Actual Rope Break
Old June 2nd 14, 12:35 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default Actual Rope Break
At 23:20 01 June 2014, Kevin Christner wrote:
I had my first "rope break" ever today. I was approximately 200-250ft
abov=
e the ground. Emergency procedures were not a problem.
The Tost released for some reason. Its a nose hook so the back release
mec=
hanism could not have been the culprit. Further testing with the wheel
bre=
ak on the ground revealed no problems so I took another tow and had no
prob=
lems. The ring may not have been engaged properly (doubtful) or the
slack
I got in the rope was just too much when it tightened back up (probable
but=
the release still should have held).
In any case has anyone else ever experienced an actual emergency
unplanned
release? In 14 years of flying I have never heard of one. Good thing we
d=
o practice this. =20
2C
Most common cause is a broken spring. If the spring breaks on one side it
will still close the hook but with insufficient tension. This can cause
intermittent failures.
Rope Break! Waveguru Soaring 9 August 28th 12 03:17 AM
Rope Break Walt Connelly Soaring 4 April 12th 11 09:04 PM
Explanation Required: ATA (actual time of arr) and ATD (actual timeof dep) SVCitian General Aviation 2 September 19th 10 10:27 PM
Actual Autos Ol Shy & Bashful Rotorcraft 3 April 26th 07 04:22 AM
IR without actual IMC Iain Wilson Instrument Flight Rules 26 October 13th 03 11:26 PM
