Any F-11 maintainers here? It has been my understanding that the egress
sysrem on the plane and its 600+ pryotechnics charges were major maintenance headaches. Far from a major maintenance headache, the components that you refer to were static items that didn't wear out any more than the capsule's, or any other ejection system's, rocket motor. I'm not sure what information led you to this understanding. Can you cite some sources? Kurt Todoroff Markets, not mandates and mob rule. Consent, not compulsion. |
Any F-111 maintainers here? It has been my understanding that the egress
sysrem on the plane and its 600+ pryotechnics charges were major maintenance headaches. Far from a major maintenance headache, the components that you refer to were static items that didn't wear out any more than the capsule's, or any other ejection system's, rocket motor. I'm not sure what information led you to this understanding. Can you cite some sources? Sure. I was an F-4 maintenance officer at RAF Lakenheath UK in the 70s until the F-111Fs repalced the F-4Ds. We (the Lakenheath maintenenace staff) had numerous dialogs with the F-111E (IIRC) guys at Upper Heyford not far away. They showed us the major system maintenance manhour drives and the capsule pyros were right near the top. All the pyros were time change items and many required pulling a lot of hardware to access and change. Not a problem on a low hour plane but as the plane accumulated hours the time change requirements increased. |
![]() "SteveM8597" wrote in message ... Any F-111 maintainers here? It has been my understanding that the egress sysrem on the plane and its 600+ pryotechnics charges were major maintenance headaches. Far from a major maintenance headache, the components that you refer to were static items that didn't wear out any more than the capsule's, or any other ejection system's, rocket motor. I'm not sure what information led you to this understanding. Can you cite some sources? Sure. I was an F-4 maintenance officer at RAF Lakenheath UK in the 70s until the F-111Fs repalced the F-4Ds. We (the Lakenheath maintenenace staff) had numerous dialogs with the F-111E (IIRC) guys at Upper Heyford not far away. They showed us the major system maintenance manhour drives and the capsule pyros were right near the top. All the pyros were time change items and many required pulling a lot of hardware to access and change. Not a problem on a low hour plane but as the plane accumulated hours the time change requirements increased. Presumably in modern aircraft with digital data buses most of the wiring harnesses would be replaced by the bus thus substantially reducing the number of charges. |
![]() Here's more on the plane that "bailed out" the other day, from Aero-News email newsletter this morning: ************************************************** ****************** "Minutes after departure, I started experiencing instrument failures, one after another. No warning. No smoke. No clues. Just gauges going out one after another." As the first gauge failed, Jeff told Center he wanted to turn back. Center immediately gave him vectors for the return, but thereafter the perceived succession of failures made the turn-around seem fairly iffy. Ippoliti was stunned. Not only were gauges failing, but they were failing in systems that didn't appear to be related. In a matter of seconds, just hundreds of feet from the ground and untold obstacles obscured by IMC, he really didn't know what to trust. This couldn't be good. With an unknown number of hazards looming, he informed ATC that he was clearly in trouble. And after some initial hope of heading back, the SR22 pilot realized that turning back to the airport was something he wasn't sure he could do with his gauges continuing to fail in "rapid succession." "I told center I couldn't turn back... that I was going to pull the chute." Jeff then told ANN that one of the few responses he remembered from that moment on was center responding, "you're going to pull what?" From there, Ippoliti's activities were quick and assured. "I'd thought about this... but I never expected to have to do it." Jeff pulled the power back, killed the engine and reached up for the BRS CAPS handle... and pulled. Despite all his trepidation, Jeff noted that the pull went well, "No problem with that, it pulled easily." BANG! The chute OPENED. Ippoliti then described feeling a little 'G' as the plane slowed, swung around a bit, and then things calmed down remarkably fast. "From there it was almost a non-event. The ELT went off right away and prevented me from understanding Center because it was so loud, and the pilot door came off as the chute fired... but the ride down lasted only seconds as I came down on some trees and just... stopped." Ippoliti was alive and had landed in a local park. The aircraft was not only intact, but surprisingly suffered limited damage... "a lot less than what might have been," he noted. He doesn't have much to say about the landing impact, as the trees apparently absorbed most of the energy, and turned history's third emergency CAPS landing into a "relative non-event." all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com Viva Bush! blog www.vivabush.org |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 1st 04 02:31 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
