Op zondag 13 april 2014 20:05:26 UTC+2 schreef Auxvache:
Went to update to the latest version of PF--3.40--and one item in the release note made me hesitate: With this update Flarm hopes to reduce the numerous nuisance "dangerous traffic warnings" (DTW). A nuisance DTW could be described as a warning with red beeping Flarm V3 display or DTW on Butterfly while the traffic that is causing this warning is still at a safe distance. See photo of such a situation on https://dl.dropboxusercontent.com/u/...ic-warning.jpg At that time I was climbing in a thermal and the gilder that caused this waring (equipped with transponder with ADS-B out) was flying past me at a distance of 1200 meters. In Europe a lot of gliders are flying around with mode-s transponders with ADS-B out. PowerFlarm does not treat the ADS-B signal in the same way as the Flarm signal for a number of reasons. I have been flying with PowerFlarm for almost a year now and have seen many many nuisance DTW's caused by gliders that have transponders with ADS-B out. In the mean time I have delivered diagnostic data to Flarm that enables them to improve the firmware and hopefully reduce the number of nuisance DTW's I certainly hope that Flarm is able to solve this problem soon, because nuisance warnings are also dangerous. I you get used to so much warnings you might not react to a real DTW. |
On Tuesday, April 15, 2014 6:51:16 AM UTC-4, RuudH wrote:
Op zondag 13 april 2014 20:05:26 UTC+2 schreef Auxvache: Went to update to the latest version of PF--3.40--and one item in the release note made me hesitate: With this update Flarm hopes to reduce the numerous nuisance "dangerous traffic warnings" (DTW). A nuisance DTW could be described as a warning with red beeping Flarm V3 display or DTW on Butterfly while the traffic that is causing this warning is still at a safe distance. See photo of such a situation on https://dl.dropboxusercontent.com/u/...ic-warning.jpg At that time I was climbing in a thermal and the gilder that caused this waring (equipped with transponder with ADS-B out) was flying past me at a distance of 1200 meters. In Europe a lot of gliders are flying around with mode-s transponders with ADS-B out. PowerFlarm does not treat the ADS-B signal in the same way as the Flarm signal for a number of reasons. I have been flying with PowerFlarm for almost a year now and have seen many many nuisance DTW's caused by gliders that have transponders with ADS-B out. In the mean time I have delivered diagnostic data to Flarm that enables them to improve the firmware and hopefully reduce the number of nuisance DTW's I certainly hope that Flarm is able to solve this problem soon, because nuisance warnings are also dangerous. I you get used to so much warnings you might not react to a real DTW. Hmm... interesting that gliders are equipping ADS-B out in Europe. So far the US has been insisting on a GPS source that costs more than the rest of the instruments put together. I wonder if this will ever change? Matt |
Just to clarify, the DTW described while can indeed be an issue with ADS-B out equipped gliders, has nothing to do with suppression of own mode C transponder which the OP describes.
Ramy |
PowerFLARM 3.0 and TIS | Andy[_1_] | Soaring | 6 | January 21st 14 09:35 AM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM 2.71...WTF? | [email protected] | Soaring | 40 | May 2nd 13 03:32 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
