On Mon, 10 Mar 2014 06:26:26 -0700, unclhank wrote:
Use of a simply made manometer should clarify the delemna of comparing 2 instruments, both of which have unlnown accuarcy. UH Yep, my club uses a water-filled manometer with the vertical tube being cut from a roll of soft plastic tube - most likely its the same tubing you'd use to connect the ASI to static and pitot. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Looking for a used 57 mm airspeed indicator | Scott Alexander[_2_] | Soaring | 0 | October 13th 12 07:28 PM |
Airspeed Indicator Strangeness | Frank[_1_] | Soaring | 6 | June 9th 08 01:24 PM |
Airspeed Indicator problems | [email protected] | Soaring | 6 | June 19th 07 02:33 AM |
verifying airspeed indicator | Heino & Deanne Weisberg | Home Built | 11 | October 22nd 05 07:36 PM |
Need glider airspeed indicator | [email protected] | Soaring | 1 | June 21st 05 09:57 PM |
