Houston crash today
Old July 15th 14, 11:22 AM posted to rec.aviation.soaring
Kevin Christner
Default Houston crash today
Why do you think it's NOT safe to spin a Puchacz?
As of January 2004 Cindy B. had identified 23 fatal spins or over 1/8 of the fleet. A high proportion of these were fatal and several involved 2 CFIGs at the controls. A few searches will yield a couple more since then.
And do you think it IS safe to spin a K21?
To my knowledge K21s are permitted for spinning. Don't they have a tail ballast box for that purpose? I believe something over 1000 have been built. I don't think 125+ have plowed into the ground.
Old July 15th 14, 11:23 AM posted to rec.aviation.soaring
JS
My speculation:
I would fly a JS1 again.
As will the pilot involved in the Truckee accident.
Old July 15th 14, 11:26 AM posted to rec.aviation.soaring
Kevin Christner
Given the current unknowns about the two JS1c fatalities its a bit of a stretch to say that.
Beyond that rudder pedals slicing through cables
http://www.ntsb.gov/aviationquery/br...01X72635&key=1
I can find no recommended action on the manufacturers website.
Old July 15th 14, 11:48 AM posted to rec.aviation.soaring
Eric Munk
If a glider does not spin (like an unmodded ASK-21), it will not be
involved in a spin-related accident. Unfortunately pilots do spin.
Sometimes even if they don't want too. And most aircraft they fly after
their training on ASK-21's do too.
Old July 15th 14, 12:06 PM posted to rec.aviation.soaring
Piotr Szafranski
Sorry to continue OT, but Kevin, is there a study of Puchacz accidents (comparing to other types) which takes into account what percentage of Puchacz (vs. other types) flights are to perform spin recovery training? If you know the source I would be grateful. To not to clutter the thread, you may e-mail me
"piotr dot szafranski at gmail dot com"
Old July 15th 14, 01:01 PM posted to rec.aviation.soaring
Kevin Christner
I can't say I know of a study. You could have a point. But when very experienced pilots are being killed on a regular basis it begs the questions 1) is this a safe glider for spin training and 2) should we be doing such training at all.
I have not seen a report of such a high percentage of incidents in any other glider, such as an L-13, which had many multiples of the number of Puchaczs in service.
  #28
Old July 15th 14, 02:46 PM posted to rec.aviation.soaring
Eric Munk
By heart by far the most of the accidents you mention were from inadvertent
spins. Cable breaks, turn to final, etc. Plus some while doing spin
training.
Having flown the Puch for spin training quite a lot, I can say it spins
quite well, and recovers quite well. The only drawbacks are the relatively
short warning time when inducing a spin from a slightly nose-up slipping
turn. ANd the delayed recovery when spinning with an aft CoG or improper
recovery techniques.
  #29
Old July 15th 14, 03:28 PM posted to rec.aviation.soaring
Kevin Christner
The Puch may be recoverable 999 times out of 1000. Unless an airplane is recoverable 1000 times out of 1000 no one should be spinning it.
  #30
Old July 15th 14, 04:26 PM posted to rec.aviation.soaring
Any glider will do the part of the spin that will kill you, even if it does not enter a sustained spin.
Some are simply more tolerant to pilot error.
UH
Crash at MYF today.... [email protected] Piloting 45 February 1st 07 12:37 AM
F-15E Crash today John Doe Military Aviation 0 May 7th 04 04:42 AM
Houston Area Air Crash Ludlow Johnson Piloting 2 November 20th 03 03:10 PM
Wildcat crash in Houston Wright1902Glider Home Built 3 October 27th 03 09:24 PM
Wildcat crash in Houston Wright1902Glider Restoration 0 October 21st 03 03:38 AM
