"This stuff must be really good! If you look under "Product Features," fourth bullet point down it says: "Nuclear power plant construction and maintenance."
Yeah, I've actually read the product spec sheet on 3M's website with some degree of amusement trying to find out what this tape was originally intended for! |
Is it possible or practicable to use relective wing tape?
Some time ago conspuity tests determined that a reflective surface on a glider was more visible than a plain colour such as red or black. So maybe it could serve a dual purpose. |
Wing Tape | Craig[_2_] | Soaring | 0 | May 5th 11 05:09 PM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
Wing Tape - Does Thickness Affect Performance? | ContestID67 | Soaring | 87 | February 1st 07 03:24 PM |
Wing Tape - Does Thickness Affect Performance? | Charles McLaurin | Soaring | 2 | January 30th 07 06:00 PM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
