Does anyone use a tug tow hook that releases automatically whenglider kites?
Old February 11th 14, 10:39 PM posted to rec.aviation.soaring
kirk.stant
Default Does anyone use a tug tow hook that releases automatically whenglider kites?
On Tuesday, February 11, 2014 12:41:48 PM UTC-6, son_of_flubber wrote:
How about a weather proof calibrated mechanical device placed between the Tost release hook and the tug that pulls the Tost release lever when the vertical component exceeds a limit? There is a well-proven mechanism that does something like that on my downhill ski bindings. A rocket-scientist is not required.
Well, if you think it is that big a problem and it can't be addressed through better (more threatening) training, then how about an optical device on the towplane that tracks the glider and 1. warns the tow pilot and glider pilot when the glider is moving out of the safe tow envelope, and 2. fires a guillotine on the tow rope when the glider reaches the limit. Add a flashing light on the tow plane to warn the glider pilot that he is about to be dumped.
Or, just teach the glider pilot to NEVER lose sight of the towplane, and to immediately release if he does.
Is it a matter of the FAA and insurance underwriters making any change to the status quo cost-prohibitive? What sort of gauntlet does one need to run?
Bwahahahaha!!!!
ROTFLMFAO!
Gasp, sigh, that just really made my day!
Cheers,
Kirk
66
Old February 12th 14, 12:26 AM posted to rec.aviation.soaring
son_of_flubber
Bwahahahaha!!!!
ROTFLMFAO!
http://i.imgur.com/wPwWj.gif
Old February 12th 14, 01:43 PM posted to rec.aviation.soaring
kirk.stant
Cute!
Seriously, the biggest problem is probably just plain cost. Everybody knows the Schweizer tow releases are junk and dangerous - but (like the Schweizer gliders) they are cheap and available. So we use them. There is a much better and safer replacement - the Tost - but it cost so much that when you try to get a club interested in replacing their Schweizer hooks with Tost hooks you get laughed out of the club house.
So for now we are stuck with solving (a real but fortunately rare) the problem with better awareness of what can happen (by both the tugger and tuggee) and better training.
Now, if anybody has any spare explosive bolts laying around, we could probably come up with some kind of emergency release that the tow pilot could activate under any condition...(just don't let your local FAA guy see it).
Cheers,
Kirk
66
Old February 12th 14, 03:13 PM posted to rec.aviation.soaring
On Wednesday, February 12, 2014 8:43:35 AM UTC-5, kirk.stant wrote:
On Tuesday, February 11, 2014 6:26:21 PM UTC-6, son_of_flubber wrote: http://i.imgur.com/wPwWj.gif Cute! Seriously, the biggest problem is probably just plain cost. Everybody knows the Schweizer tow releases are junk and dangerous - but (like the Schweizer gliders) they are cheap and available. So we use them. There is a much better and safer replacement - the Tost - but it cost so much that when you try to get a club interested in replacing their Schweizer hooks with Tost hooks you get laughed out of the club house.. So for now we are stuck with solving (a real but fortunately rare) the problem with better awareness of what can happen (by both the tugger and tuggee) and better training. Now, if anybody has any spare explosive bolts laying around, we could probably come up with some kind of emergency release that the tow pilot could activate under any condition...(just don't let your local FAA guy see it). Cheers, Kirk 66
The only explosive allowed in our tugs is the tow pilot.
UH
Old February 16th 14, 01:21 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default Does anyone use a tug tow hook that releases automatically when glider kites?
to=
immediately release if he does. =20
=20
to=
r=
un?
One of the never to be breached rules of aerotowing for a glider pilot in
the UK is "if at any time you loose sight of the tug for ANY reason you are
to pull the release"
If you read Chris's article carefully you may deduce that in the worst case
scenario, the rapid vertical departure of the glider, by the time the
glider pilot realises he has lost sight of the tug, and attempts to pull
the release it is already far to late to make any significant difference to
what is going to happen.
"Our first conclusion was that, in the event of this sequence occurring
accidentally as a result of an inadvertent pitch up by the glider pilot,
there was effectively no chance that either the glider pilot or tow-pilot
would recognise the problem and pull the release in the available time."
It was this very scenario that killed a very good friend of mine who was a
very experienced tug pilot. There are some events that, paradoxically,
require corrective action to commence before onset if they are to be
effective in time to change the outcome.
