish and some more spoilers added.
This also gives a little more room is someone has a problem on landing and obstructs the runway.
Kevin
192
Old January 24th 14, 02:10 PM posted to rec.aviation.soaring
Good points Kevin.
Kevin
192
Old January 26th 14, 10:37 PM posted to rec.aviation.soaring
Bravo Zulu
On Friday, January 24, 2014 8:10:34 AM UTC-6, wrote:
Good points Kevin.
Kevin
192
To add to Kevin's point. I have seen some pilots take such a long down-wind turn to final that I could have turned inside of their pattern and had plenty of room. If I were in his glider, that would be a real problem for a short wing glider. A higher finish hurts no one as long as we are all going to the same finish. If we keep the pattern tight, low energy or lower L/D gliders have an easier time transitioning to pattern and landing.
Old January 24th 14, 02:46 PM posted to rec.aviation.soaring
If a 700ft finish is too low for a 18 meter national contest, then it is probably too low for a Regional. Yes, I understand the caveat of diving off a ridge and would not have a problem with that. Last year at Perry and at Cordele, I was racing my Silent-IN, the 12 meter, 31/1 L/D. We had 700 foot finishes at both sites. I understand this is comfortable for a modern 15 or 18 meter ship and leaves plenty of margin. This does not leave much if any margin for me, and found that I needed to take extra height to be safe. I am racing too, and this leaves us essentially racing to a different finish points. You are racing to a finish height that gives you an adequate safety margin and I am racing to the same point, but having to take more altitude for the same safety factor. I understand UH's comment about immediately joining the pattern in an orderly fashion, but I think this could also be done with a 1000 foot finish and some more spoilers added. This also gives a little more room is someone has a problem on landing and obstructs the runway. Kevin 192
I Fly an ASK-21 that has similar performance in a couple contests each year.. If the finish position and the pattern are such that I think we will need a bit more margin, I add it in the last couple miles and get on with it. That is part of what handicapped racing is about.
Most finishes set at 700 feet result in a bit more altitude available because few fly the finish perfectlyand most have some excess energy.
In any case, if pilots at a race have a concern about the finish height, the CD has the option to adjust it. That said, at a big contest like Perry, adjusting the finish and complicating the pattern for 65 gliders to accomodate 1 or 2 makes not too much sense.
UH
Old January 24th 14, 02:56 PM posted to rec.aviation.soaring
UH
Wise from UH. There is way too much asking the rules committee to impose from on high things that you can just talk to the CD about.
But..700 feet is really 500 feet, and 500 feet, 40 knots, and one mile from the south or north is really uncomfortable even in 15 meters at Perry. I also don't agree with Hank's idea that too much altitude leads to traffic problems. More energy always good. The CD can suggest an extended pattern if youse don't know what to do with yourselves for a few hundred feet. So if anyone wants to ask for 1000 feet at Perry, you'll have another voice to agree with it.
John Cochrane
Old January 24th 14, 03:14 PM posted to rec.aviation.soaring
Andy Gough[_2_]
First of all I would like to congratulate Sean for being able to pick the most controversial subjects to discuss on RAS. Just about every thread Sean starts or joins turns into a weeks long exchange that explores every possible nuance to the point of ad nauseam. If newcomers to the sport could be encouraged to the same degree we would see a boom in soaring participation.
But I digress my main observation is that twenty years ago before GPS to receive a good finish one had to arrive within the airfield boundaries with flying speed and it was necessary to complete a touchdown, roll out and stop without catastrophic incident. If you landed before the fence or executed an arrival rather than a landing, points for a successful finish were not awarded. The difference now is we are required to arrive above and within the horizontal boundaries of the top of an invisible cylinder. The cylinder itself is no different than a line of trees on the airfield boundary, enter it from anywhere other than above and you did not make the finish. Except of course we have graduated penalties, which change the whole safety objective, the main reason for going to a finish cylinder. Imagine if we had the same graduated penalties in the finish line scenario:
· hit the fence post but cause only superficial damage 20 points
· stall and groundloop just inside the airfield boundary, breaking off the tail boom 500 points
· but come to rest past the runway threshold 100 points
Well I hope you get the picture. Logically, if you don't complete the mission the way it is intended you don't deserve the points.
