![]() Henry J Cobb wrote: http://www.prnewswire.com/cgi-bin/st...2163485&EDATE= More details about the KC-130J tanker can be found here. http://www.globalsecurity.org/milita...ft/kc-130j.htm -HJC How does "hotel mode" work? Bob -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
On Sun, 02 May 2004 11:57:54 -0500, Bob Urz wrote:
Henry J Cobb wrote: http://www.prnewswire.com/cgi-bin/st...2163485&EDATE= More details about the KC-130J tanker can be found here. http://www.globalsecurity.org/milita...ft/kc-130j.htm -HJC How does "hotel mode" work? Their uniforms turn Air Force blue and their TDY accommodations improve. -Jeff B. yeff at erols dot com |
Bob Urz wrote:
How does "hotel mode" work? http://www.codeonemagazine.com/event..._events33.html Hotel mode, a unique capability of the C-130J propulsion system that provides for safer ground loading and unloading operations, was demonstrated in recent tests at MCAS Cherry Point, North Carolina. This capability puts the C-130J propellers in feathered position, which reduces both propeller blast and engine exhaust heat and, consequently, the amount of dust, dirt, and debris being kicked up behind the aircraft. The engines remain running in this mode enabling the pilot to spool them quickly up to military power. -HJC |
![]() Henry J Cobb wrote: Bob Urz wrote: How does "hotel mode" work? http://www.codeonemagazine.com/event..._events33.html Hotel mode, a unique capability of the C-130J propulsion system that provides for safer ground loading and unloading operations, was demonstrated in recent tests at MCAS Cherry Point, North Carolina. This capability puts the C-130J propellers in feathered position, which reduces both propeller blast and engine exhaust heat and, consequently, the amount of dust, dirt, and debris being kicked up behind the aircraft. The engines remain running in this mode enabling the pilot to spool them quickly up to military power. -HJC I saw what it does already, i was more curious on how. I have visions of a large clutch pack or such. That could be a potential failure mode. I am curious mechanically how they do it. Bob -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
The LPT is not physically connected to the compressor; only to the prop
gearbox. The pitch control unit routes oil through the Beta tube to the prop to set it to feather. Since the LPT isn't connected to the HPT or the compressor, it can turn at a much slower speed. That is the reason the engine spools up faster than the T-56 also. If you're doing a man on the stand you apply a bit of reverse pitch because in hotel mode you still have some prop blast. Steve R. "Bob Urz" wrote in message ... Henry J Cobb wrote: Bob Urz wrote: How does "hotel mode" work? http://www.codeonemagazine.com/event..._events33.html Hotel mode, a unique capability of the C-130J propulsion system that provides for safer ground loading and unloading operations, was demonstrated in recent tests at MCAS Cherry Point, North Carolina. This capability puts the C-130J propellers in feathered position, which reduces both propeller blast and engine exhaust heat and, consequently, the amount of dust, dirt, and debris being kicked up behind the aircraft. The engines remain running in this mode enabling the pilot to spool them quickly up to military power. -HJC I saw what it does already, i was more curious on how. I have visions of a large clutch pack or such. That could be a potential failure mode. I am curious mechanically how they do it. Bob -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
"Steve R." wrote:
The LPT is not physically connected to the compressor; only to the prop gearbox. The pitch control unit routes oil through the Beta tube to the prop to set it to feather. Since the LPT isn't connected to the HPT or the compressor, it can turn at a much slower speed. That is the reason the engine spools up faster than the T-56 also. If you're doing a man on the stand you apply a bit of reverse pitch because in hotel mode you still have some prop blast. Steve R. Ok, so it's 'not' a T-56 then...do you know what it is?...and what RPM does the prop turn at in that mode?...most interesting... -- -Gord. |
![]() "Gord Beaman" wrote in message ... "Steve R." wrote: The LPT is not physically connected to the compressor; only to the prop gearbox. The pitch control unit routes oil through the Beta tube to the prop to set it to feather. Since the LPT isn't connected to the HPT or the compressor, it can turn at a much slower speed. That is the reason the engine spools up faster than the T-56 also. If you're doing a man on the stand you apply a bit of reverse pitch because in hotel mode you still have some prop blast. Steve R. Ok, so it's 'not' a T-56 then...do you know what it is?...and what RPM does the prop turn at in that mode?...most interesting... -- -Gord. (Note: I get this whole top post/bottom post thing messed up, so forgive me if I switch back & forth. ![]() The J-model has the Rolls Royce AE2100D-3 engines. The AE2100 engine is used in the Saab 2000, C-27J and in the AE1107 configuration in the V-22 Osprey. I do not know the prop RPM in HOTEL mode, but it is approx. 25-30% Np RPM, where low speed ground idle is 71-73% Np RPM. Steve R. |
Henry J Cobb wrote:
Bob Urz wrote: How does "hotel mode" work? http://www.codeonemagazine.com/event..._events33.html Hotel mode, a unique capability of the C-130J propulsion system that provides for safer ground loading and unloading operations, was demonstrated in recent tests at MCAS Cherry Point, North Carolina. This capability puts the C-130J propellers in feathered position, which reduces both propeller blast and engine exhaust heat and, consequently, the amount of dust, dirt, and debris being kicked up behind the aircraft. The engines remain running in this mode enabling the pilot to spool them quickly up to military power. It also allows them to keep the climate control systems running, which is commonly called a "hotel load" (lights and A/C). Which is probably how it came to be called "hotel mode". -Marc -- Marc Reeve actual email address after removal of 4s & spaces is c4m4r4a4m4a4n a4t c4r4u4z4i4o d4o4t c4o4m |
Bob Urz wrote:
Henry J Cobb wrote: http://www.prnewswire.com/cgi-bin/st...2163485&EDATE= More details about the KC-130J tanker can be found here. http://www.globalsecurity.org/milita...ft/kc-130j.htm -HJC How does "hotel mode" work? Bob Hell yes!!...how indeed?, that's a very interesting development...I'm assuming that this isn't the normal Allison C-130 engine? -- -Gord. |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
Lockheed Martin completes first F-16I for Israel | Henry J. Cobb | Military Aviation | 16 | November 19th 03 01:22 PM |
Shooting at Lockheed Martin plant. | Gil G. | Military Aviation | 14 | August 14th 03 08:59 AM |
6 reported slain at Lockheed Martin facility in Mississippi | Bertie the Bunyip | Military Aviation | 60 | July 15th 03 10:23 AM |
Shooting at a Lockheed Martin plant | Quant | Military Aviation | 0 | July 8th 03 05:02 PM |
