The "offical" LXNAV V7 thread
Old February 23rd 14, 02:04 PM posted to rec.aviation.soaring
Default The "offical" LXNAV V7 thread
On Saturday, February 22, 2014 11:28:10 PM UTC-6, Bastoune wrote:
Help please!
I am unsuccessful at updating my V7 with the latest 3.02 software. (I did successfully upgrade to v2.02 two years ago). I am trying to update with my PNA Vertica V2. Part of the problem is that I am not sure which COM port to select from the PNA V2. Here's the combination of errors that I get:
COM1: "Load" message appears, but the "Discovery" message does not. I then get this error window pop up: "Update failed, error code = -5"
COM2 or COM3: Load message appears, Discovery then starts but after 5 seconds, error window message: "Update failed, error code = -10"
COM 4: Load message appears, Discovery then starts but stays stuck. When I eventually hit "cancel" on the PNA, the error message is: "Update failed, error code = -21" shows up.
Additional info:
- The baud rate is set at 115200 on both the V7 and the PNA (I have been forewarned about using anything else so I always triple check)
- The LXNav "PNA Update tool" and firmware are the latest versions from the LX website
What I am screwing up?
Thanks,
B
Bastoune-
your v2 needs to use COM7 for the PNA update tool to talk to the v7 and that is not available from the pulldown. You will need to bring up a keyboard on your v2 and type in COM7 and I think it will work - at least it does from my Avier.
Mike O.
Old February 23rd 14, 02:48 PM posted to rec.aviation.soaring
Help please!
Additional info:
Thanks,
B
Bastoune-
Mike O.
Has anyone accomplished this update with a MIO? I have my MIO connected to the V7 via the Glider Tools cable but have not attempted a firmware update via this connection.
Lane
Old February 23rd 14, 03:51 PM posted to rec.aviation.soaring
Bastoune
Mike 0! This was the tip that I needed! Switching to COM7 manually did the trick. The installation when smooth as butter after that! Thanks!
Lane - Your MIO will work just fine as long as you select the correct COM port (!). I had used a MIO a year ago to upgrade my V7.
B
Old February 23rd 14, 07:56 PM posted to rec.aviation.soaring
son_of_flubber
What is the difference between V7 and V7D? I did not find an answer on the LXNav website.
Old February 23rd 14, 08:27 PM posted to rec.aviation.soaring
Pete Startup[_2_]
Default The
LXNav website.
V7D is the repeater for a 2 seat glider.
Old February 24th 14, 04:53 AM posted to rec.aviation.soaring
Paul Remde
Hi,
The V7D is the 2nd-seat repeater version of the V7. It is a display without
the vario sensors. It works only when connected to a V7.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
________________________________
"son_of_flubber" wrote in message
LXNav website.
Old February 23rd 14, 10:19 PM posted to rec.aviation.soaring
B
Bastoune,
I assume I put the update utility and update file in the primary file directory? Do I create a folder for them or just place them separately in the the primary file structure? Any chance you remember the correct com? I suppose I can start with the com setting I currently have that is communicating with the V7 from the MIO.
Lane
Old February 24th 14, 02:20 AM posted to rec.aviation.soaring
Bastoune
Lane,
The easiest way is to create a folder in the primary file directory and save all of the files (LNNUpdate.exe, CeLxV.dll, the VINB and VSEV files) in that directory.
Starting with the COM port that you are using to communicate with the V7 is the right approach (and this is where I got off track as my PNA did not show that COM port as an option in the LXNav Update tool)
Good luck! B.
Old February 24th 14, 01:45 PM posted to rec.aviation.soaring
B
Bastoune,
Sent LXNav an email last night suggesting they add COM7 to the pulldown and Uros had a new PNA update tool file on their website by 7:30cst this morning! Now if we can just remember from one update to the next that COM7 is what we need to use!
Mike
Old February 24th 14, 04:16 PM posted to rec.aviation.soaring
Bastoune
This is fantastic. The LXNav team product support and responsiveness is second to none. This is another fine example!
LXNAV V7 - Reviews? David Reitter Soaring 10 October 21st 14 12:41 AM
New LXNAV LX9000 Overview Video Paul Remde Soaring 0 April 21st 12 01:33 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
LXNAV Nano and LX 9000 Overview Videos Available Paul Remde Soaring 3 February 28th 11 01:58 PM
HELP! Need offical Blanik L-13 Canopy Strap John Scott Soaring 4 March 3rd 08 05:03 AM
