X-43A successful flight
Old April 7th 04, 02:11 AM
Tarver Engineering
"Mike Kanze" wrote in message
Let us agree that I know where the F/A-18 stick breaks out at (20#) and
that you and monkey are clueless.
Once again, the Tarverbot shows his OWN cluelessness.
Not me. It is unsafe for the operator to not know that the stick breaks out
to activate the mechanical backup. There is no guarantee the failure of the
electric controls will cause the force transducer to deactivate. Once agian
a pilot is so ignorant as to believe they know more about how an airplane
works than a systems engineer for that airplane.
How many F-18 hours a year in the air are you and monkey getting Woody? 50?
20?
Old April 7th 04, 03:52 AM
Chad Irby
"Doug \"Woody\" and Erin Beal" wrote:
Look, Tarver, I've accumulated enough hours in the Hornet to have more than
a clue about its systems and how to employ them than you do.
Don't try to confuse him with the facts. He's confused enough without
them
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old April 6th 04, 10:26 AM
José Herculano
than
Woody, the Tarver-dude is reasoning-proof. In ancient Greece he'd be a
sophist without a following. Plonk him ;-)
_____________
José Herculano
Old April 7th 04, 04:52 PM
Mary Shafer
On Wed, 07 Apr 2004 02:22:48 GMT, "Doug \"Woody\" and Erin Beal"
There is no difference in stick forces or "break out" as you're calling it
between CAS, DEL, or MECH modes. Perhaps you're talking about the feedback
force that is added when the stick is displaced from its neutral position?
That is certainly not a "break out."
That is, too. That's the definition of break out force, the force you
have to overcome to leave the deadband.
What do you think break out force is?
Don't get me started on stick force shaping, as I spent some serious
flight time and money looking at a variety of schedules for pilot
cueing. I can probably tell you more than you want to know about how
pilots perceive the cues, although the most interesting part is how
they can fail to consciously notice a major cue, even when it affects
their technique.
20?
Per year? Absolutely ZERO in MECH, more than 150 or so in CAS, less than 1
in DEL (spin recovery mode).
Keep it that way. The Plastic Bug flies miserably in MECH. It was a
big deal when they finally trapped in MECH, in fact. Before that, it
had meant diverting to land. When Tom McMurtry had to land one of
ours in MECH he cheerfully declared it to be one of the worse control
modes he'd ever flown, not counting those he'd flown for me when we
were doing the PIO work.
I thought DEL was a reversionary mode for more than spin recovery,
though. Doesn't the Bug drop into DEL when the MC faults? It's the
spin recovery mode that overrides the surface limits for spin recovery
when the yaw rate goes over some limit (40 deg/sec, maybe?), isn't it?
Mary
Mary Shafer Retired aerospace research engineer
Old April 8th 04, 01:49 AM
Doug \Woody\ and Erin Beal
On 4/7/04 10:52 AM, in article ,
The way he seems to be describing it there is an additional force imparted
beyond the normal feedback when the stick is displaced from neutral. Of
course, I've got no formal training in TPS terms, so perhaps I
misunderstand.
This discussion is going round and round, but my point is... that the stick
forces do not change whether in CAS, MECH or DEL--i.e. any "break out" force
in the cockpit is incidental to what the pilot normally experiences when
pulling on the pole.
their technique.
I wouldn't dare even attempt to discuss it with you, Mary unless I were in
receive only mode. |:-)
20?
That's what I've heard. I had no idea that a trap in MECH had actually
occurred. It must have been MECH in one axis only. Eh? Sea story?
Mary
It is. You are correct that's DEL, but the only time *I'VE* ever
experienced flying in DEL is when I do Spin Recovery Mode (SRM) checks on
FCF's (only on the A profiles now).
The way I had it explained to me years ago (by some dude at China Lake) is
that SRM is a subset of the DEL mode (with the LEF's at 33-34 degrees and
the TEF's at 0 +/- 1 degree). The nose gets a bit "slicy" coming out of 30K
in with SRM engaged, and the AOA must be kept between 10-20 degrees
(although I know from personal experience that the jet won't explode if you
fall outside of that limit for transitory periods).
