Chris Rollings wrote:
At 10:06 16 February 2014, Jonathon May wrote: At 08:50 16 February 2014, Chris Rollings wrote: At 01:21 16 February 2014, Don Johnstone wrote: At 22:39 11 February 2014, kirk.stant wrote: Or, just teach the glider pilot to NEVER lose sight of the towplane, and to= immediately release if he does. =20 Is it a matter of the FAA and insurance underwriters making any change to= the status quo cost-prohibitive? What sort of gauntlet does one nee to r= un? One of the never to be breached rules of aerotowing for a glider pilot i the UK is "if at any time you loose sight of the tug for ANY reason yo ar to pull the release" If you read Chris's article carefully you may deduce that in the wors cas scenario, the rapid vertical departure of the glider, by the time th glider pilot realises he has lost sight of the tug, and attempts to pul the release it is already far to late to make any significant differenc t what is going to happen. "Our first conclusion was that, in the event of this sequence occurring accidentally as a result of an inadvertent pitch up by the glider pilot, there was effectively no chance that either the glider pilot or tow-pilot would recognise the problem and pull the release in the available time." It was this very scenario that killed a very good friend of mine who was very experienced tug pilot. There are some events that, paradoxically require corrective action to commence before onset if they are to b effective in time to change the outcome. As for cheap solutions, I am firmly of the view that most wooden glider with only CoG hooks should not be aerotowed, those with compromise hook should be aerotowed with extreme care. I would add that, although I haven't done the same tests with any glas gliders, I'm pretty sure that many of the light-weight Standard/15m type would behave in the same way on a C of G hook. Std Cirrus would be a prim candidate, would somebody with access to one care to try it at saf altitude and report the result? What I find rather sad about the gliding movement is the lack o willingness to go and get the facts. We have been aware of this proble for over 35 years, I described flights tests that I carried out, to try t improve understanding and seek a solution. Has anyone else done the same? In my opinion more relevant has any one tried these departures from track with the next generation tugs eurofox to name but one. We are all used to boxing the wake of a Pawnee and I know the teams introducing them into clubs are taking a steady measured introduction . But I don't want to be known as the the guy that killed the tuggie because I didn't know what was acceptable . My apologies to all at YGC for washing in public but this thread stirred my concerns and I know that when I get to fly behind the fox I will get a briefing But as Chris said until you have tested and published the results no one knows. Jon Jon, I share your concern about the new generation of light-weight tow-planes, I strongly suspect they will be more vulnerable to upset accidents. I think that carrying out test like the ones I described should be a requirement before the authorities approve the type for towing. It may be possible I'll get the chance to try it out behind a Eurofox later this year, I'll publish the results here if I do. Chris, as it happens I have also been in the glider during one of these incidents, and once again I emphasise that it is all over in fractions of a second, with absolutley no chance to take any sort of corrective action. It was not a light sailplane either - an ASH25 in fact - flown by its owner with me taking no part in the rear cockpit. (I will try to be more observant in future). The airbrakes had opened as we left the ground, and although the tug pilot was shouting 'bremse' into his radio it took quite some time for the translation to sink in, at which point P1 slammed the brakes shut and quite possibly and inadvertantly pulled back on the stick. Bang, all over, and one very annoyed and very lucky tug pilot back on the ground. Maybe the time to translate the message saved his life. |
inReach website not updating track automatically | Eric Greenwell[_4_] | Soaring | 4 | September 23rd 13 09:59 PM |
Compare/Contrast: CG hook on aerotow vs. CG hook on winch | son_of_flubber | Soaring | 37 | June 4th 12 10:40 PM |
TOST E85 RELEASES | [email protected] | Soaring | 2 | March 6th 05 04:21 PM |
Cumulus releases version 1.2.1 | André Somers | Soaring | 0 | March 2nd 05 09:58 PM |
NSA releases EC-121 Liberty tapes: no smoking gun | Mike Weeks | Military Aviation | 0 | July 9th 03 05:06 AM |
