PowerFlarm v3.40
Old April 21st 14, 03:17 AM posted to rec.aviation.soaring
Dan Marotta
Default PowerFlarm v3.40
That's what I would hope. I recall that, when I installed my Mode S
transponder and had it tested, it was putting out over 175 watts to the test
equipment antenna. Don't we have an inverse cube function of power density
to distance? I think that's right, though I probably didn't say it
correctly. Anyway, an aircraft a couple of hundred feet away would be
received in the milliwatt range, maybe somewhat more, but certainly not at
100+ watts.
"Ramy" wrote in message
I am pretty sure that the suppression is based on power as well, in addition
to altitude. So only a strong signal at the same altitude will be
suppressed. Which mean you will still get warning for same altitude until
the other aircraft is very close, giving you enough warning. I assume this
is the same way that Zaon works. But again this is just my guess. Will be
nice if Flarm folks will comment on this.
Ramy
Old April 21st 14, 05:43 PM posted to rec.aviation.soaring
100+ watts.
Ramy
Dan, radiation diminishes according to the inverse square law, just as gravitational forces or sound:
http://en.wikipedia.org/wiki/Inverse-square_law
If you double the distances, intensity falls to a quarter.
Old April 22nd 14, 01:48 AM posted to rec.aviation.soaring
Dan Marotta
OK, I was picturing the power as on the surface of an expanding sphere from
the point of transmission (4/3 * pi * r **3) but, as I said, I wasn't sure.
test
density
at
100+ watts.
addition
this
Ramy
PowerFLARM 3.0 and TIS Andy[_1_] Soaring 6 January 21st 14 09:35 AM
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 Tim Taylor Soaring 20 June 17th 13 05:56 PM
PowerFLARM 2.71...WTF? [email protected] Soaring 40 May 2nd 13 03:32 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
