Replacing an airspeed indicator
Old March 7th 14, 09:45 PM posted to rec.aviation.soaring
son_of_flubber
Default Replacing an airspeed indicator
Is there any reason to suspect that an ASI (especially a non-TSO'ed one) might be more accurate in the middle of it's range?
Also, to anyone with a combo vario/secondary ASI like LXNAV V7, does the AS indicated on the V7 agree with your primary ASI and if not, which one do you trust? A sanity check on the primary ASI with a secondary instrument seems like such a good idea to me. I mean... when my ASI eventually goes broken, I want to know right away. The redundancy is nice in the meantime, especially if they agree on speed.
Old March 7th 14, 11:03 PM posted to rec.aviation.soaring
K
On Friday, March 7, 2014 2:45:53 PM UTC-7, son_of_flubber wrote:
Also, to anyone with a combo vario/secondary ASI like LXNAV V7, does the AS indicated on the V7 agree with your primary ASI and if not, which one do you trust? .......
Son,
You have to remember that your ASI shows IAS and the V7 shows TAS. Typically these are always different (With a larger difference at higher altitudes and hotter than standard atmosphere). I trust either one but of course you use IAS for things like flap speeds and approach speeds.
Old March 8th 14, 12:30 AM posted to rec.aviation.soaring
Martin Gregorie[_5_]
On this side of the pond the rules say that ASI calibration must be
checked as part of the Annual Inspection and must be within 2kts
throughout its range.
The calibration check applies a known pressure to the pitot inlet and and
records the ASI reading. This is done at 10 kt intervals from the ASI's
highest indicated speed down to 20 kts.
An ASI is a sensitive pressure gauge that happens to be calibrated in kts.
The calibration is independent of the airframe. IOW, if the IAS in flight
shown by a freshly calibrated ASI is not the same as independently
measured TAS then the error is due to the placement of the static vent
and/or the pitot. For example, its well known that pressure under the
wing is above bulk atmospheric pressure, so a static vent anywhere near
the underside of the wing will make the ASI read low. Similarly, a static
vent placed on a convex bulge in the fuselage away from the wing will see
a lower pressure and so will make the ASI read high. That's why the
static vent is commonly halfway along the boom: at that point the boom is
a straight taper and so has minimal curvature in relation to the
slipstream while the vent is placed well away from the flying surfaces.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 10th 14, 01:11 PM posted to rec.aviation.soaring
son_of_flubber
Thank you Martin. Pointing out how the pieces fit together is very helpful..
An annual test of the ASI over the entire range suggests that they have in the past found a few ASI that were not accurate over the entire range and that ASIs might go bad gradually over time. I wonder what those tests find in the field.
(My question may sound like FUD, but I have a habit... people paid me to find defects in their technology.)
Do I have it right that at a given point in time and altitude, the difference between TAS and IAS is constant over the entire range? I'm still figuring out how to use my LXNav V7 to check the calibration of my 15 year old Made in China ASI (and vice-versa, if I find a problem, either one of the devices could be the culprit.)
An ASI is a sensitive pressure gauge that happens to be calibrated in kts..
org |
Old March 10th 14, 01:26 PM posted to rec.aviation.soaring
On Monday, March 10, 2014 9:11:34 AM UTC-4, son_of_flubber wrote:
Thank you Martin. Pointing out how the pieces fit together is very helpful. An annual test of the ASI over the entire range suggests that they have in the past found a few ASI that were not accurate over the entire range and that ASIs might go bad gradually over time. I wonder what those tests find in the field. (My question may sound like FUD, but I have a habit... people paid me to find defects in their technology.) Do I have it right that at a given point in time and altitude, the difference between TAS and IAS is constant over the entire range? I'm still figuring out how to use my LXNav V7 to check the calibration of my 15 year old Made in China ASI (and vice-versa, if I find a problem, either one of the devices could be the culprit.) On Friday, March 7, 2014 7:30:41 PM UTC-5, Martin Gregorie wrote: On Fri, 07 Mar 2014 13:45:53 -0800, son_of_flubber wrote: Is there any reason to suspect that an ASI (especially a non-TSO'ed one) might be more accurate in the middle of it's range? On this side of the pond the rules say that ASI calibration must be checked as part of the Annual Inspection and must be within 2kts throughout its range. The calibration check applies a known pressure to the pitot inlet and and records the ASI reading. This is done at 10 kt intervals from the ASI's highest indicated speed down to 20 kts. An ASI is a sensitive pressure gauge that happens to be calibrated in kts. The calibration is independent of the airframe. IOW, if the IAS in flight shown by a freshly calibrated ASI is not the same as independently measured TAS then the error is due to the placement of the static vent and/or the pitot. For example, its well known that pressure under the wing is above bulk atmospheric pressure, so a static vent anywhere near the underside of the wing will make the ASI read low. Similarly, a static vent placed on a convex bulge in the fuselage away from the wing will see a lower pressure and so will make the ASI read high. That's why the static vent is commonly halfway along the boom: at that point the boom is a straight taper and so has minimal curvature in relation to the slipstream while the vent is placed well away from the flying surfaces. -- martin@ | Martin Gregorie gregorie. | Essex, UK org |
Use of a simply made manometer should clarify the delemna of comparing 2 instruments, both of which have unlnown accuarcy.
UH
Old March 10th 14, 10:05 PM posted to rec.aviation.soaring
UH
Yep, my club uses a water-filled manometer with the vertical tube being
cut from a roll of soft plastic tube - most likely its the same tubing
you'd use to connect the ASI to static and pitot.
org |
Old March 10th 14, 01:49 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
This is true only at sea level, standard day conditions in the airspeed range we are interested in. At 5000 feet, IAS and TAS are NOT the same.
Disagree with this. Look at the airspeed corrections on a Schempp-Hirth sailplane using the underwing statics. The Ventus A that Dick Johnson tested is a good example. Goes from reading 4 knots too slow at low speed to 10 knots to fast at high speed.
If you are curioius about the calibration of your indicator, the following should be of interest to you:
http://www.rst-engr.com/rst/articles/KP89JUL.pdf
Steve Leonard
Old March 10th 14, 10:13 PM posted to rec.aviation.soaring
same
Yeah. Treat that as a rather bad short-hand. A fully qualified
explanation would be quite long by the time you factor in the different
IAS errors on a different type of glider flying with the one that's
trying to check his ASI. Most people don't own the same sort of trailing
bomb device that Dick Johnson used.
The general effect of the wing is like I said, but it can obviously be
affected by factors specific to some airframes such as turbulence round
the root or kicked off by the nose shape. Most gliders have, at best,
quite rudimentary root fairings. I imagine Will Schueman would be quite
unimpressed if he saw them.
org |
Old March 10th 14, 04:31 PM posted to rec.aviation.soaring
Soartech
Thank you Martin for this answer.
That is what I needed to know.
Looking for a used 57 mm airspeed indicator Scott Alexander[_2_] Soaring 0 October 13th 12 07:28 PM
Airspeed Indicator Strangeness Frank[_1_] Soaring 6 June 9th 08 01:24 PM
Airspeed Indicator problems [email protected] Soaring 6 June 19th 07 02:33 AM
verifying airspeed indicator Heino & Deanne Weisberg Home Built 11 October 22nd 05 07:36 PM
Need glider airspeed indicator [email protected] Soaring 1 June 21st 05 09:57 PM
