F15E's trounced by Eurofighters
Old April 7th 04, 10:24 AM
Guy Alcala
Evan has apparently declined my offer to analyse Moro's claim below for
accuracy (to absolutely no one's surprise), so to amuse myself I'll do so, to
show just how easy it is to disprove it, based on the technical minutiae that
Evan apparently finds so difficult to deal with.
For those who don't have access to Moro, here's his account of the Dagger
attack on June 8th, verbatim. My notes and interjections are in square
brackets, although I have resisted the temptation to make comments about
Moro's overly dramatic (for what purports to be a history) prose:
"The Mystery of the Frigate Plymouth.
"Just after all hell had broken loose in the wake of the A4-B [Sic. A-4B]
blitz [on Sir Tristram and Galahad at Port Pleasant], two formations of
Mirage-Vs Daggers, code-named Perro (Dog) and Gato (Cat), screamed in over
Pleasant Bay [False; they were over Falkland Sound, ca. 50 miles to the NW],
bristling with 500-pound bombs [some of the mission pilots agree, others say
1,000 lbers], gunners' trigger fingers at the ready on 30mm cannon. They bore
in from the west, and as they came in, they spotted a frigate in the inlet
that was going to great lengths to conceal its presence. But it proved to be
too late. The planes hugged the elevations around Pleasant Peninsula [False:
see above], then lunged for the prey, coming in at 30 deg. on both the bow and
the port side. Again bombs fell and cannons blazed as they made their attack
run over the hapless vessel, whose gunners cut loose with everything they had
in a vain attempt to drop their tormentors from the skies. The attackers
returned to base without a single loss [True]. Where had the British CAPs
been at the moment of truth? Something was strangely amiss with the Sea
Harriers [This inference is part of Moro's claim that both Hermes and
Invincible had been hit and damaged by AAF bombs/CANA Exocets, for which the
evidence Moro uses is even more tenuous than for this case].
"The wounded frigate turned and, making slow headway (three knots), left the
bay on an easterly heading. Apparently, four of the eight bombs hit the
ship's structure [True]. Initial reports from Great Britain indicated that
none of them detonated, but later reports from the same sources told a
different tale [False. None detonated, although one set off a depth charge].
"At the same time, the armed forces' operations electronic center [in Stanley]
picked up a source of infrared radiation, similar to that given off by a
vessel afire, in the Falkland Sound area [Sure, they did! See end of post].
There was no logical explanation for this, since there had been no Argentine
attacks in that area [False]. Then, unexpectedly [only to Moro], Hastings and
Jenkins revealed in late 1983 that the Rothesay class frigate Plymouth had
been attacked by Argentine aircraft (Mirage-V and A4-B) at the exact point
where radiation had been detected in Falkland Sound. A later publication
[also 1983 according to my copy] (Ethel [Sic.] and Price) re-states the
Plymouth's position at the same location.
"What really happened? British officials seemed to waffle in the days
immediately following the June 8 attack. Argentine analysts could be certain
only of the events reported by their own men: that a Class [Sic. Type] 12
frigate had sustained an attack in Pleasant Bay by air-launched 500-pound
bombs. This was confirmed by aerial photographs [he is presumably referring
to gun camera film from the Daggers rather than post-strike recon photos, as
no such missions were flown to the area]. Data provided on the attack against
the frigate [presumably the one supposedly attacked in Pleasant Bay] report
serious damage [overstates the case] by the bombs from the Mirage-Vs which had
not been revealed by the infrared radiation, thus agreeing with the original
British report [of the attack on HMS Plymouth in Falkland Sound] that the
bombs had failed to detonate."
"The process of deduction has enabled the following events to be surmised
[here's where he really steps off the edge into fantasy based on wishful
thinking]:
1. The frigate targeted by the Daggers in Pleasant Bay was similar to the
Plymouth. One of the Argentine pilots saw the Marks F-16 during the attack,
indicating that the frigate would be the HMS Diomede (similar to the Plymouth)
[we'll be back to this].
2. The Plymouth may have fallen victim to a mistaken attack by a Harrier
squadron flying cover against Argentine troops at Port Howard, under adverse
weather conditions and poor visibility [nice of him to admit that those were
the conditions].
