Sorting out Experimental Airworthiness Certification and LSA designation
Old April 17th 14, 08:29 PM posted to rec.aviation.soaring
Frank Whiteley
Default Sorting out Experimental Airworthiness Certification and LSA designation
On Thursday, April 17, 2014 1:02:54 PM UTC-6, Frank Whiteley wrote:
On Thursday, April 17, 2014 7:11:33 AM UTC-6, son_of_flubber wrote:
On Thursday, April 17, 2014 8:33:29 AM UTC-4, Tom (2NO) wrote:
"I would like to get rid of the 300 NM geographic radius limitation and also eliminate the need for a program letter whenever I want to fly outside that radius."
If you simply add OLC to your list of events you never have to worry about the geographic limitation.
I suppose that would work until someone at my FSDO decides that OLC is not a 'race' in the same sense as what is called a 'race' in my operating limitations written in 1998.
Your operating limitations should say something about FAI and SSA records and awards. SSA recognizes OLC.
Frank Whiteley
That is, given the date of your operating limitations. FAA Order 8130.2 has omitted those from the lexicon for the past few revisions.
The new draft order is available here. Comment period closed Feb 7.
http://www.faa.gov/aircraft/draft_do...der_8130.2.pdf
Frank Whiteley
Experimental Airworthiness PS Soaring 13 July 1st 09 03:54 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
FS 2002 - sorting aircraft rottenberg Simulators 1 November 2nd 04 07:59 PM
How did F117 get it's designation? ReeferGuy Military Aviation 13 January 24th 04 02:32 PM
Airworthiness certification of an experimental Ace Pilot Home Built 0 July 16th 03 03:26 PM
