#111
On 23/02/2014 01:35, kirk.stant wrote:
Without any statistics, my scientific wild-ass guess (SWAG) is about 80% nose tow hook on glider and 19% low tow; I'll concede 1% to training just because I know how poorly most glider pilots listen to any training when "safety" is involved... I'd agree with that split. I'd also add that there are no Schweitzer hooks in Oz. That helps a lot. GC Kirk 66 |
#112
Let's say I'm on low tow and fly perpendicular to the "tube" of rotor (aka horizontal circular air flow/ vortex)...
The tug goes abruptly up, the glider goes abruptly down. When the glider pulls down on the tug tail, can it increase the tug AOA and stall the tug wings? |
#113
On 23/02/2014 01:46, Chris Rollings wrote:
I've been aware of the Australian preference for low tow and the reasons for it for over 30 years. My own flight testing and experience lead me to believe that it does not significantly reduce the probability of a kiting accident. Well, Australia's experience shows that it does. I would also say that, having flown in the UK, the Oz rules are sometimes seen there as somewhat wussy - along the lines of "real men don't fly low tow". Chris's irrational vehemence makes me think he may be one of that 'sometimes' group. GC |
#114
For those who consider using a nose hook largely solves the
problem of kiting, I suggest watching http://www.youtube.com/watch?v=4MkCnVYa3VY It is a video of a pilot's second solo flight in a K13 with an aerotow launch using the nose hook. The pilot is distracted when the airbrakes open, he looks out at the airbrakes, closes/locks them and when he looks forward again the tug is disappearing below the nose. The glider pilot releases. This is at 90m agl. The commentary and text (in French) gives some extra insight and analysis. CRIS is the acronym for the French pre-flight checks. I met the tug pilot some months after this incident - he said that it was very fortunate that the glider pilot released so promptly as the towplane was starting to be tipped. It was a big lesson learnt for him personally, not least to keep a hand VERY close to the release. Enlightening and interesting thread... |
#115
On Saturday, February 22, 2014 11:14:30 AM UTC-5, son_of_flubber wrote:
Let's say I'm on low tow and fly perpendicular to the "tube" of rotor (aka horizontal circular air flow/ vortex)... The tug goes abruptly up, the glider goes abruptly down. When the glider pulls down on the tug tail, can it increase the tug AOA and stall the tug wings? No- Our experience is that you can't pull the tail down that much. We have towed at speeds so low in low tow when testing that the glider was adding to the stability of the pair by keeping the tug straight. In any case it is so obvious that the glider pliot will take corrective action. UH |
#116
On 23/02/2014 03:14, son_of_flubber wrote:
Let's say I'm on low tow and fly perpendicular to the "tube" of rotor (aka horizontal circular air flow/ vortex)... The tug goes abruptly up, the glider goes abruptly down. When the glider pulls down on the tug tail, can it increase the tug AOA and stall the tug wings? Maybe. I've never heard of it happening. The tug is also pulling the glider nose up which will make it want to climb and reduce the downward pull. We could place bets on who might win. ![]() The actual answer is that if the tug pilot runs out of forward stick, he has a big handle and a Tost release which reliably solve his problem. GC |
#117
Yes, but that was a fixed hitch. I would think that, as the glider shot
upwards, the hinged release would swivel upward before the tug's nose started down. Is it because the arm aft of the hinge point would be so short? I always preferred mechanical stuff to electrical, but the education was free so I had to take what was offered. "Steve Leonard" wrote in message ... Dan, that might work if the towplane's attitude was constant. However, during a kiting event, the towplane is being pitched nose down, so the hitch would not likely get activated, as the hitch to surrounding structure angle may not change. I wish it could be that simple, but it isn't. See the previous post about a kiting even where the glider was still in sight in the mirror, even though the towplane was significantly nose down. Steve |
#118
Huh! Sounds good to me!
"GC" wrote in message eb.com... On 22/02/2014 16:17, Alan wrote: ...You don't get kiting if you fly normal "high" tow behind the towplane, if you remain in control. If you don't remain in control, starting from low tow is not going to make a lot of difference. Experience (tens of thousands of aerotows) shows there is an enormous difference. The inadequate control and time to go from high tow to kiting is orders of magnitude different from that required to go from low tow to kiting. In fact, I've never heard of that ever happening. Even with low time students. Kiting from high tow, however, is apparently so common as to need a whole new system of electronic whizzbangery and gallons of bandwidth to stop. If the tug has just lifted off, being in low tow sounds a bit difficult, but that would be a particularly hazardous time. Yes. Liftoff is a time to be wary and we train accordingly. Nevertheless, all I can say is that low tow has prevented kiting accidents for many years. But don't take my word for it, keep this ridiculous discussion going with another screwball idea for pivoting, autoswivelling, pitch-sensing, stick-following nonsense. If the issue is serious - as it was in Australia - flying low tow will solve it. If it isn't - see my previous post. GC As for automatic methods to mitigate the problem, perhaps the solution is not to modify tow planes, but to modify gliders. If the glider is in a very high pitch attitude on tow, it might be a good time to automatically release. Another modification might be to attach the tow rope to the top of the glider. This would cause the tow force to pitch the glider down. Is this more of a problem when folks try to tow a slow glider like a 2-33 at high speeds? Alan |
#119
Elevator power.
