PowerFlarm v3.40
Old April 19th 14, 09:31 AM posted to rec.aviation.soaring
Ramy[_2_]
Default PowerFlarm v3.40
I suspect that in practice, suppressing transponders at the exact same altitude will have no much affect on PCAS reliability, as relative altitude between aircrafts fluctuate all the time, especially with gliders, and I suspect the suppression algorithm can detect altitude fluctuation and does not suppress it. This is just my guess based on the fact that my PF seem to do good job with PCAS alert even when flying at the same altitude as someone else.
Ramy
Old April 19th 14, 09:50 PM posted to rec.aviation.soaring
Andy[_1_]
On Saturday, April 19, 2014 1:31:15 AM UTC-7, Ramy wrote:
"I suspect that in practice, suppressing transponders at the exact same altitude will have no much affect on PCAS reliability, as relative altitude between aircrafts fluctuate all the time, especially with gliders, and I suspect the suppression algorithm can detect altitude fluctuation and does not suppress it. This is just my guess based on the fact that my PF seem to do good job with PCAS alert even when flying at the same altitude as someone else."
The relative altitude between gliders may be subject to large fluctuations. The relative altitude between powered aircraft is quite likely not to vary by more that the typical 100ft resolution of the altitude encoder interface.
I have first hand experience of being on a same altitude, opposite heading, less that 500ft lateral offset threat. ZAON PCAS alerted. I acquired the aircraft visually then checked PF portable. The target was never indicated or alerted.
ZAON used, perhaps inter alia, the signal strength to determine if a mode C signal is own ship. That is why there is provision in the calibration menus for adjusting each unit for own transponder signal strength. To the best of my knowledge FLARM units have no such provision for user calibration.
Andy
Old April 19th 14, 10:49 PM posted to rec.aviation.soaring
It would be nice to have the option to include a list of transponder codes that were always suppressed. For example, 1202. One could make the determination if a majority of the local gliders with a transponder also had FLARM. If that was a reasonable assessment for your location, then suppressing all the 1202 hits would potentially reduce the false alarms based on transponders and would rely on the more reliable FLARM data.
Old April 19th 14, 11:33 PM posted to rec.aviation.soaring
darrylr
Ah the trouble there is you cannot definitively associate a Mode A squawk reply with the same transponder doing a Mode C reply. And there will be situations where targets are doing Mode C only replies (e.g. any time a target is being interrogated by TCAS I or II but out of range of ground SSR... which I'm guessing happens a fair amount).
The 'best' you could do in that situation is stop all PCAS warnings. That may be/is likely too drastic, you can also so try adjusting the PCAS height/range parameters. Ultimately there is nothing you can do that is goign to work that well with Mode C transponders. Hopefully over time this will go away as an issue as Mode S transponder use keeps growing in the USA glider fleet.
There is no need/strong justification to replace a Mode C today, they work great for letting ATC know where you are and with TCAS, TCAD and PCAS in GA aircraft etc. but on the other hand there is no sane reason to buy a new Mode C transponder today. The possible issues here with PowerFLARM interoperability is just one of those reasons. Over time and as equipment ages and gets expensive to repair and new Mode S transponder technology hopefully keeps falling in cost and size etc. we'll just see the current Mode C usage in the glider fleet migrating over to Mode S. I'm much less worried about Mode C vs. Mode S than I am to encourage *any* transponder use in areas of high airline, fast jet, and even GA traffic.
Anybody who what my opinion on what the FAA should have really done with Mode S vs. Mode C transponders and ADS-B Out carriage mandates, etc. is welcome to buy me a six pack of beer and put up with an hour of whining.
Old April 20th 14, 04:14 PM posted to rec.aviation.soaring
Dan Marotta
Of course you all know that I'm not a Flarm guy.
Having said that, it strikes me funny that nobody seems to have noticed that
it's the "same altitude" aircraft that's going to hit you. Why would you
want all transponders at co-altitude to be suppressed? And the notion that
you're going to be OK since the Flarm will point out other Flarm traffic.
