Tow DROID
Old February 6th 14, 06:38 AM posted to rec.aviation.soaring
Frank Whiteley
Default Tow DROID
http://www.aerotechnews.com/news/201...o-uas-air-tow/
Old February 6th 14, 04:21 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
The glider is so far out of position that I'm surprised the tow pilot has
not released him.
....And did you see that little rigging stand? Where was the solo rigging
device?
"Frank Whiteley" wrote in message
Old February 6th 14, 04:32 PM posted to rec.aviation.soaring
Tom Gardner[_2_]
Default Tow DROID
Wow. They are behind the curve
Search youtube for combinations of rc/glider/towed and similar,
and you will see many many videos of rc enthusiasts doing just that!
Old February 6th 14, 05:10 PM posted to rec.aviation.soaring
Eric Bick (1DB)
Default Tow DROID
And ... they get paid to do this ...
Eric Bick
Old February 6th 14, 09:28 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Tow DROID
has not released him.
....but did you notice that the towline attaches to the tug on top of the
wing at the CG position? That's SOP on the RC world and I imagine it
makes the glider position a lot less critical since it can't jerk the tow
plane's tail around.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 6th 14, 09:32 PM posted to rec.aviation.soaring
Default Tow DROID
http://www.aerotechnews.com/news/201...-demonstrates-
autonomous-uas-to-uas-air-tow/
I thought that too, until I read the text a bit more carefully. They
verified that the UAVs were trimmed correctly, etc by hand flying a tow
or two before they did a number of completely autonomous flights.
Its just unfortunate that the main picture shows one of the manually
flown launches and that they didn't publish any pictures of an antonomous
launch.
org |
Old February 6th 14, 10:38 PM posted to rec.aviation.soaring
Tom Gardner[_2_]
Default Tow DROID
launch.
You're right, but you do have to read it carefully to see past all
the future tense and "...to evaluate the research pilot's ability to..."
The biggest clue is the "autonomous" in the URL!
Old February 7th 14, 01:06 AM posted to rec.aviation.soaring
Default Tow DROID
http://www.aerotechnews.com/news/201...drydens-droid-
demonstrates-
antonomous launch.
You're right, but you do have to read it carefully to see past all the
Yes, you're right: the description is not at all well written. It would
have helped a lot if the guy at the next desk had read the text and then
helped to rewrite it.
org |
Old February 8th 14, 02:31 PM posted to rec.aviation.soaring
son_of_flubber
Default Tow DROID
Returning for a moment to the 19th century tow hook designs that are on most tugs.
Why does the pilot need to pull the release if the glider kites? Why is the release for a deadly tow position not fully automatic? Is a simple purely mechanical, totally foolproof and 100% automatic release not possible?
As the guy in the glider, I would be fine with a 100% automatic release. If I kite, release me immediately.
Old February 8th 14, 04:50 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
The standard setup is to use a Schweizer hook which is rigidly mounted in
pitch and can swivel around the yaw axis. So, if the glider kites, it
exerts sufficient force on the release mechanism that the tow pilot may not
have the strength to pull the lever. It's also possible that, should the
glider get too wide, the axis of the release cable is too far off center to
operate the release. So... Stay in position on tow!
The Tost release does not suffer from this design problem. I've also seen
the Schweizer release mounted to a heavy duty gate hinge for use in ground
launching. This allows it to align with the axis of the rope so there's no
difficulty with the driver or observer releasing the rope. I don't think
you'd get such a system approved for mounting on the tail of an aircraft.
"son_of_flubber" wrote in message
most tugs.
possible?
Aviation applications for the Droid phone Bob Owning 3 January 2nd 10 03:26 AM
