Zaon figured it out years ago. My PCAS does not alert on my transponder.
In fact, with a simple button hit, it displays my squawk code to verify that it's giving me alerts based upon my transponder altitude rather than its own internal pressure sensor. Why can't the PFlarm simply eliminate the most powerful transponder received? That would have to be your own unless another aircraft is parked with his transponder antenna closer to your PF antennae than your own transponder antenna and that ain't bloody likely. "Andy" wrote in message ... On Sunday, April 20, 2014 8:14:46 AM UTC-7, Dan Marotta wrote: it strikes me funny that nobody seems to have noticed that it's the "same altitude" aircraft that's going to hit you. It's not that nobody has noticed. I have posted about this issue before. The reason FALRM implemented this change is that it is less bad than having continuous alerting to ownship transponder. Why would you want all transponders at co-altitude to be suppressed? Because they have not figured out how to suppress the only co-altitude transponder that needs to be suppressed - the one in the same aircraft as the Power FLARM. Andy |
On Wednesday, April 23, 2014 3:11:32 PM UTC-7, Dan Marotta wrote:
Zaon figured it out years ago. My PCAS does not alert on my transponder. No need to tell me that. I own a ZAON MRX and have used it as the benchmark for side by side testing of Power FLARM mode C alerting. I have reported my results several times on this group. When the MRX is working it does a very good job of distinguishing between ownship and other transponders. I, and other MRX owners, have had reliability issues though. ZAON gave outstanding customer support and repaired my MRX twice for no change despite the fact it was years out of warranty. There was a time when my MRX did alert to my own transponder. This was caused by 2 factors. First my altitude encoder was unstable with temperature and, second, my transponder had marginal power output. Since fixing those issues the MRX works as advertised. My Power FLARM portable does not. I'm tempted to say I wish FLARM supported their customers like ZAON did. However, ZAON is out of business and I hope FLARM does not follow. Andy |
Thanks for that, Andy. I just must be very lucky having bought one of the
last MRXs. Its performance has been (so far) flawless. "Andy" wrote in message ... On Wednesday, April 23, 2014 3:11:32 PM UTC-7, Dan Marotta wrote: Zaon figured it out years ago. My PCAS does not alert on my transponder. No need to tell me that. I own a ZAON MRX and have used it as the benchmark for side by side testing of Power FLARM mode C alerting. I have reported my results several times on this group. When the MRX is working it does a very good job of distinguishing between ownship and other transponders. I, and other MRX owners, have had reliability issues though. ZAON gave outstanding customer support and repaired my MRX twice for no change despite the fact it was years out of warranty. There was a time when my MRX did alert to my own transponder. This was caused by 2 factors. First my altitude encoder was unstable with temperature and, second, my transponder had marginal power output. Since fixing those issues the MRX works as advertised. My Power FLARM portable does not. I'm tempted to say I wish FLARM supported their customers like ZAON did. However, ZAON is out of business and I hope FLARM does not follow. Andy |
PowerFLARM 3.0 and TIS | Andy[_1_] | Soaring | 6 | January 21st 14 09:35 AM |
PowerFLARM USB 3 cables and ConnectMe to PowerFLARM through V7 | Tim Taylor | Soaring | 20 | June 17th 13 05:56 PM |
PowerFLARM 2.71...WTF? | [email protected] | Soaring | 40 | May 2nd 13 03:32 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
