one more for low tow
Old February 26th 14, 05:05 AM posted to rec.aviation.soaring
BruceGreeff
Default one more for low tow
Not that this has anything to do with low tow.
Regrettably, your incredulity needs to be stretched some more.
Flubber is quite good at that. ;-)
There was a similar incident in South Africa a few years ago.
Very experienced pilot, high drag trainer, on the second stall he worked
out the problem.
Wire was fouled on the winch so cutting at the guillotine would make no
difference.
Pilot executed a steep descending turn laying the cable down on the
ground in a wide loop around the winch.
Finished by tighetening turn to overfly the winch in a full airbrake
steep and slow final.
The cable stopped the fun about 10m after touchdown, but there was no
damage found on the glider. The "arrestor wire" was effectively lined up
behind the glider and broke at the weak link.
Couple of lessons, including
Use the correct weak link.
Use good condition OEM rings
Service your release hooks as per the manual
Have a working guillotine - and - Use it earlier rather than later (the
only thing these folk did not do)
And FINALLY - stuff still happens, so have a plan for eventualities.
On 2014/02/25 5:10 PM, son_of_flubber wrote:
On Tuesday, February 25, 2014 8:02:47 AM UTC-5, Andreas Maurer wrote:
Never say never.
Two years ago we had a freak accident in Germany where the glider
pilot was unable to release during a winch tow.
Unfortunately, the winch driver was also unable to cut the winch
cable.
With incredible skill (and some luck) the glider pilot was able to
fly most of a circle tethered to the winch, until finally the winch
cable got caught in some bushes and he crashed from only about 30 ft
of altitude.
ASW-19 badly damaged, pilot fortunately not hurt.
This is implausible and frankly unbelievable. I would have thought that a slack Spectra line could be cut with a sharp pocket knife.
Bruce Greeff
T59D #1771
Old February 26th 14, 10:27 AM posted to rec.aviation.soaring
Eric Munk
For my tow license I had to demonstrate a tow down to the deck all the way
from 1500 feet, while behind tow.
'it'll never happen for real' - some years later I watched a Blanik doing
a formation landing after the two rope got tangled around the bungee hook,
including the weaklink. No cutter on the towplane. All landed safely in
tight formation.
