I have a question about the history of soaring... (I'm not asking a practical serious question.)
Has anyone tried and/or had any luck with a 'slow burn single use' solid rocket in a glider? It would have the advantage of high energy density, low drag and quick start. I suppose that it might melt something important if it were were mounted on the fuselage. What about a wing mount close to the root? I know this idea sounds crazy, but a pop-up jet sustainer strikes me as only slightly less outrageous. |
At 22:31 16 April 2014, son_of_flubber wrote:
I have a question about the history of soaring... (I'm not asking a practic= al serious question.) Has anyone tried and/or had any luck with a 'slow burn single use' solid ro= cket in a glider? It would have the advantage of high energy density, low = drag and quick start. I suppose that it might melt something important if = it were were mounted on the fuselage. What about a wing mount close to the= root? I know this idea sounds crazy, but a pop-up jet sustainer strikes me as onl= y slightly less outrageous. Germans did Me-163. I know that it had not an 'slow burn' solid rocket, but it was liquid fuel, but still it was glider with rocket engine ![]() Regards Wolf http://youtu.be/WCej1kZInZk |
On Thu, 17 Apr 2014 14:36:07 +0000, Wolf Aviator wrote:
At 22:31 16 April 2014, son_of_flubber wrote: I have a question about the history of soaring... (I'm not asking a practic= al serious question.) Has anyone tried and/or had any luck with a 'slow burn single use' solid ro= cket in a glider? It would have the advantage of high energy density, low = drag and quick start. I suppose that it might melt something important if = it were were mounted on the fuselage. What about a wing mount close to the= root? I know this idea sounds crazy, but a pop-up jet sustainer strikes me as onl= y slightly less outrageous. Germans did Me-163. I know that it had not an 'slow burn' solid rocket, but it was liquid fuel, but still it was glider with rocket engine ![]() .....but never something you could call a 'safe ride'. Regards Wolf http://youtu.be/WCej1kZInZk Cool video, though. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Wednesday, April 16, 2014 5:31:37 PM UTC-5, son_of_flubber wrote:
I have a question about the history of soaring... (I'm not asking a practical serious question.) Has anyone tried and/or had any luck with a 'slow burn single use' solid rocket in a glider? It would have the advantage of high energy density, low drag and quick start. https://www.youtube.com/watch?v=vsqg28y_s3s As for whether or not it is practical, ask the high altitude model rocket guys how much the spend on a "shot" for one of their rockets with not near enough propellant to launch a glider. Then go take a couple of tows and see which you would rather do. But it is an interesting thought. |
IMHO it doesn't matter what kind of engine you have - at the
moment you reach for the start button of any motorised glider you have to be 100% certain in your mind that it will not start and have planned for that possibility. Then its nice when it does start. The actual probability of the engine not starting may vary depending on the type and service status of the engine system but the short term internal mental tool of 100% certainty of non- starting should not. (Even with the FES) John Galloway |
John Galloway wrote, On 4/17/2014 11:20 AM:
IMHO it doesn't matter what kind of engine you have - at the moment you reach for the start button of any motorised glider you have to be 100% certain in your mind that it will not start and have planned for that possibility. Then its nice when it does start. The actual probability of the engine not starting may vary depending on the type and service status of the engine system but the short term internal mental tool of 100% certainty of non- starting should not. (Even with the FES) Perhaps the plan could be the same one you have for the wing spar breaking, or a control rod disconnecting. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl |
Has anyone tried and/or had any luck with a 'slow burn single use' solid rocket in a glider? It would have the advantage of high energy density, low drag and quick start. I suppose that it might melt something important if it were were mounted on the fuselage. What about a wing mount close to the root? I know this idea sounds crazy, but a pop-up jet sustainer strikes me as only slightly less outrageous. Fritz von Opel in 1929. www.youtube.com/watch?v=vsqg28y_s3s Ed |
At 20:41 17 April 2014, Edward Bittenbender wrote:
www.youtube.com/watch?v=vsqg28y_s3 Sorry, the youtube link should have read: www.youtube.com/watch?v=vsqg28y_s3s Ed |
AS responds to the latest Ventus 2cxa | KevinFinke | Soaring | 3 | March 18th 09 03:45 AM |
Ventus 2C W&B - 15M vs 18M | [email protected] | Soaring | 0 | March 29th 06 10:20 PM |
FS: Ventus C | KO | Soaring | 9 | November 5th 05 12:58 AM |
FS: Ventus C 17.6 | John Shelton | Soaring | 0 | November 16th 04 12:55 AM |
FS Ventus C 17.6 | John Shelton | Soaring | 0 | November 15th 04 09:10 PM |
