Not unusual. I cross the fence at 100 knots in the Twin Comanche and land
at 85 knots or so on a normal length runway. John Stricker "Corky Scott" wrote in message ... On 19 Nov 2003 17:16:03 -0800, (Jay) wrote: "It's just one of the risks you take when you play the game with a single-engine aircraft," he said. Well said Mr. Swears. 90MPH was the slowest he could get it before he went into the drink? Just taking a guess, but if he was heading for San Francisco at this time, his airplane must have been pretty heavily loaded. I've always been impressed with how high the landing speed of many of the canards is. This one, at it's max fuel load could easily have been around 80 or so. The guy probably did not want to let it get to the speed where the canard lost lift and the nose pitched down. I think even the Grumman F6F Hellcat landed slower than 90. Corky Scott |
On Fri, 21 Nov 2003 17:41:37 -0600, Big John
wrote: Corky Have you enough ammunition on auto engines to stop the nit picking in this group? Both Lyc and Con started life with auto engines G Big John Big John, to the best of my knowledge, I try not to nitpick. I try to present facts as I know them. I believe that there are various auto engines that can be successfully converted and I believe it strongly enough that I'm assembling a Ford V6 in my shop that will be the engine I fly behind. You weren't here when this subject was first aired many years ago, but there were many sceptics... actually that's not a strong enough word. There were some extremely vocal critics of the concept who felt that no auto engine would work in an airplane. One of them was an auto engineer, a guy who used to work for the Chaparal Racing Team with Jim Hall. He was absolutely positive that V configured auto engines would disintegrate (literally) under the stress. He also believed they could not cool because the coolant passages were too small and the cylinders too close together. He was wrong. In order to build a reliable auto conversion, you do have to do your homework. You have to safety wire just about everything that could come off including the oil pan bolts. You have to build using accepted aviation practices. There have been guys who screwed gas or oil lines into the block and then ran them to the firewall. They broke. You can't mount pipes solidly to the block and run them for any distance, prop vibration will eventually crack them. The guy who developed the Ford V6 discovered that the stud that holds the air filter can and will unscrew and drop into the engine, if you don't safety wire it. How did he discover this? Because it did. It was one of the many flights in which he coasted back to the runway. By now, many guys have successfully built and flown the Ford V6. One guy accumulated more than 2,000 hours without anything falling off or failing. Others are in the over a thousand hours hobbs time category. For some reason, success stories like this don't seem to matter to those who feel using an auto engine won't work. I do intend to test run the engine extensively. I'm fabricating an engine test stand along with the engine assembly process. While it's true this doesn't exactly duplicate the stresses encountered during flight, it's the best I can do, and better than just hanging it on the airframe and testing the engine during the very first flight. One thing at a time please. Corky Scott |
To walk before you run.
