On Thursday, May 8, 2014 2:42:52 PM UTC-4, Martin Gregorie wrote:
On Thu, 08 May 2014 08:23:01 -0700, Richard wrote: What is your take on a 4800 baud rate system that also transmits PowerFlarm and Vario sentences two ways. I don't have enough information to make any estimate. To do that you need to know: - baud rate and character format - format of the various messages exchanged with the FLARM and vario - the frequency and order in which the messages are exchanged. and I don't have any of this stuff. I am able estimate the spare capacity in a GPS receiver's output stream because I found the NMEA sentence formats and character format (8N1) on the 'net [1] and spent some time with a Garmin GPS2+ and a GPS35 hooked up to the serial port on a PC, watching the data stream and working out how it changes as the GPS settings are changed, i.e. no active route, active routes with different numbers of waypoints. [1] http://aprs.gids.nl/nmea/ gives some NMEA sentence formats: enough for our purposes and the NMEA 0183 specification gives baud rate and character encoding. However, this stuff is quite hard to find because it seems that the standards that define NMEA sentence formats and ordering are not exactly an open source document. The full spec will set you back around $2800. BTW, it seems that 38400 baud is also a standard NMEA transmission rate. It is used for AIS (Automatic Identification System), an automatic tracking system used on ships and by vessel traffic services (VTS) for identifying and locating vessels by electronically exchanging data with other nearby ships, AIS base stations, and satellites. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Typically varios send one sentence a second containing the lift data and some other stuff. Sentences indicating things that don't change that often (MC, ballast, bugs, whatever) are sent less frequently, or only when those values change. FLARM data volume depends on the connection speed. At 19.2K it sends a pretty large amount of data describing all the targets in view. At slower speeds you just get the warnings. Matt |
On Thu, 08 May 2014 13:04:39 -0700, mattmckrell wrote:
Typically varios send one sentence a second containing the lift data and some other stuff. Some (mainly older ones?) like the SDI C4 don't send anything - they just receive GPRMB,GPRMC,GPROO,GPWPL - the set needed to calculate wind and final glide. Presumably 'other stuff' includes IAS. Sentences indicating things that don't change that often (MC, ballast, bugs, whatever) are sent less frequently, or only when those values change. Makes sense. How big are the sentences? Are their formats generally available? FLARM data volume depends on the connection speed. At 19.2K it sends a pretty large amount of data describing all the targets in view. At slower speeds you just get the warnings. I'd heard that, but have seen any documentation of either those messages or the FLARM additions to their IGC log files. IIRC both message sets are regarded as proprietary/undocumented. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Thursday, May 8, 2014 6:31:58 PM UTC-4, Martin Gregorie wrote:
On Thu, 08 May 2014 13:04:39 -0700, mattmckrell wrote: FLARM data volume depends on the connection speed. At 19.2K it sends a pretty large amount of data describing all the targets in view. At slower speeds you just get the warnings. I'd heard that, but have seen any documentation of either those messages or the FLARM additions to their IGC log files. IIRC both message sets are regarded as proprietary/undocumented. The FLARM message sets for traffic and collision warnings are very well documented and used by at least a dozen other manufacturers and software packages to display FLARM info. See "Data Port Spec": http://www.flarm.com/support/manual/index.html See the "Sentence PFLAA" section for explanation that 19200 is required to receive traffic information. Hearsay is dangerous (and rampant on RAS)... Best Regards, Dave "YO electric" |
On Thu, 08 May 2014 15:42:42 -0700, Dave Nadler wrote:
The FLARM message sets for traffic and collision warnings are very well documented and used by at least a dozen other manufacturers and software packages to display FLARM info. See "Data Port Spec": http://www.flarm.com/support/manual/index.html Thanks for the link, Dave. Bookmarked. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
note to fellow selves - SYM upgrade and baud rates | 2NO | Soaring | 0 | April 20th 12 11:07 PM |
WestJet B-737 With The Sun Setting | Canuck[_10_] | Aviation Photos | 0 | September 4th 10 05:07 PM |
Cruise RPM setting | john | Piloting | 22 | October 18th 07 07:46 PM |
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
Setting QNH | BTIZ | Piloting | 31 | March 12th 04 04:29 PM |
