Ted,
I may be misunderstanding your question, but I do not think that you can upload a task "to" the V7. You can upload a task to your GPS Logger (e.g. Nano) by going "through" the V7 (See setup example in section 8.4.2 of the manual). The relevant section on how to perform the upload is 5.1.2. In the "Direct Link" mode, the Oudie communicates directly to the Logger. |
Okay, things are starting to make a little more sense. On page 16 (section 5.1.2)there is a turnpoint name ("Line 11") above the course direction indicator. When I saw that, I assumed I there was some task storage and processing in the V7. If the task is not in the V7, where does this turnpoint name come from? (From the Oudie, or from the logger?)
On 02/28/2014 9:28 AM, ES wrote:
Okay, things are starting to make a little more sense. On page 16 (section 5.1.2)there is a turnpoint name ("Line 11") above the course direction indicator. When I saw that, I assumed I there was some task storage and processing in the V7. If the task is not in the V7, where does this turnpoint name come from? (From the Oudie, or from the logger?) The Oudie will have to send the active TP coordinates in an RMB sentence back to the V7. Luke |
On Fri, 28 Feb 2014 09:41:29 -0500, Luke Szczepaniak wrote:
On 02/28/2014 9:28 AM, ES wrote: Okay, things are starting to make a little more sense. On page 16 (section 5.1.2)there is a turnpoint name ("Line 11") above the course direction indicator. When I saw that, I assumed I there was some task storage and processing in the V7. If the task is not in the V7, where does this turnpoint name come from? (From the Oudie, or from the logger?) The Oudie will have to send the active TP coordinates in an RMB sentence back to the V7. It must also be getting at least the WPL sentence and possibly is also getting ROO sentences. I say this because the RMB sentence conveys the TP coordinates but doesn't contain its name. Both ROO and WPL include the TP name. WPL contains the name and coordinates of a TP: by comparing coordinates between RMB and WPL the receiver can work out the RMB's target TP name. ROO defines the task (in our terminology). All it contains is a list of TP names in task declaration sequence. The reception frequency differs depending on the sentence type. An RMC+RMB pair are received every second with a third sentence appended. This sentence is either an ROO or a WPL. The ROO and associated WPLs are sent in a repeating sequence, one each second, so if you have 'n' turnpoints in the active task, the sequence takes n+1 seconds to be sent. I researched this some time ago when I wanted to understand why my SDI C4 wouldn't calculate wind unless the GPS it was attached to, a Garmin GPS II+ at that stage, had at least one active waypoint. I ended up with the Garmin plugged onto a PC and displaying each sentence as it arrived so I could work out what was going on. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
LXNAV V7 - Reviews? | David Reitter | Soaring | 10 | October 21st 14 12:41 AM |
New LXNAV LX9000 Overview Video | Paul Remde | Soaring | 0 | April 21st 12 01:33 AM |
LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 12:31 AM |
LXNAV Nano and LX 9000 Overview Videos Available | Paul Remde | Soaring | 3 | February 28th 11 01:58 PM |
HELP! Need offical Blanik L-13 Canopy Strap | John Scott | Soaring | 4 | March 3rd 08 05:03 AM |