"The Royal Navy has sought to explain the events by attributing to Argentine
Flyers 'an understandable navigational error,' which is not borne out
becauseof the distances involved and the pinpoint precision of the Mirage-V's
navigation system."
I then summarized these claims and asked Evan to analyse them, as follows:
You have Moro, and from
references you've made to it, you apparently also have "Air War South
Atlantic." Using those two sources plus any others you wish (you'll
want to use a good naval reference like Jane's, Conway's etc. for the
era), why don't you analyse for us Moro's claim that:
1. The Dagger attack on June 8th hit a frigate other than HMS Plymouth
(Moro suggests HMS Diomede, owing to a pilot's claim that he saw "F
16" on the ship),
2. That said frigate was off Port Pleasant rather than in Falkland
Sound when attacked,
3. That Plymouth, which he agrees was in Falkland Sound, must have
been hit by a British air attack,
4. And that IR emissions from said frigate were detected from the
Argentine Ops Center (presumably in Port Stanley)?
Okay, how long does it take to determine, using only the three sources I
mentioned above and which Moro certainly had available to him, whether his
claims are valid? Not counting the time to retrieve the books from the shelf,
library or what have you, I estimate between 30 seconds and one minute. Let's
start with the simplest part first - Moro agrees that Plymouth was attacked
while in Falkland Sound, indeed she was only a little way outside San Carlos
Water on her way to an NGS mission of West Falkland when she was attacked.
Numerous photos of her show her burning as she retreats back into San Carlos
Water, so her position is agreed by all sides.
Moro claims that the Daggers were absolutely sure of their position and
attacked a frigate in Pleasant Bay, and no Argentine attack, by Daggers or any
other a/c, was made on a ship in Falkland Sound that day. Further, he claims
that the ship attacked was a "Class 12" frigate, and that one of the pilots
saw "F-16" on the ship, indicating it was HMS Diomede. Let's ignore the
information (which Moro had available to him in "Falklands: The Air War") that
Diomede didn't deploy to the South Atlantic until well after the war was over;
for the sake of argument we'll assume that British claims to that effect are
all part of the big cover-up Moro charges the Brits with.
So, what proof do with have from the Argentine side as to what ship was
attacked by the Daggers that day? Their gunsight camera film, of course,
which Moro cites as proof. Fortunately for us, still frames of that film have
been widely released by the AAF and published in numerous sources, including
one photo in "Air War South Atlantic". And here's where Moro's claim falls
completely apart. The frigate in the Dagger gunsights is very clearly a
Rothesay class, of which only two were with the task force at the time,
Plymouth and Yarmouth.
Even assuming HMS Diomede was in the South Atlantic at the time, it can't be
her, because Diomede was a broad-beam Leander. The difference between the two
classes is instantly recognizable from the beam, which is the angle all the
attacks were made, as shown by the gun camera film. The photo in "AWSA" is
cropped so only the section of the ship from the turret aft to the funnel is
visible, but that's more than enough. Rothesay class ships have the funnel
just aft of the mast and raked slightly aft, the two forming a noticeable V at
the base. Leanders have the funnel well aft of the mast (guesstimating 30-50
feet), and the funnel is vertical not raked. In the gun camera photos, the
funnel and mast are together, and the latter is raked. In gun camera photos
available in other sources the other recognition features are plainly visible
- Rothesays have the weather deck stepped-down aft of the Limbo mortar, while
in Leanders the deck continues level all the way to the stern. Unmodified
broad-beam Leanders like Diomede have a mainmast aft mounting a Type 965
radar; Rothesays lack both mast (well, they have a sort of stump) and radar.
The ship in the photos has a stepped down weather deck, and no mainmast or
Type 965. In other words, the Dagger gunsight photos are conclusive as to the
ship type they attacked, and it was a Rothesay, not a Leander like Diomede.