Didn't mean to draw a long history Corky. I've followed the discussion here for a while and inspected and evaluated converted engines, etc. for many years. I just wanted to point out another bit of triva that you could use in protecting yourself from the 'nit pickers' who have taken you to task on the Group. Big John On Mon, 24 Nov 2003 13:48:22 GMT, (Corky Scott) wrote: On Fri, 21 Nov 2003 17:41:37 -0600, Big John wrote: Corky Have you enough ammunition on auto engines to stop the nit picking in this group? Both Lyc and Con started life with auto engines G Big John Big John, to the best of my knowledge, I try not to nitpick. I try to present facts as I know them. ----clip---- |
(Corky Scott) wrote: On Fri, 21 Nov 2003 17:41:37 -0600, Big John wrote: Corky Have you enough ammunition on auto engines to stop the nit picking in this group? Both Lyc and Con started life with auto engines G Big John Big John, to the best of my knowledge, I try not to nitpick. I try to present facts as I know them. I believe that there are various auto engines that can be successfully converted and I believe it strongly enough that I'm assembling a Ford V6 in my shop that will be the engine I fly behind. Who is the guy near Lakeland that uses, or used the Aluminum small block Chevy in the Lancair IV-P? Think it was just shy of 400 cu inch. He did a lot of testing including dyno work. After he had the front web separate on take off he went out and purchased the equipment to cast his own blocks. He figured the front web was too weak to take the PSRU stresses. I talked to him at Oshkosh a few years back and he figured that he had over 7 figures into the engine operation at that time. Admittedly there are few of us who can afford to do that, but he was developing a lot of useful information the rest of us could, or might be able to use. He had flown the rig to Oshkosh from Lakeland in about 3 hours, so that sucker did haul. Don't know about engine life and durability though. You'll have to fix the return add due to dumb virus checkers, not spam Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair?) www.rogerhalstead.com |
On Mon, 24 Nov 2003 22:40:13 GMT, Roger Halstead
wrote: Who is the guy near Lakeland that uses, or used the Aluminum small block Chevy in the Lancair IV-P? Think it was just shy of 400 cu inch. He did a lot of testing including dyno work. After he had the front web separate on take off he went out and purchased the equipment to cast his own blocks. He figured the front web was too weak to take the PSRU stresses. I talked to him at Oshkosh a few years back and he figured that he had over 7 figures into the engine operation at that time. Admittedly there are few of us who can afford to do that, but he was developing a lot of useful information the rest of us could, or might be able to use. He had flown the rig to Oshkosh from Lakeland in about 3 hours, so that sucker did haul. Don't know about engine life and durability though. You'll have to fix the return add due to dumb virus checkers, not spam Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair?) www.rogerhalstead.com That would be Jim Rahm of Enginair. In a former life he was the no. 2 guy behind "HURST" as in Hurst shifters. Auto's and hotrodding were his life, until he discovered aviation. Hotrodding an airplane just seemed a natural to him. You're right, the engine had a LOT of engineering and dyno development and so far has performed flawlessly. The PSRU on the other hand, has been problematic. The PSRU was the one thing he felt should be done by people who knew how to do them, and contracted NIS to develop one. To make a long story short, the PSRU did not work well and things have been in litigation for a while. Making a PSRU to handle 120 to 180 horsepower is one thing, making one to handle over 400 horsepower is something entirely different. Corky Scott |
On Tue, 02 Dec 2003 12:57:49 GMT,
(Corky Scott) wrote: On Mon, 01 Dec 2003 17:20:55 GMT, (Corky Scott) wrote: The PSRU was the one thing he felt should be done by people who knew how to do them, and contracted NIS to develop one. To make a long story short, the PSRU did not work well and things have been in litigation for a while. Making a PSRU to handle 120 to 180 horsepower is one thing, making one to handle over 400 horsepower is something entirely different. Corky Scott Thanks Corky, I appreciate the info. As I see it (and I don't know squat about PSRUs except their goal) a high ratio PSRU as used in a turbo prop which has a very high ratio (planetary) is easier to build than say the 2:1 or 3:1, BUT the planetary also has the advantage in being used on an engine without pulses being inherent in their operation. The life of a PSRU on a piston engine has to be complicated. It not only has to handle linear torque and thrust, but virtually any other imaginable angle as well. Then it has to be designed to avoid any resonances with those power train pulses AND take the positive and negative torque without beating the snot out of the gears which means next to nothing for slack (which brings its own set of problems). Helical, double helical, spur, planatery...each with it's own set of pluses and minuses. BUT, didn't the big 12 and 16 cylinder Vs in WWII have PSRUs? Course those engines had very short TBOs too. Then again they weren't exactly babied either. Also...How did the guys make out using the Olds chain drive in the Legend? It "appeared" to work great