Pylon mounted wings superior?
Old February 11th 14, 05:56 PM posted to rec.aviation.soaring
Soartech
Default Pylon mounted wings superior?
On Sunday, February 9, 2014 10:03:36 AM UTC-5, firsys wrote:
A wing 3 ft above the CG will give excessive roll stability; to
get an acceptable roll rate there will have to be substantial
anhedral. It will be at least look peculiar but there may be
other detractions.
Wings with anhedral have been shown to be more efficient (L/D) than straight wings. I can looks up the study if anyone needs to know more.
This may be the reason paragliders perform as well as they do despite large amounts of drag.
Old February 11th 14, 06:15 PM posted to rec.aviation.soaring
On Tuesday, February 11, 2014 12:56:19 PM UTC-5, Soartech wrote:
On Sunday, February 9, 2014 10:03:36 AM UTC-5, firsys wrote: A wing 3 ft above the CG will give excessive roll stability; to get an acceptable roll rate there will have to be substantial anhedral. It will be at least look peculiar but there may be other detractions. Wings with anhedral have been shown to be more efficient (L/D) than straight wings. I can looks up the study if anyone needs to know more. This may be the reason paragliders perform as well as they do despite large amounts of drag.
Given the trend in sailplanes toward multiple dihedral breaks toward the tip, and the associated benefit of spreading the flow field spanwise, it seems that your statement is based upon dated knowledge. Or possible it applies in some cases and not others.
UH
Old February 12th 14, 12:12 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Please do. Might be amusing.
On Tuesday, February 11, 2014 12:15:43 PM UTC-6, wrote:
...Or possible it applies in some cases and not others.
Think you will find paragliders do have large drag, but such low speed as to make the horsepower consumed small. Think Paul MacCready and the Gossamer series of man powered planes. Most previous were cantilever, but he put wires out all over the place. Why? Lighter structure = lower flying speed = lower horsepower required. Horsepower is a cubic function of speed. Cut the flying speed in half, cut the horsepower to 1/8th. So you can afford a little higher drag if you knock the speed way down. Man powered flight is horespower limited. So is paraglider flight. They don't have to make much lift, and at low speed, all the risers don't make too much drag. Not much horsepower available from the low weight, either, so not much speed range.
On Tuesday, February 11, 2014 4:24:53 PM UTC-6, J. Nieuwenhuize wrote:
There are some other details at work; you gain lift, since now the wing is
actually lifting (no dip in the spanwise lift distribution anymore), so you
can actually shrink the wing area with a significant part of the wetted area increase.
Well, there is still a dip in the lift distribution. It is caused by the horizontal tail. If, of course, we are talking complete system, and not just wing. There is still a negative effect from the fuselage, but not NEARLY as big
The pylon could be rather small, for a modern super-elliptic area
distribution (winglets), we now need a root chord of something like 24".
Given the fairly low forces on the pylon (save yaw, groundloop), the pylon
could be a lot smaller in chord and thickness.
The smaller you make the pylon and closer you get the load reacting points together, the higher the loads go. And, if you make the pylon too small, you lost all your volume for control connections. :-) Also, check the root chord on the AS-W27, V2, or even the Diana or Duckhawk. Think they are still 27 to 30 inches.
I also am not ready to buy into the need for anhedral for roll control if you have a pylon mounted wing. Weight of the wings, plus all the water carried in the wings, tends to make the fusleage and pilot a much smaller percentage of the mass of the flying machine. So, the center of mass is not starting as close to on the axis of the fuselage as you might think. What? The world doesn't revolve around the pilot? :-)
Good thoughts. Keep them coming.
Steve
Old February 12th 14, 04:47 PM posted to rec.aviation.soaring
Dan Marotta
Hey Steve,
The McDonnell XF-85 Goblin (
http://en.wikipedia.org/wiki/McDonnell_XF-85_Goblin ) had winglets *and*
anhedral (in the tail). Do you think it was much of a glider?
Coming to Moriarty this year?
"Steve Leonard" wrote in message
straight
drag.
you
area increase.
NEARLY as big
Steve
Old February 12th 14, 09:11 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Op woensdag 12 februari 2014 01:12:40 UTC+1 schreef Steve Leonard:
distribution (winglets), we now need a root chord of something like 24"..