Unless, of course, Moro wants to contend that his own side was participating
with the British in the great conspiracy to cover up British losses ;-)
What about the "F-16" one of the pilots believed he saw? British frigates and
destroyers had painted out their hull-side pennant numbers during the war (HMS
Yarmouth seems to have been an exception, as her port-side pennant number
"F101" is visible in photos taken while she was alongside the sinking HMS
Ardent), apparently leaving their pennant numbers only on the counter. As an
aside, the AAF released gun camera film of the Dagger attack on Broadsword on
21 May, where they apparently 'added' a pennant number, F08, to the picture.
Unfortunately for Argentine credibility, that number had last been used in the
1960s by HMS Urania; Broadsword's own pennant number was F88. Of course, the
Brits _could_ have painted a false pennant number on her themselves, but
normal practice was to just paint them out entirely, and besides, she could be
identified from her sister Brilliant by the difference in her funnel, number
or no number. This was definitely a case where they should have left well
enough alone.
Getting back on track, we know the ship wasn't Diomede (or any other Leander),
so how could the pilot have thought he saw "F-16"? I'll point out that the
attacks were made at speeds between 550-575 knots, at an angle to the ship,
the pilots were being shot at, and the ship was making quite a lot of smoke,
not exactly conditions conducive to reading a number accurately. And yet, the
pilot did a pretty good job -- HMS Plymouth's pennant number was F126, and the
photo of her at anchor in San Carlos Water shortly after the attack appears to
show that the '2' has been somewhat worn away. It's a bit hard to say for
sure because funnel smoke and possibly smoke from the fire is drifting across
the stern, making the number hard to see at all, at least in the print in the
book.
Finally, getting back to the "big coverup" theory of Moro, couldn't it be that
there were more Rothesays in the theater during the war than the Brits
admitted, and it was one of _those_ which was attacked in Port Pleasant? A
reasonable question, except for the gun camera photos and the numerous photos
taken of the damage to HMS Plymouth, immediately after the attack. In every
still frame I've seen of the attack on Plymouth, including the one reprinted
in "AWSA", a hole can be seen in the after end of the funnel about half way
up, made by one of the bombs (which passed through without exploding) of the
first Dagger to attack. So, we know that whichever Rothesay they attacked, it
will have that entrance hole in the funnel, and also show signs of the bomb's
exit on the other side. AWSA has three photos related to the attack; the gun
camera still mentioned above, and two photos showing the damage to Plymouth
immediately after she'd anchored in San Carlos Water shortly after the attack,
both of which, including a closeup of the funnel, show the hole in the funnel
and the damage made by the bomb's exit.
But maybe the ship was hit in Port Pleasant, then steamed around to San Carlos
Water? At the 3 knots that Moro claims, that would be quite a feat to get
there in daylight, as it's well over 90nm by sea -- even at 28 knots they
couldn't make it given the time the attack occurred. In short, the total time
needed to analyse and disprove Moro's claim, based primarily on evidence from
_his own side_ along with other sources he used, was considerably less than
the time it took you to read the above. And that ignores Commodore Clapp's
account (which hadn't been published when Moro wrote his book) that no frigate
was anywhere near Port Pleasant at the time, because Clapp didn't feel they
could add anything to the defense beyond a couple of 20 or 40mm guns, owing to
the short warning time and surrounding terrain that would prevent radar-guided
weapons from working; it would just be another target. Clapp also said that
he'd tasked Plymouth with a NGS mission against a target in West Falkland,
that he'd wanted her to stay inside the headlands of the entrance to SCW to
keep her inside the AA defenses, but her Captain had decided he preferred a
firing position outside it.
There are numerous other sources which Moro failed to use or didn't have
access to at the time, which just pile proof on proof as to the British
version of events rather than Moro's being the correct one. For instance,
what about Moro's claim that the Daggers couldn't have been in Falkland Sound,
owing to the pinpoint precision of their navigation system? While some French
built Mirage 5s had INS or Doppler nav systems, the Israeli-built Daggers
don't seem to have had anything like that at the time. Here's Salvador Mafe'
Huertas, who interviewed several Grupo 6 pilots, describing their fit at the
time of the war in "Dassault Mirage III/V":
"The equipment was fairly basic, with VOR, DME, ILS and an Israeli-developed
RWR . . . At the beginning of 1982, the FAA [Fuerza Aerea Argentina; I've used
AAF for them to avoid confusion with the British FAA] was working with the
Israelis on a plan to update and modernize its Daggers, but the whole scheme
was brought to an abrupt halt by the Argentine occupation of a little-known
group of islands in the South Atlantic."