I may have missed the comment , but has anyone experienced insufficient pitch down authority with full forward stick? Our club had an incident in very rough conditions. A PIK20B , belly hook, flown by a very experienced pilot, was forced to release as a snatch caused an uncontrollable pitchup. CG position not known, but the pilot was not large. I did a calculation ( 30 years ago) to see if this was plausible and indeed, if the CG was is near the aft limit with a PIK 20, the transient pitchup couple in a snatch can probably overpower full nose down elevator, thus initiating kiting. There a re probably many other sailplanes susceptable to this near the aft CG limit. John firth At 14:46 22 February 2014, Chris Rollings wrote: At 14:28 22 February 2014, wrote: On Saturday, February 22, 2014 1:58:28 AM UTC-6, GC wrote: On 22/02/2014 16:17, Alan wrote: =20 =20 =20 ...You don't get kiting if you fly normal "high" tow behind the towplan= e, =20 if you remain in control. =20 =20 If you don't remain in control, starting from low tow is not going t= o =20 make a lot of difference. =20 =20 =20 Experience (tens of thousands of aerotows) shows there is a enormous=20 =20 difference. The inadequate control and time to go from high tow to=20 =20 kiting is orders of magnitude different from that required to g from=20 =20 low tow to kiting. In fact, I've never heard of that eve happening.=20 =20 Even with low time students. Kiting from high tow, however, is=20 =20 apparently so common as to need a whole new system of electronic=20 =20 whizzbangery and gallons of bandwidth to stop. =20 =20 =20 If the tug has just lifted off, being in low tow sounds a bit diffic= ult, =20 but that would be a particularly hazardous time. =20 =20 =20 Yes. Liftoff is a time to be wary and we train accordingly.=20 =20 Nevertheless, all I can say is that low tow has prevented kiting=20 =20 accidents for many years. But don't take my word for it, keep this=20 =20 ridiculous discussion going with another screwball idea fo pivoting,=20 =20 autoswivelling, pitch-sensing, stick-following nonsense. =20 =20 =20 If the issue is serious - as it was in Australia - flying low to will=20 =20 solve it. If it isn't - see my previous post. =20 =20 =20 GC =20 =20 =20 =20 =20 As for automatic methods to mitigate the problem, perhaps the soluti= on =20 is not to modify tow planes, but to modify gliders. If the glider is =20 in a very high pitch attitude on tow, it might be a good time to automa= tically =20 release. =20 =20 Another modification might be to attach the tow rope to the top of t= he glider. =20 This would cause the tow force to pitch the glider down. =20 =20 =20 Is this more of a problem when folks try to tow a slow glider like a= 2-33 at =20 high speeds? =20 =20 Alan =20 GC is making his point for low tows very convincingly - why is he immediate= ly being ripped, Chris? Preparing and steering into low tow at a safe alti= tude, say 300', If you wait 'till 300 feet the majority of the risk of a fatal kitin incident is already behind you, once past 400 feet there is just abou enough height for the tow pilot to recover. means to mentally and then practically pushing the stick fo= rward and then holding in the low tow position. That's the opposite maneuv= er of what's leading to kiting. Drifting upwards takes you into the prop w= ash and again, it takes forward stick pressure to move into the saf spot. = That feedback mechanism is correctly maintaining the intended safe spot wh= ile in the normal tow position only visual cues are being used. I think I'll give the low tow a try, if ever that polar vortex over Chicago= makes like tree... Herb I've been aware of the Australian preference for low tow and the reason for it for over 30 years. My own flight testing and experience lead me t believe that it does not significantly reduce the probability of a kitin accident. |
inReach website not updating track automatically | Eric Greenwell[_4_] | Soaring | 4 | September 23rd 13 09:59 PM |
Compare/Contrast: CG hook on aerotow vs. CG hook on winch | son_of_flubber | Soaring | 37 | June 4th 12 10:40 PM |
TOST E85 RELEASES | [email protected] | Soaring | 2 | March 6th 05 04:21 PM |
Cumulus releases version 1.2.1 | André Somers | Soaring | 0 | March 2nd 05 09:58 PM |
NSA releases EC-121 Liberty tapes: no smoking gun | Mike Weeks | Military Aviation | 0 | July 9th 03 05:06 AM |
