Ventus 2C main wheel inner tube. Short stem or long stem valve ?
Old June 30th 14, 06:55 PM posted to rec.aviation.soaring
Default Ventus 2C main wheel inner tube. Short stem or long stem valve ?
A quick question:
On a Ventus2C main wheel inner tube, does it require a long or a short valve stem ?
How to identify what is in there right now, without disassembling the main wheel ?
Looks like the main wheel is a standard 5 inch Tost wheel with disk brake.
3U
Old July 1st 14, 06:07 AM posted to rec.aviation.soaring
Tim[_10_]
short TR87
also TOST come out with a special tire for the later Discus / Ventus gliders
due to the standard 500x5 tires rubbing on the gear frames...Wings & Wheels
should ahev both these tires and innetr tubes in stock.
tim
A quick question:
valve stem ?
wheel ?
3U
valve stem thread length too short [email protected] Soaring 3 August 12th 13 04:05 PM
ASW-24 Main Wheel Removal Lauren Rezac Soaring 5 March 19th 12 04:20 PM
Glider Main Wheel Dolly Jim[_18_] Soaring 0 March 9th 11 04:19 PM
main wheel dollies, plans? [email protected] Soaring 1 July 18th 07 06:55 AM
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price valvetom Piloting 0 November 28th 06 02:25 AM