This upgrade did eventually come about, known as the "Finger" program,
completed in several stages finishing up with Finger IIIB. It included an
INS. So it appears that the Daggers lacked "pin-point" navigation capability
at the time; even the best INS at the time would drift ca. 1 mile/hr, not
enough to put them in Falkland Sound instead of ca. 50 miles away in Port
Pleasant, but "pin-point" only in relative terms. VOR/TACAN is line of sight,
so that's out of the question on the deck even if they hadn't been well out of
range. Further indication of their lack of onboard navigation systems, if
that were needed, is provided by the following account of the mission in Mafe'
Huertas, describing the lead up to the attack:
"The five remaining a/c [one Dagger had suffered a bird-strike just after
take-off] were joined by Learjet TC-23 [Sic. T-23. Trasnports that were
primarily used or modified for cargo hauling added the 'C' after the 'T' --
the Lears were just plain 'T', as contemporary photos show] of Grupo 1 de
Aerofotografico, which would act as pathfinder, _using its state of the art
navigation system [Omega and INS] to guide the formation towards the
south-west coast of West Falkland_ [my emphasis]. From there, the Daggers
would establish a northwest heading towards Falkland Sound, intending later to
turn east, crossing southern east Falkland to make the attack from the west.
The weather began to deteriorate, and in order to avoid the worst of the low
cloud, rain and snow squalls, the formation deviated slightly from from the
planned route. Crossing Falkland Sound on their north-easterly heading they
were amazed to find the Type 12 frigate [actually Rothesay class, but they
were slightly modified Type 12s, the Whitby class], HMS Plymouth (F 126)."
Surprise having been lost for an attack in Port Pleasant, they decided to
attack her instead. Finally, we come to Moro's most ludicrous claim of all
regarding this incident:
vessel afire, in the Falkland Sound area."
I wrote in an earlier post that this one could be argued (more accurately,
debunked) based on basic physical phenomena. I leave it to the rest of you to
evaluate the likelihood of some kind of IR sensor being able to detect a ship
on fire, when the detector is located at least 50nm away from the supposed
fire, with no direct line of sight to it (lots of several hundred foot high
hills in the way), and the weather is low cloud, rain and snow squalls, i.e.
lots of moisture in the air to absorb IR radiation and reduce the range to
near zero.
So, if any of you are tempted to read Ruben Moro's "The History of the South
Atlantic Conflict," you're now aware of the effort Moro put in establishing
the 'truth' of his more unlikely claims. Objective history, it ain't, but it
does serve to illustrate the mindset of nationalist partisans like Moro. He
reminds me of Venik, Mikhael Petukhov, et al., but at least Moro was an actual
participant in the war (he was a Lt. Col. at the time flying C-130s, possibly
including some missions into Stanley).
Guy
Old April 8th 04, 09:35 PM
Lee Hutchinsom
I don't know if its heplfull but a Workmate of mine served aboard HMS
Plymouth during the conflict and has in the past related to me this tale of
when they were attacked by the daggers, the bomb hits and the depth charge
being triggered - i guess something like this would tend to stick in your
memory!!
He also said something about them bringing down an A4. There is A4 wreckage
in the museum that the Plymouth now is.
I'll have to give him a call and see if he can give me a few more details
BTW HMS Plymouth is now part of the Historic Warships Collection in
Birkenhead UK along with HMS Onyx, a Diesel Sub that also took part in the
conflict.
Lee Hutch
"Guy Alcala" wrote in message
to
that
NW],
say
bore
be
[False:
and
attack
had
that
charge].
Stanley]
post].
Argentine
and
certain
referring
as
against
report
had
original
thinking]:
attack,
Plymouth)
adverse
were
the conditions].
Argentine
Mirage-V's
navigation system."
16" on the ship),
shelf,
Let's
attacked
Carlos
Carlos
any
claims
pilots
that
over;
are
have
including
falls
be
two
is
is
funnel
V at
30-50
photos
visible
while
radar.
Diomede.
participating
and
(HMS
As an
on
picture.
could be
number
enough alone.