If safety is not the reason for adopting a finish cylinder then we might as well go back to the old finish line at least it was fun and it was simple to determine a valid finish. Both methods open the possibility to pull ups and thermalling low and close to the airport. Is this the behaviour we are trying to mitigate? Thermalling low down or aggressive pull ups can occur anywhere on task, this behaviour is not governed by proximity to the finish. However funnelling the fleet into a 1 mile radius cylinder at 500 ft may concentrate traffic to the point this behaviour can be detrimental to more than the individual performing these manoeuvres. We use a 5 mile cylinder for the start to provide separation should we not do the same at the finish. It could be argued that there is greater concentration at the start than the finish, but gaggling ensures a mass finish is not unusual. Finishing the race further out would necessitate a higher cylinder to allow the glider to cover the distance to the airport and extra height is needed to perform a circuit. The desired circuit arrival height can be used to determine the height at which the race ends at the circle boundary. Spectator value disappeared along with the finish line but if one is bent on thrilling the onlookers there is plenty more time and room to execute the move using the remote finish.
Contest site management already has the leeway to set a finish height. We have testimony that unless the finish is set high enough lower performance gliders entering the finish cylinder at the optimum height may encounter difficulty completing a satisfactory circuit and landing. Again if safety is the motivation then maybe we need to allow contest management the ability to set realistic safety parameters to suit the contest they are running. In a large contest at a restricted site a wider finish ring with height set high enough to ensure an orderly circuit for the given site and different finish heights to suit each class might alleviate safety concerns and given the more generous margins obviate the need for penalty points and the arguments they create. In short flexible finish height and an elastic cylinder radius may be the answer but despite all the risks I still prefer the old fashioned flying finish the most.
Andy Gough
Old January 24th 14, 04:42 PM posted to rec.aviation.soaring
If safety is not the reason for adopting a finish cylinder then we might as well go back to the old finish line at least it was fun and it was simple to determine a valid finish. Both methods open the possibility to pull ups and thermalling low and close to the airport. Is this the behaviour we are trying to mitigate? Thermalling low down or aggressive pull ups can occur anywhere on task, this behaviour is not governed by proximity to the finish. However funnelling the fleet into a 1 mile radius cylinder at 500 ft may concentrate traffic to the point this behaviour can be detrimental to more than the individual performing these manoeuvres. We use a 5 mile cylinder for the start to provide separation should we not do the same at the finish.. It could be argued that there is greater concentration at the start than the finish, but gaggling ensures a mass finish is not unusual. Finishing the race further out would necessitate a higher cylinder to allow the glider to cover the distance to the airport and extra height is needed to perform a circuit. The desired circuit arrival height can be used to determine the height at which the race ends at the circle boundary. Spectator value disappeared along with the finish line but if one is bent on thrilling the onlookers there is plenty more time and room to execute the move using the remote finish.
Andy Gough
You are correct Andy. Even a 700ft AGL minimum finish height is not enough for a low performing glider to execute a safe pattern. Coming back from the ridge at Mifflin, into the wind and a good bit of sink, I found that at 700ft 1 mile out, it would be just enough to do a base-final turn. It was not intentionally executed in this manner... just a function of getting accustomed to another ridge site and its arrival procedures from the ridge. At other contests, 500ft AGL puts low performing gliders into a straight-in final to the runway.
Regards,
Daniel Sazhin
Old January 24th 14, 07:52 PM posted to rec.aviation.soaring
Mike I Green
My finish height, fun, cross country, or contest is 1200'. Didn't win
a lot of contests but had a hell of a lot of fun.
MG
Mike I Green
Sean F2, Evan T8, HELP! Current finish cylinder rule! Tom Kelley #711 Soaring 5 May 24th 13 09:59 PM
Safety finish rule & circle radius Frank[_1_] Soaring 19 September 12th 07 07:31 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
