"trader_4" wrote in message
news:df3d9f0d-cc7f-4640-a592- On Monday, May 19, 2014 7:17:35 AM UTC-4, Robert Green wrote: This thread has helped explain why I believe the missing Malaysia flight might have suffered a cabin fire (that model plane had a known oxygen supply hose defect that caused a very serious fire on the ground in another plane). Again, that defect that occured in one other case, resulted in a cockpit fire at the pilots seat, while the airplane was on the ground. Let's say the same thing happened in MH370. How does that explain the airplane flying for about an hour more under radar contact, making precise turns, lining up with mormal flight paths toward India, and then later, making at least one more course change that took it to Australia? How does it miraculously result in the the transponder and ACARS being lost. And all this just happened to occur in the couple of minutes between being handed off by Malaysian ATC to Vietnam ATC, ie the ideal small, ideal window for deliberate human action? There's no explanation of events that can be proven or disproved until the wreckage is found. The pandemonium that can occur with a cabin fire can explain a lot of things that appear to be inexplicable. Reading about how fast cabin fires spread and how lethal they can be still makes me suspect a cabin fire because a pilot crashing a plane deliberately and silently doesn't make sense. He would *want* to get credit for his actions. Your small, ideal window could be total coincidence. There's just no way to know from the few facts that are available. If it was a cabin fire, there should be still some evidence recoverable to support that theory. If the FDR and voice recorder unit are found, it may prove your theory - or it may leave us with more clues but no firm answer because the voice recorder overwrites old data every two hours and the plane allegedly crashed 7 hours after takeoff. Critical voice information is most likely gone unless the CVR lost power early on in the flight. The most difficult part of the suicide scenario is that even Shakespeare's often long-winded dramatic characters got it over relatively quickly. People who survived jumping off the Golden Gate bridge change their minds half way down. Search for the 2003 New Yorker article about Golden Gate Bridge suicide jumpers. It's very enlightening. I just don't know of a single case where a guy took 7 hours to kill himself. It's an impulsive act that people want to get over with quickly. He left no note, no radio contact, no reasons given. That's pretty unusual for a suicide, especially one who appears as troubled as he's been made out to be. And his demonization by the press and the Malaysian government also bothers me. It's classic scapegoating. There are dozens of scenarios at this stage, but allow me to prefer those that don't point a finger at the crew or the pilot. Pilot suicide just doesn't make a lot of sense to me whereas a cabin fire in a plane KNOWN to have a serious oxygen hose defect seems far more likely. There's no record or mention I can find of the oxygen hose problem being corrected and I doubt Malaysia has a fully-functioning FAA equivalent to enforce maintenance fixes. I am also always totally suspicious of airlines and governments being quick to blame the pilots. It's an industry tradition used to focus attention away from any possible gross negligence on their part. So then explain how the plane continued to make the many reported course and altitute changes. Including ones an hour and beyone the alleged fire.... It just doesn't fit. "Reported course changes" really bothers me. If they had such detail course information, why where they searching, without luck, huge swaths of ocean? That model plane has not one but several automated systems that can fly the plane and are dedicated to keeping it airborne. There's no main computer to fail, like some "Star Trek" scenario. There are lots of independent systems connected through data buses. Considering how badly my PC acted up when the space heater accidentally started blowing on it I have no problem believing a fire damaged autopilot could do a lot of things that looked like a human was at the controls. Since autopilots are capable of executing almost every command a pilot could issue, changes in course don't prove there was a person issuing them. If the cabin's filled with cyanide gas, death for everyone would occur in very short order. That's not true. There are portable oxygen tanks for the crew to use. You're forgetting that it was precisely those tanks and their fittings that caused the disastrous oxygen-fed fire on a different plane of the same model. A fire that would not have