I'm with Herb on this one. Since you are an XCSoar user, you have many Android options as well. I've been happy with XCSoar on a Dell Streak 5, which has a very good screen, but is no longer in production.
-AM On Tuesday, February 18, 2014 10:30:49 AM UTC-6, wrote: On Tuesday, February 18, 2014 9:33:54 AM UTC-6, Frank Beythien wrote: Am 18.02.2014 13:59, schrieb Greg Delp: Bill, Your name is familiar as I think I sold you the 310. The unit will have these exact symptoms also if you try to charge using any cord other than the original cord that came with an HP 310 (special HP wiring)or if you don't use the USB OTG pigtail that I provided with the unit. The details are hazy but the 310 looks for one of the USB pins to be grounded to another, if I remember correctly pins 4 and 5, or the unit will not start the charging process. When I bought the unit the owner had just replaced the battery so it is relatively new. He hadn't found this information about the charge process so the battery wouldn't charge. I could plug in the unit for long hours get the light as you describe above and the unit would never turn on or charge. After hours of internet research I was able to find the USB OTG solution and after charging with that pigtail the unit would turn on within a few minutes and then fully charge after several hours. I used the unit for multiple hours for several use/recharge cycles to make sure the battery was ok. Then also did the tests with the extra external battery for extended inflight use. You still need to use the USB OTG pigtail for that backup battery as well or again the 310 wont start the charging process. If you're using the USB OTG pigtail then I'm not sure what else the problem could be. Another problem can be the lid over the battery. There is a tiny switch near the battery, which will be pressed by the properly closed lid and otherwise prevents HP310 operation. CU Frank Bill, I suggest you toss your IPAQ into the hazardous electronics bin at your local dump. After suffering through over 10 years of squinting at that damned thing I recommend getting an Avier, Oudie or ClearNav, whatever you can afford. You'll be glad the battery on the IPAQ died, let it rest in peace. |
KX 155 trouble | doug mcconnell | Products | 1 | October 31st 12 05:41 PM |
KAP 140 trouble | Dan Luke | Owning | 27 | July 12th 07 07:13 PM |
Posting Trouble | Cody Dawg | Piloting | 3 | November 29th 06 08:06 PM |
Tie Down Trouble | Dylan Smith | Piloting | 16 | May 20th 06 09:47 PM |
The Trouble With E-Ballots | WalterM140 | Military Aviation | 0 | June 26th 04 09:46 PM |