for at least a short time, but they were running 400 to 500 HP through a chain that was used in a drive train that only had about 200 HP on the other end. When I talked to the one guy at Oshkosh some years back he thought it had plenty of reserve. I always like that airplane. Last I saw it had a turbine up front. Sorry, that should be NSI. I know when he used the original "so called" chevy big block aluminum based engine he felt the front web was the weak spot. Course that was right after planting his IV_P off the end of the runway when the web broke. (or did he make it back on that one?) At any rate the web broke and it was a high pucker factor. That sucker sure did go though. The only thing that would have been able to beat him from Lakeland to Oshkosh would have been a jet and it would have had to have been a direct, non stop flight. You'll have to fix the return add due to dumb virus checkers, not spam Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair?) www.rogerhalstead.com Corky Scott |
Corky Scott wrote:
On Fri, 21 Nov 2003 17:41:37 -0600, Big John wrote: Corky Have you enough ammunition on auto engines to stop the nit picking in this group? Both Lyc and Con started life with auto engines G Big John Big John, to the best of my knowledge, I try not to nitpick. I try to present facts as I know them. I believe that there are various auto engines that can be successfully converted and I believe it strongly enough that I'm assembling a Ford V6 in my shop that will be the engine I fly behind. You weren't here when this subject was first aired many years ago, but there were many sceptics... actually that's not a strong enough word. There were some extremely vocal critics of the concept who felt that no auto engine would work in an airplane. One of them was an auto engineer, a guy who used to work for the Chaparal Racing Team with Jim Hall. He was absolutely positive that V configured auto engines would disintegrate (literally) under the stress. He also believed they could not cool because the coolant passages were too small and the cylinders too close together. He was wrong. In order to build a reliable auto conversion, you do have to do your homework. You have to safety wire just about everything that could come off including the oil pan bolts. You have to build using accepted aviation practices. There have been guys who screwed gas or oil lines into the block and then ran them to the firewall. They broke. You can't mount pipes solidly to the block and run them for any distance, prop vibration will eventually crack them. The guy who developed the Ford V6 discovered that the stud that holds the air filter can and will unscrew and drop into the engine, if you don't safety wire it. How did he discover this? Because it did. It was one of the many flights in which he coasted back to the runway. By now, many guys have successfully built and flown the Ford V6. One guy accumulated more than 2,000 hours without anything falling off or failing. Others are in the over a thousand hours hobbs time category. For some reason, success stories like this don't seem to matter to those who feel using an auto engine won't work. I do intend to test run the engine extensively. I'm fabricating an engine test stand along with the engine assembly process. While it's true this doesn't exactly duplicate the stresses encountered during flight, it's the best I can do, and better than just hanging it on the airframe and testing the engine during the very first flight. One thing at a time please. Corky Scott First, I apologize for the delayed posting in the middle of a thread. I can only say that it has been a strange week ... My personal view, not fully substantiated be research, is that most (and possibly all) of the current automotive engines can be successfully converted for aircraft use. However many of them have shortcomings that make them less attractive. I might not bother with an engine that I expect to have significant vibration modes other than torsion. For example; I doubt that I would convert any of the three cylinder engines, even if it had balance shafts, as an inline four could be a much smoother installation. My hypothesis is that the pitch oscillation of the three cylinder, and possibly some of the 90 degree vee six, engines would add stresses to the propeller and PSRU. OTOH, there are a lot of 90 degree vee six engines flying... Probably the best question is not whether an automotive engine can be made reliable; but whether a purpose-built engine is available and competitively priced for the application. For example, Jabiru offers ram air cooled engines of 80 and 120 horsepower; provided that the aircraft is fast enough to use a 60 inch diameter prop. Rotax offers engines with a hybrid cooling scheme... As I recall, Blanton's conversion was originally for glider towing. According to the story I was told, the reduction drive allowed the Ford vee six to produce thrust similar to a much more powerful direct drive aircraft engine--at towing speeds. Unfortunately, the story later circulated that the engine produced mathematically ridiculous amounts of horsepower... So, I may eventually build with an automotive conversion. Or may not. The choice is not "open and shut". Regards, Peter |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
FS: O-235C1 Lycoming engine (core) | Del Rawlins | Home Built | 0 | October 8th 03 09:46 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