As for cheap solutions, I am firmly of the view that most wooden gliders
with only CoG hooks should not be aerotowed, those with compromise hooks
should be aerotowed with extreme care.
Old February 16th 14, 08:50 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
to=
=20
to=
to
r=
un?
ar
cas
t
I would add that, although I haven't done the same tests with any glass
gliders, I'm pretty sure that many of the light-weight Standard/15m types
would behave in the same way on a C of G hook. Std Cirrus would be a prime
candidate, would somebody with access to one care to try it at safe
altitude and report the result?
What I find rather sad about the gliding movement is the lack of
willingness to go and get the facts. We have been aware of this problem
for over 35 years, I described flights tests that I carried out, to try to
improve understanding and seek a solution. Has anyone else done the same?
Old February 16th 14, 10:06 AM posted to rec.aviation.soaring
Jonathon May[_2_]
and
to=
=20
change
to=
to
r=
un?
ar
cas
t
tow-pilot
hook
prim
same?
In my opinion more relevant has any one tried these departures from track
with the next generation tugs eurofox to name but one.
We are all used to boxing the wake of a Pawnee and I know the teams
introducing them into clubs are taking a steady measured introduction .
But I don't want to be known as the the guy that killed the tuggie because
I
didn't know what was acceptable .
My apologies to all at YGC for washing in public but this thread stirred my
concerns and I know that when I get to fly behind the fox I will get a
briefing
But as Chris said until you have tested and published the results no one
knows.
Jon
Old February 16th 14, 11:01 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
and
to=
change
to=
to
r=
un?
i
ar
cas
t
pilot,
tow-pilot
time."
was
hook
prim
t
same?
because
I
my
briefing
knows.
Jon
Jon, I share your concern about the new generation of light-weight
tow-planes, I strongly suspect they will be more vulnerable to upset
accidents. I think that carrying out test like the ones I described should
be a requirement before the authorities approve the type for towing. It
may be possible I'll get the chance to try it out behind a Eurofox later
this year, I'll publish the results here if I do.
Old February 16th 14, 03:37 PM posted to rec.aviation.soaring
and
to=
change
to=
to
r=
un?
i
ar
cas
t
pilot,
tow-pilot
time."
was
hook
prim
t
same?
because
I
my
briefing
knows.
Jon
Imagine a proximity switch built into the tow hook in the nose of any glider. It could be adjusted in such a way that it senses the larger tow ring position moving down when the glider is kiting. That signal could be hooked up to a warning horn or speech output "Glider too high". I realize that the warning would sound on the ground until the rope is tight. Sensing airspeed above 25 knots would address that problem.
Herb
Old February 17th 14, 07:45 AM posted to rec.aviation.soaring
Chris Rollings[_2_]
=20
=20
=20
=20
=20
=20
towplane,
=20
and
=20
to=3D
=20
immediately release if he does. =3D20
=20
=20
=20
any=20
=20
change
=20
to=3D
=20
nee
=20
to
=20
r=3D
=20
un?
=20
=20
pilot
=20
i
=20
yo
=20
ar
=20
=20
wors
=20
cas
=20
=20
pu=
l
=20
differen=
c
=20
t
=20
=20
=20
=20
=20
=20
=20
occurrin=
g
=20
=20
pilot,
=20
=20
tow-pilot
=20
=20
time."
=20
=20
=20
was
=20
=20
paradoxically
=20
=20
effective in time to change the outcome.=20
=20
=20
glide=
r
=20
compromise=20
=20
hook
=20
=20
=20
=20
=20
glas
=20
typ=
e
=20
a=
=20
=20
prim
=20
=20
=20
=20
=20
proble
=20
try
=20
t
=20
the=20
=20
same?
=20
=20
=20
trac=
k
=20
=20
=20
=20
We are all used to boxing the wake of a Pawnee and I know the teams=20
=20
inReach website not updating track automatically Eric Greenwell[_4_] Soaring 4 September 23rd 13 09:59 PM
Compare/Contrast: CG hook on aerotow vs. CG hook on winch son_of_flubber Soaring 37 June 4th 12 10:40 PM
TOST E85 RELEASES [email protected] Soaring 2 March 6th 05 04:21 PM
Cumulus releases version 1.2.1 André Somers Soaring 0 March 2nd 05 09:58 PM
NSA releases EC-121 Liberty tapes: no smoking gun Mike Weeks Military Aviation 0 July 9th 03 05:06 AM