It's kind of a squirrelly deal to fly in. Nauga, where are you?
--Woody
Old April 8th 04, 06:17 AM
Mary Shafer
On Thu, 08 Apr 2004 00:49:00 GMT, "Doug \"Woody\" and Erin Beal"
I thought the feel system changed in the spin recovery mode, with more
surface deflection per inch of stick displacement, but there's a good
chance that was either a non-standard F-18 or some other airplane. I
mean, I could have been thinking of the F-16 deep stall recovery mode,
you know.
their technique.
Did you know, for example, that you have a different tolerance for
time delay in the feel system than you do for time delay in the flight
control system? If asked, you probably don't even know you can tell
the difference, but you can.
I honestly don't know if it was one axis or more. It's not a sea
story, because we got the notification from the class desk (or
whatever they call it). You know the thing I mean, the telex to all
F/A-18 squadrons and Dryden, with time-critical information.
I think this is all exactly right, except that my crummy memory for
numbers means I can't say about them. I don't think you can get the
jet to explode on transient excursions outside the limit, although I
know that no one should ever underestimate the fleet pilots, but you
can get it to depart again if you botch the recovery (usually by being
a little too enthusiastic too soon). If you do it just right, you can
get it to depart into a worse mode, like oscillatory instead of flat.
I'll give you my standard stall-departure-spin warning, which I give
to every fighter pilot and test pilot I know. Be careful if you're
flying a two-seat version with a centerline tank. It will depart and
spin much more easily than a single-seat jet or a clean jet. You're
not guaranteed to depart and spin, of course, but you're at greater
risk. It also probably won't recover as well or as quickly and it may
have more spin modes.
I used to have a couple of plots that really made this point clear,
but I left them with one of the flying qualities engineers when I
retired. I wasn't sure if all the data was generally available.
They're all squirrelly in stall-departure-spin. Maybe it's because
it's all forebody flow so there's a lot of moment arm or something.
The F-16 deep stall procedure is odd, to say the least, because you
get out of the stall by pulling up the nose and increasing the stall
angle before you push over and "rock" the airplane out of the stall.
Yo, Nauga, over here!
Mary
Old April 8th 04, 12:10 PM
On 4/8/04 12:17 AM, in article ,
you know.
It may, but I wouldn't know because I never move the stick more than about
1/2 an inch in that mode. I sort of doubt it though because pulling the
stick back or cycling it in a cold/dead airplane feels (force wise) exactly
the same as moving it around in a live running airplane.
I should explain here that the only time I've USED SRM is when I'm doing an
FCF A. The SRM check starts at 30K and 200 KCAS. Basically, turn the SRM
switch to RCVY, and hold the stick back. Then the aircraft hits the correct
numbers (which embarrassingly escape me right now... Circa 150 KCAS), SRM
actually engages. You basically hold 10-20 alpha for the rest of the
recovery while accelerating through 250 so that SRM will auto-disengage.
Basically, we're just diving in SRM in level flight and checking that it
engages and disengages when it's supposed to.
We used to do these checks on C and A FCF's. Now just on A's.
SNIP
Ow.
SNIP
The explode thing was a poor attempt at humor.
Concur with the two-seater/single C/L.
Departing I have done (single-seat)... Twice. Once was fairly eye-opening.
460KCAS (probably much slower 350 or less when it stopped flying) at 15000
feet with a full load of back stick and a full boot of top rudder--a real
ham-fist piece of work. The airplane recovered after disappearing into its
own cotton-ball and some real bang-me-up PSG's. I felt pretty sheepish.
Jet was just fine. The immediate action procedures (basically let go and
wait) worked like a champ.
Weird. Do those guys still do that with the 25 alpha limiter installed?
If he's lurking, this is usually the point where he shows up.
--Woody
Mary
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
100 years of flight - Special coverage by The Cincinnati Enquirer Garrison Hilliard Military Aviation 1 March 14th 04 02:42 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 07:47 AM
