Whether or not positive action is required to maintain airspeed
depends on the trim; this will be different for nose and belly hooks. A belly hook on some ( older ) gliders requires nose down trim to balance the rope force. JMF At 11:31 15 June 2014, Bruce Hoult wrote: On Sunday, June 15, 2014 6:09:22 PM UTC+12, 2G wrote: PLEASE stop with the sanctimonious crap! I have done hundreds of aerotows= .. You need to lower the nose because you are in a climb attitude and need t= o transition to a glide attitude. On your next tow note where the horizon i= s on the canopy and compare it to where it is after release at the same air= speed. While the nose ends up lower, you don't lower the nose. The decrease in air= speed does that for you, and the movement of the stick is rearward, to prev= ent the nose falling through into a dive and again attaining the aerotow ai= rspeed. |
On Monday, June 16, 2014 12:21:16 AM UTC+12, firsys wrote:
Whether or not positive action is required to maintain airspeed depends on the trim; this will be different for nose and belly hooks. A belly hook on some ( older ) gliders requires nose down trim to balance the rope force. Yes, I have 60 or 70 hours PIC from aerotow (and a few flights on a winch) in an original model Janus, with only a belly hook. To be honest the only time it is really noticeable on aerotow is if you have slack rope and it comes tight with a jerk. It pays to be ready with forward stick, or even anticipate it. But in any case, the removal of that nose-up force at tow release makes it even more certain that you'll be moving the stick rearwards after release. That model is far more of a handfull on the winch, as the hook is really too far forward for good winching. It takes a lot of up elevator to keep the climb steep enough. The all moving tailplane means that it's easily possible to over do it and stall the elevator. And if you get a premature release then you're sitting there nose up with the stick most of the way back. *Definitely* need a positive check forward to neutral stick in that situation! |
Parowan Fatal Crash | ContestID67[_2_] | Soaring | 30 | July 3rd 09 03:43 AM |
Rare fatal CH-801 crash | Jim Logajan | Home Built | 8 | June 22nd 09 03:24 AM |
Fatal crash in NW Washington | Rich S.[_1_] | Home Built | 1 | February 17th 08 02:38 AM |
Fatal Crash | Monty | General Aviation | 1 | December 12th 07 09:06 PM |
Fatal Crash in Fittstown, OK | GeorgeC | Piloting | 3 | March 7th 06 05:03 AM |
