Fatal crash Arizona
Old May 14th 14, 03:14 AM posted to rec.aviation.soaring
Default Fatal crash Arizona
I've been into soaring since 1996 and he was the 7th I've known to be called to the other side.
We try to learn from others' mistakes, but in this case, as there were no glider pilots who observed the event, little can be learned.
My heart goes out to his family and friends.
Bob T
Bob thanks.
Old May 14th 14, 10:25 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
At 02:14 14 May 2014, wrote: (snip)
no
Bob T
That is simply not true. Whilst not commenting on the specifics of this
accident the outcome has provoked a serious discussion on the procedure to
be adopted following a launch failure at low level.
There are those who have argued passionately, that a turn back, even from a
low starting height is a viable and safe option providing the best chance
of a good outcome. There has been a deal of opinion that in these
circumstances we should consider doing something, turning downwind at very
low level, which we would never ever consider doing in normal operations.
Observing a pilot making the 90 degree turn from base to finals at such a
low level would result in a very one sided conversation at many gliding
sites. Loss of control below 300 ft, let alone 200 ft, is only ever going
to end one way.
There are those who have argued that a much safer option in to land
straight ahead, or slightly to one side even if the terrain is difficult,
aiming to ensure that the fuselage survives the landing, even at the
expense of damage to other parts. The argument to support this is that a
controlled descent with wings level is far more likely to have a better
outcome than getting the low turn wrong. There are fewer items to
concentrate on with more time to monitor the basic need of keeping the
glider flying with sufficient airspeed to ensure a controlled landing. A
much simpler approach and one likely to be easier for low hours,
inexperienced and low currency pilots.
The basic questions to ask in deciding which is the best option is, "Will
pilots of ALL skill levels and currency be best served by a simple or
complicated procedure?" "Is creating a mindset that turning downwind is the
best option suitable for all conditions?" and "Does the procedure adopted
offer the best chance of survival of the pilot, even at the expense of
glider damage?". I think most gliding supervisors will be able to answer
those questions, the only question remaining is will they be able to make
the right decision to implement what they have learned.
My personal view is that the low turn back is one complication, if not
several, too many for an average pilot and flies in the face of the basic
Aviate, navigate, communicate mantra. The last two should only ever come
into play once the first has been achieved and off a very low launch
failure there may never be time to get to the secondary priorities. The
teaching of a low turn back places more emphasis on the secondary priority
to the detriment of the first and creates a mindset that may lead to a less
positive outcome than a much simpler procedure. There will always be
exceptions to any basic procedure, in a few situations the basic procedure
may not be an option so other options will have to be considered. Those
exceptions should only ever be applied where and when they are necessary,
which does not invalidate the preference for a simple basic procedure.
I also think that arguing amongst ourselves, while useful in reaching the
best conclusion, carries the danger of entrenchment when it should promote
the adoption of best practice.
To say there is little to be learned is just plain wrong.
Old May 19th 14, 05:21 PM posted to rec.aviation.soaring
David Salmon[_3_]
no
Bob T
to
a
very
to end one way.
priority
less
procedure
promote
A good many years ago, my CFI had persuaded me to become an instructor, and
I confided in him that my only real concern, was allowing someone else to
be in control near the ground. He lent me Stick & Rudder by Wolfgang
Langewiesche, and suggested a chapter to read. This is not a gliding book,
but nevertheless there was lots of common interest. In particular was the
bit, actually written by someone else, and showing how forgiving aircraft
are when "crashing" under control. It is when they are not under control,
ie stalled or spinning when they hit the ground, that the occupants stand
the most chance of getting hurt, or worse.
The same lesson was passed onto me in my brief excursion into power
flying. In case of a relatively low engine failure, you land as near ahead
as possible, into whatever is available.
I can vouch for this from personal experience, having been in a straight
ahead aeroplane crash, not me flying it, I hasten to add, I was in the
back, and four of us walked away, as it went up in flames.
Dave
Old May 19th 14, 08:40 PM posted to rec.aviation.soaring
Bill D
no
Bob T
to
a
very
low level, which we would never ever consider doing in normal operations..
to end one way.
priority
less
procedure
promote
Dave
Langewiesche's point is correct as far as it goes. If the only choice is between crashing with the aircraft under control and crashing while out of control, being in control is always better. Duh!
However, I think your implied point is that if a pilot tries a turn, the aircraft will be out of control. Obviously, I disagree. If a pilot can't retain control while making a simple 180 degree turn, the situation was dire long before the emergency arose.
Now, lets define the "ground" you're going to crash into. Lets say there's a rock quarry off the departure end. Solid surfaces are vertical and all horizontal surfaces are water with no climb out options. The occupants will die in the crash or drown a few minutes later whether the aircraft crashed under control or not. My point is there are situations where no "straight ahead" option is available.
My situation isn't quite that bad - it's only water filled gravel pits. The only field proven landable is VERY small and requires a 90 degree turn at treetop level around a large tree. Turning back, when possible, is always the best option. It pays to be good at it.
The good news is gliders can turn back with generous safety margins. The wild card is the pilot.
Old May 20th 14, 02:46 AM posted to rec.aviation.soaring
Bruce Hoult
Exactly.
Let's just emphasise this again.
If the rope breaks at normal aerotow speed, you should be able to complete a 180º turn and be at normal safe final approach speed with as much or more height as the moment the rope broke.
The glider can. Easily.
Old May 22nd 14, 10:41 PM posted to rec.aviation.soaring
no
Bob T
to
a
very
to end one way.
priority
less
procedure
promote
Dave
Langewiesche's point is correct, period. Which option carries the best chance of retaining control, keeping the wings level or turning, especially at low level?
The primary concern is survival of the pilot, an undamaged glider is a long way below this fundamental priority.
We have all witnessed instructors who like to scare their pupils witless by carrying out risky procedures, such behavior has no place in responsible aviation, but we all know it survives because of the intransigence of those who refuse to accept that we are there to teach safe flying.
Ignore the KISS mantra at your peril.
Old May 22nd 14, 11:55 PM posted to rec.aviation.soaring
Bill D
no
Bob T
to
a
very
to end one way.
priority
less
procedure
promote
Dave
Neither or both depending solely on the ability of the pilot. Turns don't stall gliders - pilots do. Pilots with real flying ability have the "best chance" of retaining control.
So, you say that instructors who teach a maneuver required by the FAA Practical Test Standards as covered in detail on page 8-11 of the FAA Glider Flying Handbook are "witlessly" carrying out "risky procedures" to "scare their pupils"? That's about as absurd as r.a.s ever gets - which is saying a lot. You better hope the instructor who gives you your next Flight Review didn't read your post.
Old May 23rd 14, 03:15 AM posted to rec.aviation.soaring
WAVEGURU
I agree with Bill. If you are scared witless by an instructor pulling the release at 200ft you have no business flying a sailplane solo.
Boggs
Parowan Fatal Crash ContestID67[_2_] Soaring 30 July 3rd 09 03:43 AM
Rare fatal CH-801 crash Jim Logajan Home Built 8 June 22nd 09 03:24 AM
Fatal crash in NW Washington Rich S.[_1_] Home Built 1 February 17th 08 02:38 AM
Fatal Crash Monty General Aviation 1 December 12th 07 09:06 PM
Fatal Crash in Fittstown, OK GeorgeC Piloting 3 March 7th 06 05:03 AM