Leander),
ship,
smoke,
appears to
across
book.
that
A
photos
every
reprinted
way
attacked, it
bomb's
gun
Plymouth
attack,
funnel
Carlos
time
from
than
Clapp's
frigate
they
owing to
radar-guided
that
to
a
Sound,
French
Mafe'
Israeli-developed
used
scheme
little-known
capability
sight,
out of
Mafe'
'T' --
art
later to
west.
low
they
all
Stanley]
you to
ship
high
i.e.
near zero.
South
establishing
it
He
actual
possibly
Guy
Old April 9th 04, 01:28 AM
Evan Brennan
Guy Alcala wrote in message ...
[remaining drivel snipped]
By now, everyone who reads your posts must realize that it bothers you
to no end that your beloved Harrier shot down just two missile-armed
jets during the Falklands War...that their opponents had no reserve
fuel to dogfight even if they had carried missiles...that British
attempts to neutralize the airstrip at Port Stanley were, and still
are, worthy of criticism from their opponents and everyone else. Your
attempt to dismiss the substantial overclaiming of Argentine aircraft
by the British was also yawn-inducing, but not surprising.
Apparently all of this is a bitter pill for you to swallow, because
you make continous efforts to distract our attention from it with
longwinded posts of "technical minutiae", interspersed with petty
attempts to dicredit Ruben Moro, whilst propping up your hero -- the
self-righteous windbag Sharkey Ward -- who is arguably less honest
than Moro.
Basically, you are an expert at talking a lot but saying nothing.
Evidently, you have a tremendous surplus of free time not available to
the rest of us.
Old April 9th 04, 11:53 PM
Guy Alcala
than Moro.
the rest of us.
Oh, dear, Evan. I seem to have hit a nerve.
Guy
Old April 10th 04, 10:00 AM
Presidente Alcazar
On Fri, 09 Apr 2004 22:53:55 GMT, Guy Alcala
Don't stop now - I'm waiting for Evan to conclude that the Argentines
really did sink Invincible. He provides hours of hysterical
entertainment at minimal cost. All you have to do is provide the
right Pavlovian trigger and he goes off like an Energiser bunny. I
suspect a bitter experience at the hands of a lover dumping him for a
Brit at some point in his early life.
Gavin Bailey
Now see message: "Boot sector corrupt. System halted. All data lost."
Spend thousands of dollar on top grade windows system. Result better
than expected. What your problem? - Bart Kwan En
Old April 10th 04, 11:19 AM
Drewe Manton
Presidente Alcazar wrote in
You aren't kidding! I've actually taken him out of my killfile just so I
can get both sides as Mr Alcala takes him apart bit by bit by bit with
the technical minutae Brennan appears to think so important right up to
the point where it destroys his argument (basically every time). I
actually had to check my history books at one point after reading a
Brennan post just to check that Britain did actually win that war! Still,
this thread appears to be dying now, so I suppose it'll be back into the
killfile with him shortly. . .
Regards
Drewe
"Better the pride that resides
In a citizen of the world
Than the pride that divides
When a colourful rag is unfurled"
Old April 11th 04, 03:33 AM
Guy alcala
Presidente Alcazar wrote in message . ..
Much as I've enjoyed giving Evan the public spanking he apparently
thrives on, I think I'll give it a rest. My hand is getting tired,
and besides, there's so little challenge involved. It's rather too
much like shotgunning rabbits while they're staked out spread-eagle on
the ground - it's just too easy for anyone not an entrant in the
"Upper Class Twit of the Year" competition.
But I'm sure that, in another thread or another forum, others will be
willing to take up the gauntlet, and oblige Evan with the public
humiliation he craves. Judging by his last post here he's reached
levels of evasion, mendacity and belief that (all evidence to the
contrary notwithstanding) the truth is whatever he says it is. This
leads me to suspect that he has a new role model. If so, I must
congratulate him for his success in emulating John Tarver, a
(fortunately) rare achievement.
Guy
Question about the Eurofighter's air intakes. Urban Fredriksson Military Aviation 0 January 30th 04 04:18 PM
China to buy Eurofighters? phil hunt Military Aviation 90 December 29th 03 05:16 PM
Malaysian MiG-29s got trounced by RN Sea Harrier F/A2s in Exercise Flying Fish KDR Military Aviation 29 October 7th 03 06:30 PM
Impact of Eurofighters in the Middle East Quant Military Aviation 164 October 4th 03 04:33 PM
