On Tuesday, February 25, 2014 8:02:47 AM UTC-5, Andreas Maurer wrote:
Never say never. Two years ago we had a freak accident in Germany where the glider pilot was unable to release during a winch tow. Unfortunately, the winch driver was also unable to cut the winch cable. With incredible skill (and some luck) the glider pilot was able to fly most of a circle tethered to the winch, until finally the winch cable got caught in some bushes and he crashed from only about 30 ft of altitude. ASW-19 badly damaged, pilot fortunately not hurt. This is implausible and frankly unbelievable. I would have thought that a slack Spectra line could be cut with a sharp pocket knife. |
At 15:10 25 February 2014, son_of_flubber wrote:
On Tuesday, February 25, 2014 8:02:47 AM UTC-5, Andreas Maurer wrote: Never say never. Two years ago we had a freak accident in Germany where the glider pilot was unable to release during a winch tow. Unfortunately, the winch driver was also unable to cut the winch cable. With incredible skill (and some luck) the glider pilot was able to fly most of a circle tethered to the winch, until finally the winch cable got caught in some bushes and he crashed from only about 30 ft of altitude. ASW-19 badly damaged, pilot fortunately not hurt. This is implausible and frankly unbelievable. I would have thought that a slack Spectra line could be cut with a sharp pocket knife. It may surprise you to learn that not every one is using synthetic rope. Wire rope is still used in many places today for various reasons. |
Not that this has anything to do with low tow.
Regrettably, your incredulity needs to be stretched some more. Flubber is quite good at that. ;-) There was a similar incident in South Africa a few years ago. Very experienced pilot, high drag trainer, on the second stall he worked out the problem. Wire was fouled on the winch so cutting at the guillotine would make no difference. Pilot executed a steep descending turn laying the cable down on the ground in a wide loop around the winch. Finished by tighetening turn to overfly the winch in a full airbrake steep and slow final. The cable stopped the fun about 10m after touchdown, but there was no damage found on the glider. The "arrestor wire" was effectively lined up behind the glider and broke at the weak link. Couple of lessons, including Use the correct weak link. Use good condition OEM rings Service your release hooks as per the manual Have a working guillotine - and - Use it earlier rather than later (the only thing these folk did not do) And FINALLY - stuff still happens, so have a plan for eventualities. On 2014/02/25 5:10 PM, son_of_flubber wrote: On Tuesday, February 25, 2014 8:02:47 AM UTC-5, Andreas Maurer wrote: Never say never. Two years ago we had a freak accident in Germany where the glider pilot was unable to release during a winch tow. Unfortunately, the winch driver was also unable to cut the winch cable. With incredible skill (and some luck) the glider pilot was able to fly most of a circle tethered to the winch, until finally the winch cable got caught in some bushes and he crashed from only about 30 ft of altitude. ASW-19 badly damaged, pilot fortunately not hurt. This is implausible and frankly unbelievable. I would have thought that a slack Spectra line could be cut with a sharp pocket knife. -- Bruce Greeff T59D #1771 |
For my tow license I had to demonstrate a tow down to the deck all the way
from 1500 feet, while behind tow. 'it'll never happen for real' - some years later I watched a Blanik doing a formation landing after the two rope got tangled around the bungee hook, including the weaklink. No cutter on the towplane. All landed safely in tight formation. |
a slack Spectra line could be cut with a sharp pocket knife. Yet, it is true. Report he http://www.bfu-web.de/DE/Publikation...lication File |
