At 11:31 15 June 2014, Bruce Hoult wrote:
On Sunday, June 15, 2014 6:09:22 PM UTC+12, 2G wrote: PLEASE stop with the sanctimonious crap! I have done hundreds of aerotows= .. You need to lower the nose because you are in a climb attitude and need t= o transition to a glide attitude. On your next tow note where the horizon i= s on the canopy and compare it to where it is after release at the same air= speed. While the nose ends up lower, you don't lower the nose. The decrease in air= speed does that for you, and the movement of the stick is rearward, to prev= ent the nose falling through into a dive and again attaining the aerotow ai= rspeed. The expression you are looking for is "select the approach attitude". That should be the case after ALL launch failures. With the correct attitude selected the speed will eventually decay or increase to the correct value. By selecting the approach attitude you will ensure that the speed is less likely to reduce below the desired value in any turn. Of course if the failure occurs at height it may be that normal glide attitude is more appropriate and this can be selected at the appropriate time but the initial selection should always be approach attitude. KISS |
Parowan Fatal Crash | ContestID67[_2_] | Soaring | 30 | July 3rd 09 03:43 AM |
Rare fatal CH-801 crash | Jim Logajan | Home Built | 8 | June 22nd 09 03:24 AM |
Fatal crash in NW Washington | Rich S.[_1_] | Home Built | 1 | February 17th 08 02:38 AM |
Fatal Crash | Monty | General Aviation | 1 | December 12th 07 09:06 PM |
Fatal Crash in Fittstown, OK | GeorgeC | Piloting | 3 | March 7th 06 05:03 AM |