I might have been too optimistic there with the root chord. Nevertheless I do expect the "next generation" to have narrower root chords, the modern super-elliptic planforms made possible by optimized winglets/polyhedral result in an almost untapered inner part of the wing.
I wouldn't worry too much about the loads on the pylon. Those are pretty small as compared to the wing. Packaging of the controls might be the major issue, though even there, there's some "unconquered terrain", see the Concordia control system. Having the flap/aileron mixer at the mid/outer wing joint could be a solution.
Here is some more in-depth discussion on pylon-mounted (sailplane) wings by the same author as your truly ;-)
http://www.homebuiltairplanes.com/fo...ylon-wing.html
Old February 16th 14, 05:16 PM posted to rec.aviation.soaring
John Firth[_4_]
The kicker here is the torsional load on the pylon from a ground
loop or possibly a spin plus recovery. Even if a carbon fibre
tube could approach the torsional rigidity/strength of a standard
fore/aft pin attachment in the fuselage, the structure needed
to distribute the pylon loads into the wing may be compicated.
But I am willing to be proved wrong.
John F
strai=
ght=20
be=
the=20
dr=
ag.
wrot=
e:
...Or possible it applies in some cases and not others.=20
t=
Gossame=
put
wires out all over the place. Why? Lighter structure =3D lower flying
spe=
ed =3D lower horsepower required. Horsepower is a cubic function of
speed.=
af=
fli=
ma=
N=
speed=
range.
i=
s=20
y=
ou=20
a=
rea increase.
h=
jus=
NEARLY=
as big
The pylon could be rather small, for a modern super-elliptic area=20
24".
pylo=
n
points
y=
root=
st=
y=
carr=
perce=
sta=
T=
Steve
Old March 1st 14, 09:48 PM posted to rec.aviation.soaring
J. Nieuwenhuize
Op zondag 16 februari 2014 18:16:26 UTC+1 schreef firsys:
John F
I doubt that's nearly as much of a factor as many think.
Ground loop loads, at least from the regulatory point are not that high. 400N, so about 70 kgf (155 lbsf) ultimate load at the extremity of tip, balanced by an opposite load on the tail wheel. (CS22-5?? from memory). Same for spin recovery loads; those are nowhere near as high as rudder deflection @ Va, which is likely the limiting load case for the pylon.
As for the wing structure; mounting the pylon in yaw is pretty trivial. You're simply loading the skin in pure shear, which is about the easiest connection possible. The pylon load and mounting it to the fuselage skin are the biggie, but nothing a few layers of carbon won't solve. Less certain about flutter, but then most of the modes that involve yaw have much lower inertia (sideways boom bending/torsion), 2-3 orders of magnitude less inertia as a fully ballasted wing.
Kingfisher and plncraze came up with this thesis on http://www.homebuiltairplanes.com/fo...ylon-wing.html
MANDATORY reading for anybody that thinks this is interesting. Not 1:1 applicable to full-scale sailplanes, but a most interesting read wrt pylon wings:
http://drum.lib.umd.edu/bitstream/19...i-umd-5315.pdf
Also this article by Johan Bosman has some interesting remarks about moving the wing up (article on the end of the page):
http://www.glidinginternational.com/...g_Stories.html
Old March 1st 14, 10:35 PM posted to rec.aviation.soaring
At the worlds in 2010, Prof Boermans gave an interesting talk on wing-fuselage drag, suggesting that moving the wing to the top of the fuselage -- not shoulder, and not pylon -- could reduce drag. An article in gliding international followed up with some analysis from Jonkers suggesting they are going to implement the idea at some point soon. Not pylons, but higher mounted wings may be on their way.
john cochrane
Cartoons, pt 5 - Superior.jpg (1/1) Mitchell Holman[_3_] Aviation Photos 1 July 30th 09 01:41 PM
Honda Biz Jet With Wing Pylon Mounted Engines ? Robert11 Piloting 6 September 8th 07 07:12 AM
Pylon 8 problem gatt Piloting 8 June 26th 06 10:33 PM
Fin Mounted TE Prob vs fuselage mounted TE prob [email protected] Soaring 8 June 4th 05 10:39 PM
AND THE KIS CRUISER ROUNDS THE PYLON... Paul Folbrecht Home Built 38 January 18th 05 04:29 AM
