THE AVIATORS Soaring Episode
Old February 9th 14, 04:29 PM posted to rec.aviation.soaring
son_of_flubber
Default THE AVIATORS Soaring Episode
On Saturday, February 8, 2014 11:30:34 PM UTC-5, Waveguru wrote:
Gravity does not power our gliders. The forward tilt of lift is what moves us forward. The sun powers our gliders. ( after the initial boost from dead dinosaurs)
Pointing out that the sun is the source of all vertical wind is a good way to recruit young eco-minded prospects, but some folks will be put off by that "sustainable green talk".
My standby line is that "a good glider pilot can stay up for hours without spending any money on fuel". Most people take that as a big plus, and it directs the conversation towards lift and the core challenges of flying gliders.
Old February 9th 14, 04:45 PM posted to rec.aviation.soaring
Dan Marotta
Sorry, CJ, but when pitched nose up with the lift vector aft, you can't maintain a constant speed (without an engine) since the horizontal component of your lift vector is directed aft hence the glider slows down. That is accelerated flight, though a negative acceleration (rate of change of velocity with respect to time = acceleration). Keep this up and you will stall.
The 'forward point force' in your example is rearward and amounts to drag rather than thrust. The weight vector is always towards the center of the earth.
"CJ" wrote in message ...
Waveguru wrote:
A rock has air and gravity when you drop it, but does not move forward
through the air. Our wings provide our thrust to move us horizontally.
Boggs
A rock doesn't fall in equilibrium (until terminal velocity at least) and
it's forces operate in only one plane - the vertical. Can we compare apples
with apples please?
If you have sound reasoning to offer and preferably, a vector diagram, I'm
all ears.
CJ
B3
Old February 9th 14, 04:47 PM posted to rec.aviation.soaring
Dave Springford
I would guess that waveguru has never taken a first year Applied Mechanics Engineering course, otherwise he would understand things such as equilibrium, free-body diagrams, vectors and force components and the fact that lift acts perpendicular to the relative airflow and therefore by definition can not provide thrust.
Old February 9th 14, 05:37 PM posted to rec.aviation.soaring
CJ[_3_]
Thanks for pointing out the flaw in my example Dan! You're right in that
the example I gave stated lift acting rearwards which in sustained flight
is incorrect. Whilst the aerodynamic force acts rearwards, the resolved
component of lift does indeed angle slightly forward, effectively, at the
glide angle. Where we seem to disagree (after agreeing that weight always
acts towards the centre of the earth) is that weight can be resolved into
two components. The component that opposes lift and the 'forwards
component' that opposes drag.
Figure 2-15 at http://avstop.com/ac/power_parachute/chapter2_7.html refers.
Where "WD" is the "forward component of weight" that I'm speaking of.
Not being able to draw here, I'm stuck using the works others - sorry!
CJ
B3
**reader not quoting properly; text below for context**
stall.
earth.
Boggs
with apples please?
all ears.
CJ
B3
Old February 9th 14, 09:48 PM posted to rec.aviation.soaring
"Pitch angle" and "forward tilt" in relation to what, hmmmm?
Remove gravity from the equation and you're not going anywhere.
Last time we had a glider on display at the Abbotsford Airshow I filled in the "powerplant" section of the supplied information board as "hybrid gravitic-nuclear fusion drive system."
As for using young pilots... well, you fly with who you have - and who is available to fit the schedule of the television crew. My club has at times had some young instructors and some years we don't. For the second half of the show I don't think it would be an option. it's not like Ontario has a wide selection of expert, legendary aerobatic pilots known for putting on amazing glider aerobatic performances at airshows all across North America to choose from...
Old February 9th 14, 11:41 PM posted to rec.aviation.soaring
Dan Marotta
Ya know what, CJ? I kinda, sorta, agree with you - somewhat! That powered
parachute discussion made my brain hurt, though.
Cheers!
refers.
CJ
B3
will
stall.
earth.
Boggs
apples
with apples please?
all ears.
CJ
B3
SOARING on The Aviators Set to Air Charlie Papa[_2_] Soaring 1 November 30th 13 04:04 PM
The Aviators TV Soaring Segment Frank Whiteley Soaring 1 August 9th 13 12:32 AM
Episode 3 of InsideSoaring [email protected] Soaring 4 April 24th 08 04:33 AM
Mythbusters Episode and FMS Marco Leon Piloting 19 February 13th 07 05:45 AM
New PEZ episode John Shelton Soaring 11 December 17th 03 07:49 AM
