Tow DROID
Old February 6th 14, 10:38 PM posted to rec.aviation.soaring
Tom Gardner[_2_]
Default Tow DROID
On 06/02/14 21:32, Martin Gregorie wrote:
On Thu, 06 Feb 2014 16:32:14 +0000, Tom Gardner wrote:
On 06/02/14 06:38, Frank Whiteley wrote:
http://www.aerotechnews.com/news/201...-demonstrates-
autonomous-uas-to-uas-air-tow/
Wow. They are behind the curve
Search youtube for combinations of rc/glider/towed and similar,
and you will see many many videos of rc enthusiasts doing just that!
I thought that too, until I read the text a bit more carefully. They
verified that the UAVs were trimmed correctly, etc by hand flying a tow
or two before they did a number of completely autonomous flights.
Its just unfortunate that the main picture shows one of the manually
flown launches and that they didn't publish any pictures of an antonomous
launch.
You're right, but you do have to read it carefully to see past all
the future tense and "...to evaluate the research pilot's ability to..."
The biggest clue is the "autonomous" in the URL!
Old February 7th 14, 01:06 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Tow DROID
http://www.aerotechnews.com/news/201...drydens-droid-
demonstrates-
antonomous launch.
You're right, but you do have to read it carefully to see past all the
Yes, you're right: the description is not at all well written. It would
have helped a lot if the guy at the next desk had read the text and then
helped to rewrite it.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 8th 14, 02:31 PM posted to rec.aviation.soaring
son_of_flubber
Default Tow DROID
Returning for a moment to the 19th century tow hook designs that are on most tugs.
Why does the pilot need to pull the release if the glider kites? Why is the release for a deadly tow position not fully automatic? Is a simple purely mechanical, totally foolproof and 100% automatic release not possible?
As the guy in the glider, I would be fine with a 100% automatic release. If I kite, release me immediately.
Old February 8th 14, 04:50 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
The standard setup is to use a Schweizer hook which is rigidly mounted in
pitch and can swivel around the yaw axis. So, if the glider kites, it
exerts sufficient force on the release mechanism that the tow pilot may not
have the strength to pull the lever. It's also possible that, should the
glider get too wide, the axis of the release cable is too far off center to
operate the release. So... Stay in position on tow!
The Tost release does not suffer from this design problem. I've also seen
the Schweizer release mounted to a heavy duty gate hinge for use in ground
launching. This allows it to align with the axis of the rope so there's no
difficulty with the driver or observer releasing the rope. I don't think
you'd get such a system approved for mounting on the tail of an aircraft.
"son_of_flubber" wrote in message
most tugs.
possible?
Old February 8th 14, 11:42 PM posted to rec.aviation.soaring
son_of_flubber
Default Tow DROID
Yeah but. Why does the tug pilot have to pull anything when a glider kites? The tug pilot should of course have the option to release at any time.
Here is the 1870 patent for something that look a lot like the Schweitzer tow hook. Click on the thumbnail for a drawing. http://rec.aviation.soaring/
The Tost hook still requires the tug pilot to pull a lever (though the automatic "back release" on the glider side is nice.)
Old February 9th 14, 12:02 AM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
That's a good question.
As a glider pilot, I don't want any part of an automatic release (back
release excepted).
As a tow pilot, I'd rather the glider be released automatically than have
the tug upset and, possibly, driven to the ground.
time.
Old February 9th 14, 03:24 AM posted to rec.aviation.soaring
son_of_flubber
Default Tow DROID
http://www.google.ca/patents/US102067
Old February 9th 14, 12:07 PM posted to rec.aviation.soaring
Default Tow DROID
That doesn't look to be any more an automatically releasing hook than the
Schweitzer is.
org |
Old February 9th 14, 04:29 PM posted to rec.aviation.soaring
Dan Marotta
Default Tow DROID
That patented release mechanism appears to be superior to the Schweizer hook
by having a slot for the clevis to be captured within. With the Schweizer
assembly, the ring can move forward (towards the release mechanism) and,
with the high upward force applied by a kiting glider, render the release
inoperative. Not so, apparently with the older design.
Old February 9th 14, 04:35 AM posted to rec.aviation.soaring
Bill T
Default Tow DROID
I've seen heavy duty gate (barn door) hinges used with auto tow start to pull apart.
If you use one, keep up on the inspections during the day!
BillT
Aviation applications for the Droid phone Bob Owning 3 January 2nd 10 03:26 AM