been survivable had it occurred aloft. A fire that turned the cabin's electrical gear into a mass of fused plastic and wire. http://i.dailymail.co.uk/i/pix/2014/...70_634x478.jpg Also the passengers have oxygen for long enough to bring the plane down to 10,000. Can *they* fly the plane if the pilots burned to death in a flash cabin fire? Maybe one of them was poking around with the charred autopilot after the flames were extinguished and those actions caused the alleged course changes. We may never know. One thing's for certain: without the wreckage there's never likely to be conclusive proof about what happened to that airplane, so we're just spinning our wheels. Just like you can't testify to the operation of someone's mind in court, you can't determine if the pilot was suicidal or homicidal by counting the number of course changes a plane *allegedly* made after radio contact was lost. If there was a fire, the pilots would have tried to deactivate cockpit components by pulling the electrical busses. That *easily* explains why cockpit based systems failed first and other, more remote systems continued to function. If it was the pilot's emergency oxygen supply that caused the fire, then their chances for prolonged survival amidst toxic fumes are very poor. Without the data and voice recorders or forensic evidence from the wreckage, it's all supposition. I base mine on a previous very serious oxygen fed cabin fire in an identical model and on Payne Stewart's flight to nowhere with a plane full of dead passengers. Yes, that plane flew in a straight line after all the passengers and pilot died from a pressurization malfunction, but the 777 has a far more sophisticated autopilot. If the Apollo oxygen-fed (aka a "blowtorch") fire killed everyone in the capsule in 17 seconds, a fire like that doesn't leave much time to call the ATC tower and tell them about an event they couldn't do anything about anyway from 100's of miles away. The pilot's primary duty at that point is to keep the plane flying, not to alert ATC. Pilots have a mantra for setting priorities in an emergency: aviate, navigate, communicate. The worst part is that they may never find the wreck. It took two YEARS to find the AirFrance wreck and they basically knew where it went down. But if they do find MH370, we may see which one of us is the better guesser, because that's all we can do. Guess. There just isn't enough information available to reach any valid conclusions other than the plane is lost. -- Bobby G. |
On Tue, 20 May 2014 06:55:42 -0700, Robert Green
wrote: ...snip.... The most difficult part of the suicide scenario is that even Shakespeare's often long-winded dramatic characters got it over relatively quickly. People who survived jumping off the Golden Gate bridge change their minds half way down. Search for the 2003 New Yorker article about Golden Gate Bridge suicide jumpers. It's very enlightening. ...snip... Complicating are economic pressures: Plane failed == extremely costly liability. Pilot Error == no liability. And from experience having a pilot friend accused of fuel exhaustion when it was a casting flaw in the carburator suddenly appearing where he was 'guilty until proven innocent'; you'll see more Pilot Errors causing crashes than mechanical failures. |
On 21/05/14 02:30, RobertMacy wrote:
On Tue, 20 May 2014 06:55:42 -0700, Robert Green wrote: ...snip.... The most difficult part of the suicide scenario is that even Shakespeare's often long-winded dramatic characters got it over relatively quickly. People who survived jumping off the Golden Gate bridge change their minds half way down. Search for the 2003 New Yorker article about Golden Gate Bridge suicide jumpers. It's very enlightening. ...snip... Complicating are economic pressures: Plane failed == extremely costly liability. Pilot Error == no liability. And from experience having a pilot friend accused of fuel exhaustion when it was a casting flaw in the carburator suddenly appearing where he was 'guilty until proven innocent'; you'll see more Pilot Errors causing crashes than mechanical failures. Yup. Its always easier to blame the pilot as in most cases they're dead. And sometimes the Accident Report is so wrong that the Coroners Report is taken as being the truer record |
Man eats own leg to survive car accident | The Raven | Aviation Photos | 4 | February 9th 07 07:13 PM |
airplane crash, how to overcome | bekah | Piloting | 20 | May 21st 05 01:14 AM |
Cabin aide recalls airplane crash horror | NewsBOT | Simulators | 0 | February 18th 05 09:46 PM |
Homebuilt Airplane Crash | Harry O | Home Built | 1 | November 15th 04 03:40 AM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
