If you are a member of SSA, go to www.ssa.org. Under "The SSA", find "Soaring Magazine", then "Johnson Reports". Select the link to the flight test report. You will have to log in to see it. Should have everything you need to know.
Happy Flying! Steve |
Thank you, Steve, I will try that.
Regards, -GE On Wednesday, May 7, 2014 8:48:00 AM UTC-5, Steve Leonard wrote: If you are a member of SSA, go to www.ssa.org. Under "The SSA", find "Soaring Magazine", then "Johnson Reports". Select the link to the flight test report. You will have to log in to see it. Should have everything you need to know. Happy Flying! Steve |
You should be aware that the designer of the LAK-12 read the Johson report and strongly disputed the 50-1 L/D Johnson claimed for the glider. Klemas Juocas the head of the design team at Sportine Aviacija did not believe the LAK-12 was better than 48-1.
Robert Mudd Moriarty, N.M. On Tuesday, May 13, 2014 5:23:18 PM UTC-6, wrote: Thank you, Steve, I will try that. Regards, -GE On Wednesday, May 7, 2014 8:48:00 AM UTC-5, Steve Leonard wrote: If you are a member of SSA, go to www.ssa.org. Under "The SSA", find "Soaring Magazine", then "Johnson Reports". Select the link to the flight test report. You will have to log in to see it. Should have everything you need to know. Happy Flying! Steve |
For Sale: SN10B | Britton | Soaring | 5 | November 2nd 12 03:32 PM |
Looking for used SN10B Edit | yankeegolf | Soaring | 0 | March 15th 10 12:25 PM |
Looking for used SN10B | yankeegolf | Soaring | 0 | March 15th 10 12:21 PM |
SN10B for sale | Dick[_3_] | Soaring | 0 | June 6th 09 09:05 PM |
SN10B Wanted | fulda304 | Soaring | 1 | January 28th 08 02:51 PM |
