On Monday, February 24, 2014 5:15:14 AM UTC-8, ES wrote:
I'm using SeeYou Mobile with an LXNAV V7. Both take polars in the same form: stall speed, A, B, and C coefficients, min (wing) loading, min weight, max weight, empty weight, and pilot weight. I'm also confused about the weights. If "pilot weight" is provided, then I can only assume "empty weight" means just the glider without the stick actuator, but why would the computer care about that? Why not just "dry take-off weight"? Hmmm... Do they have provision for different pilot profiles to fly the glider? |
You could also throw Dick Johnson's polar test data into an Excel spreadsheet and do a curve fit - that might be a good starting point.
Mike |
contest number question | Gary Emerson | Soaring | 22 | February 9th 18 04:15 PM |
SeeYou task leg distance calculation question | Tuno | Soaring | 6 | April 19th 11 10:08 PM |
New Chance for Aviation Enthusiasts | MOD | Piloting | 0 | February 26th 07 05:42 PM |
Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 11:50 AM |
N number question | Chuck | Piloting | 3 | October 23rd 03 07:17 PM |
