Houston crash today
Old July 15th 14, 01:10 AM posted to rec.aviation.soaring
Ramy[_2_]
Default Houston crash today
The other one the same day at Truckee was not a fatality thank god. Pilot is recovering well.
Old July 15th 14, 02:09 AM posted to rec.aviation.soaring
That was at least the third crash of a JS1-C this year, the first was a fatality in South Africa back in January. The report I saw was sketchy, but highly experienced pilot (glider and otherwise), high winds, and likely stall/spin. I don't know how many have been made, so far, but while it may be a higher than usual accident rate, it could just be sad coincidence.
Old July 15th 14, 02:23 AM posted to rec.aviation.soaring
Are there any details online about the Truckee crash?
Old July 15th 14, 02:51 AM posted to rec.aviation.soaring
Kevin Christner
This reminds me... Why does anyone think it's safe to spin a Puchcaz?
Old July 15th 14, 03:34 AM posted to rec.aviation.soaring
The history of stall/spin accidents claiming experienced glider pilots has become a phenomenon which I believed is unequaled in any other aspect of modern aviation safety. Everyone is CONTINUALLY warned and it continues at an incredible rate!
Old July 15th 14, 04:37 AM posted to rec.aviation.soaring
There is not to my knowledge any indication that the Truckee accident was a stall/spin. What little reporting I've seen points in a somewhat different direction. It's mostly speculation right now so take care.
Old July 15th 14, 07:48 AM posted to rec.aviation.soaring
Eric Munk
If you can't spell it, don't spin it.
Old July 15th 14, 09:36 AM posted to rec.aviation.soaring
Kevin Neave[_2_]
OK, I'll bite.
Why do you think it's NOT safe to spin a Puchacz?
And do you think it IS safe to spin a K21?
KN
Old July 15th 14, 11:22 AM posted to rec.aviation.soaring
Kevin Christner
As of January 2004 Cindy B. had identified 23 fatal spins or over 1/8 of the fleet. A high proportion of these were fatal and several involved 2 CFIGs at the controls. A few searches will yield a couple more since then.
To my knowledge K21s are permitted for spinning. Don't they have a tail ballast box for that purpose? I believe something over 1000 have been built. I don't think 125+ have plowed into the ground.
Old July 15th 14, 11:48 AM posted to rec.aviation.soaring
Eric Munk
If a glider does not spin (like an unmodded ASK-21), it will not be
involved in a spin-related accident. Unfortunately pilots do spin.
Sometimes even if they don't want too. And most aircraft they fly after
their training on ASK-21's do too.
Crash at MYF today.... [email protected] Piloting 45 February 1st 07 12:37 AM
F-15E Crash today John Doe Military Aviation 0 May 7th 04 04:42 AM
Houston Area Air Crash Ludlow Johnson Piloting 2 November 20th 03 03:10 PM
Wildcat crash in Houston Wright1902Glider Home Built 3 October 27th 03 09:24 PM
Wildcat crash in Houston Wright1902Glider Restoration 0 October 21st 03 03:38 AM