Listen up, Guys: GA, military, and airlines are NOT using Flarm. Oh, and
we have at least one guy at Moriarty who has a Flarm but not a transponder.
So he and the half dozen or so Flarm equipped gliders can avoid each other
but he's cruising along blissfully unaware that ATC can't see him, nor can
the airliners or military flights that buzz in and out of ABQ daily.
Hopefully Flarm will work this out as Zaon did several years ago.
"darrylr" wrote in message
glider fleet.
Old April 20th 14, 04:56 PM posted to rec.aviation.soaring
Ramy[_2_]
I am pretty sure that the suppression is based on power as well, in addition to altitude. So only a strong signal at the same altitude will be suppressed. Which mean you will still get warning for same altitude until the other aircraft is very close, giving you enough warning. I assume this is the same way that Zaon works. But again this is just my guess. Will be nice if Flarm folks will comment on this.
Ramy
Old April 21st 14, 03:17 AM posted to rec.aviation.soaring
Dan Marotta
That's what I would hope. I recall that, when I installed my Mode S
transponder and had it tested, it was putting out over 175 watts to the test
equipment antenna. Don't we have an inverse cube function of power density
to distance? I think that's right, though I probably didn't say it
correctly. Anyway, an aircraft a couple of hundred feet away would be
received in the milliwatt range, maybe somewhat more, but certainly not at
100+ watts.
"Ramy" wrote in message
Ramy
Old April 20th 14, 11:39 PM posted to rec.aviation.soaring
noel.wade
Dan -
The statistics show over and over that glider-to-glider collisions are more of a threat than glider-to-GA/Miliatry. FLARM isn't intended to be a perfect solution; it's intended to provide a very reliable, medium-cost, low-power solution for the biggest collision threat: other maneuvering gliders.
Mode C and even Mode S systems are not well-suited for combating glider-on-glider carnage when the craft are in close proximity and maneuvering.
There simply is no perfect solution; but I for one will take the single solution that reasonably covers the broadest range of targets and situations - and right now that's a PowerFLARM.
--Noel
Old April 21st 14, 12:33 AM posted to rec.aviation.soaring
Darryl Ramm
"noel.wade" wrote:
Dan -
--Noel
Hopefully that decision gets made by each pilot for the conditions they fly
in. And it's not necessarily a choice between a transponder or PowerFLARM.
And the decision should not always come down to PowerFLARM being the first
choice for all pilots. And having both provides very broad technology
assistance. And if in busy airspace areas establishing local procedures,
radio contact with ATC etc. with or without a transponder may be
appropriate.
Around busy airspace with lots of airliners and fast jet traffic the
PowerFLARM is just not going to be of much use. Except maybe highlighting
how much airline etc. traffic is around to be worried about as you see them
via 1090ES (around 1/3rd of airliners are currently 1090ES Out? I am not
sure).
Worrisome areas include those with lots of fast aircraft, all of who are
are in touch with ATC and everybody expects TCAS to just work because
'everybody else has a transponder'. The consequence of being the invisible
glider without a transponder that gets run into by an airliner is not going
to be pretty, so hopefully there is a local flying situation risk x
consequence part of any decision of what to equip with.
But yes clearly for glider-glider collision risks PowerFLARM is by far the
best choice. PCAS in PowerFLARM gives you useful help around GA traffic,
but for the big/fast conflicts you want to be seen by ATC and the TCAS
aboard those aircraft. Which means you need a transponder. ADS-B remains
largely a complex mess/futureware.
Darryl
Old April 21st 14, 03:18 AM posted to rec.aviation.soaring
Dan Marotta
Good points, Noel.
"noel.wade" wrote in message
Dan -
maneuvering.
--Noel
PowerFLARM 3.0 and TIS Andy[_1_] Soaring 6 January 21st 14 09:35 AM
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 05:56 PM
PowerFLARM 2.71...WTF? [email protected] Soaring 40 May 2nd 13 03:32 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
