OK, I was picturing the power as on the surface of an expanding sphere from
the point of transmission (4/3 * pi * r **3) but, as I said, I wasn't sure. wrote in message ... On Sunday, April 20, 2014 9:17:30 PM UTC-5, Dan Marotta wrote: That's what I would hope. I recall that, when I installed my Mode S transponder and had it tested, it was putting out over 175 watts to the test equipment antenna. Don't we have an inverse cube function of power density to distance? I think that's right, though I probably didn't say it correctly. Anyway, an aircraft a couple of hundred feet away would be received in the milliwatt range, maybe somewhat more, but certainly not at 100+ watts. "Ramy" wrote in message ... I am pretty sure that the suppression is based on power as well, in addition to altitude. So only a strong signal at the same altitude will be suppressed. Which mean you will still get warning for same altitude until the other aircraft is very close, giving you enough warning. I assume this is the same way that Zaon works. But again this is just my guess. Will be nice if Flarm folks will comment on this. Ramy Dan, radiation diminishes according to the inverse square law, just as gravitational forces or sound: http://en.wikipedia.org/wiki/Inverse-square_law If you double the distances, intensity falls to a quarter. |
PowerFLARM 3.0 and TIS | Andy[_1_] | Soaring | 6 | January 21st 14 09:35 AM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM 2.71...WTF? | [email protected] | Soaring | 40 | May 2nd 13 03:32 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
