Motor-glider talks at SSA convention in Reno
Old April 16th 14, 01:21 PM posted to rec.aviation.soaring
Dave Nadler
Default Motor-glider talks at SSA convention in Reno
On Monday, February 24, 2014 3:56:27 PM UTC-5, Key Dismukes wrote:
Dave
For those us who can't make it out there, are you planning
on making your slides or notes available?
thanks,
Key
Some bizarre ideas on RAS about motor-gliders!
I did post this, if anyone is interested in,
ya know, facts and experience, as opposed to
Random Aviation Speculation...
Sane motor-glider pilots DO NOT try an air-start
until they have a pattern planned and are in
position for landing after a worst-case failure,
which takes more altitude than landing an
un-powered glider...
Enjoy,
Best Regards, Dave
http://www.nadler.com/papers/2014_So...aker_notes.pdf
http://www.nadler.com/public/NadlerSoaringIndex.html
Old April 16th 14, 07:45 PM posted to rec.aviation.soaring
jfitch
Dave
thanks,
Key
Enjoy,
Best Regards, Dave
Interesting talk. I have two comments:
You recommend not beginning the engine start (attempt) until on downwind leg in the pattern. This adds all of the engine start workload in the middle of a pattern, a pattern that will need to be altered perhaps radically depending on the result of the start attempt. For this reason I always attempt to start the engine above a landable field and well above pattern altitude. It if fails to start, I can now set up a pattern appropriate to the configuration of the glider and concentrate on its execution. This requires the discipline to know when to quite fiddling with the engine. With the electric, it probably makes more sense because it either works or not, but with gas there are quite a lot of things to fiddle with, if it doesn't catch immediately.
Second, while you mention the addition to pilot workload while trying to start the engine, I believe there is a significant addition to pilot workload anytime you are near the glideslope to safety. Perhaps I overthink things, but when I get near the glideslope, I begin to think: Should I start the engine now? If it doesn't start will I still have options with my now 20:1 glide? Should I give up on the engine and concentrate on my straight in approach? Should I have started the engine 5 minutes ago? How cold is it from my last 3 hours at 17,000? Etc.
These things are running though my mind when I really ought to be thinking about flying the glider as a glider, and distract me well before the decision to start the motor has been made.
Old April 17th 14, 03:48 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote, On 4/16/2014 5:21 AM:
Dave
thanks,
Key
Enjoy,
Best Regards, Dave
It's a decent presentation, but I do think "plummet mode" grossly
exaggerates the situation: my ASH 26 E does not have a "plummet mode",
nor do similar gliders like the DG 800, Ventus self-launchers, etc.
My ASH 26 E thermals almost as well with the mast in the cooling
position as fully retracted, and landing with the mast extended only
means using a bit less spoiler than with it retracted. I'd reserve the
term "plummet mode" to sustainers that require diving to start the engine.
For a thorough discussion of self-launching sailplane operation, I
suggest you read my 60 page "Guide", available free from the ASA
(Auxiliary-powered Sailplane Association) website:
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old April 17th 14, 11:08 AM posted to rec.aviation.soaring
Dave Nadler
As was discussed in the talk, had you bothered to attend...
Wrong...
... I'd reserve the
If you had flown some of the planes I have, you would
have a rather different opinion.
You are losing the plot. The sink rate of many of these
planes with motor out and not running is much, much,
higher than what glider pilots are used to. Not planning
for this has led to many, many accidents...
Be careful out there,
Best Regards, Dave
Old April 19th 14, 03:29 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Dave Nadler wrote, On 4/17/2014 3:08 AM:
Wrong...
... I'd reserve the
Perhaps there is some confusion over "much, much". I'm talking about no
more than twice the sink rate of best L/D - how much are you thinking?
How about the ASH 26 E? Do you now agree it does not have a "plummet
mode"? I do not experience What I think is a high sink rate when the
mast is up.
The ASH 26 E, DG and Ventus models I'm talking about are not the "engine
on a stick" variety, but the newer (last 20 years or so) types with the
"buried" engine. There is a significant difference between, for example,
the old 15 meter PIK 20 E with it's "engine on a stick", and the newer
18 meter ASH 26 E, DG 800, etc, with their "buried engine".
Regardless of the sink rate, it is important for pilots of any glider to
practice landings with the propeller extended, so they are aware of the
gliders performance in that condition, and know how to handle the
situation when the engine does not start. There should never be a case
of "not used to it".
email me)
Old April 20th 14, 01:19 PM posted to rec.aviation.soaring
John Firth[_4_]
Wrong...
... I'd reserve the
engine.
The PIK20E with engine extended has a glide ratio no
better than 10:1 at 50kts.
John F
mast is up.
email me)
Old April 21st 14, 03:15 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Firth wrote, On 4/20/2014 5:19 AM:
Wrong...
... I'd reserve the
engine.
I've read it's more like 15:1. Do you have a reference for the PIK20E
glide angle? I don't remember such a bad glide angle on the one I flew a
number of times.
In any case, the 18 meter, buried engine self-launchers have a much
higher "mast extended" L/D.
email me)
SSA Convention at Reno, February 26 thru March 1 Burt Compton - Marfa Gliders, west Texas Soaring 0 February 22nd 14 04:39 AM
SSA Convention at Reno, February 26 thru March 1 Burt Compton - Marfa Gliders, west Texas Soaring 0 January 14th 14 03:54 PM
Reno Convention attendee's [email protected] Soaring 0 January 25th 12 09:31 PM
2006 Tailhook Convention - Reno, NV 7-10 September Mike Kanze Naval Aviation 0 June 7th 06 01:21 AM
2005 Tailhook Convention - Reno, NV, USA - 8-11 September Mike Kanze Naval Aviation 2 June 13th 05 07:41 PM
