Oudie2 - V7 - PowerFlarm Core setup (cabling question)
Old March 2nd 14, 08:40 PM posted to rec.aviation.soaring
ES
Default Oudie2 - V7 - PowerFlarm Core setup (cabling question)
Thanks Dave. My glider came wired for Oudie2 - V7 - Nano but without the Nano. When I order the PF Brick I want to make sure that I get everything I need.
Old March 3rd 14, 12:29 AM posted to rec.aviation.soaring
Dave Springford
Happy to help.
All you will need is to replace the Nano cable with the Powerflarm cable.
I recommend getting the V7-GPS-PFCORE cable with the DB9 connector for the Power flarm. This will leave the RJ45 port on the Powerflarm available to connect a Buterfly or Flarmview display.
If you are handy with a soldering iron, you can make you own cable with the pinout above for the V7 end and the details in the PF manual for the PF end.
Powerflarm Brick/Core ADSB Range Sean F (F2) Soaring 3 September 5th 13 03:10 PM
Momentary GPS data dropouts with PowerFLARM to SN10A to Oudie2 setup kirk.stant Soaring 8 May 7th 13 03:06 PM
PowerFLARM core external display software update kirk.stant Soaring 5 January 28th 13 08:56 PM
tailwheel setup question Dick[_1_] Home Built 2 May 20th 08 11:20 AM
Newbie question on trailering Setup joe Soaring 11 December 26th 04 11:10 PM
