Naval Air Refueling Needs Deferred in Air Force Tanker Plan
Old May 10th 04, 02:42 AM
Guy Alcala
Kevin Brooks wrote:
"Guy Alcala" wrote in message
Kevin Brooks wrote:
snip
Kevin, while it's highly unusual for me to support anything that HJC puts
forward, I find the article in question pretty accurately reflects the
issues.
A boom typically has double (or more) the transfer rate of a
drogue/fighter-sized probe.
Yep.
That's why the USAF decided to adopt them in the
first place, for SAC's bombers, so that refueling took much less time.
Single
point drogues are better than nothing, but just as the article says, they
limit
the size of the strike flight (or require far more tankers), because the
first
a/c to refuel has used up most of the fuel it has received by the time
that the
last guy is done.
Yep.
From DS on the USN has relied increasingly on USAF and
foreign land-based tankers, because their own tankers lack the
numbers/offload/loiter/drogue stations to allow them to go far inland
with
large strikes. The USMC has its KC-130s, which are at least dual-point,
but
they're limited to perhaps 6 a/c in a flight pre-strike, with four
preferred,
before they meet the law of diminishing returns. A single-point boom
tanker is
about the same. It's not that the navy can't use their S-3s or F-18E/Fs
exclusively, it's just that they're limited in the size/radius of their
strikes
when they do so.
Which is why the USAF will still have the capability of supporting the USN,
with both single and dual point refueling. The fact that the 767 won't have
that multi-point capability up-front is NOT going to create a critical
situation for the USN.
But it may be critical for bed-down and other operational issues, and it's
definitely inefficient. Besides,who says we're only supporting the USN? In
various conflicts we've had help from Canadian and Spanish Hornets, plus the
RAF, AMI, KDF, RNAF, Luftwaffe etc. They've helped us with _their_ multi-point
tankers on occasion.
Given our increasing jointness, it does seem odd that the KC-767 isn't
planned
to have provision for wing drogues from the get-go.
Not necessarily. The USAF is getting to the desperation point in regards to
the 135E's--they are either going to have to poop a lot of money to upgrade
them (not the wisest choice, given their age and condition), or they have to
get a replacement in the air, and rather quickly.
The justification for that has always been somewhat questionable. Only a few
years ago they were projecting the 135E's fatigue life out 30 or 40 years,
although the engines were probably going to need replacement. Let's face it,
the 767 deal has more than a little to do with keeping Boeing's 767 line open
and people employed. Would it be a good thing to get some newer tankers?
Sure. Do we need them right now, because the 135Es are falling apart? That's
arguable.
That last part (quickly)
seems to merit a sort-of-spiral approach, to me; get them into service ASAP
with the boom and single-point drogue (while still having the 135R's in
service, some with the multi-point hoses), and then worry about bringing
them up to a higher standard later, when the time-crunch is not so critical.
I see it as entirely budget-driven, with the huge bow-wave they've already got
going restricting them. Indeed, that was the primary reason for the KC-767
lease rather than buy in the first place.
It's clearly an
inter-service budget issue, but single point drogues just don't cut it for
big
strikes; if they did, we wouldn't have fit out those KC-10As and KC-135Rs
for
wing drogues (Flight Refueling MK.32s IIRC). It's a simple matter of fuel
throughput per unit time.
Which KC-10's and KC-135R's will still be serving, you should add. Correct
me if I am wrong, but the aircraft that the 767's are destined to replace,
the 135E's, do not have the multi-point refueling capability, either, do
they?
No, they don't, and the 767's will at least be able to refuel both types of
refueling systems on the same sortie, and they'll have a proper drogue rather
than that ******* afterthought on the end of the boom. OTOH, we're also buying
fewer of them than the 135Es they're supposed to replace (differing MC rates
obviously play a part). But in big strikes, it's the number of refueling
drogues/booms in the air that determine the service rate, and it's silly to have
to use (and bed-down) double the number of a/c if we don't need to.
Large, land-based drogue tankers should have at least
two drogue stations, with three preferred (see the Victor K.2; there was
even a
USN Convair seaplane with FOUR drogues):
http://www.aviation-history.com/convair/tradewind.html
Less than two drogue stations is not making use of a large a/c's wingspan.
Naturally, they don't all have to be fitted with them all the time, as
there is
a weight, drag and maintenance penalty, but they sure as hell should be
capable
of fitting them. Hell, Boeing is even talking about a BWB tanker with two
_booms_.
So what you are saying is that we should delay the program even further than
it already has been, so that all of the new aircraft are capable of
performing a mission that only a certain portion of the joint force (the USN
strikers and whatnot) can receive from them the same level of support...that
they can already get from the other aircraft that will be remaining in
service? I don't necessarily agree with that analysis (and neither does the
USAF, apparently).
I'm saying that it makes far more sense now to buy the capability up front that
we know we'll be adding down the road, especially since the R&D work is largely
being paid for by Italy and Japan, than to add it years from now when we know
it's going to be more expensive to do so. If that means we buy a/c at a slower
rate (and more refueling pods), good. We plan to be operating from more austere
bases, which tend to be somewhat limited in ramp space, so anything we can do
that limits that is a plus. That was indeed one of the USAF's arguments against
the A330 -- that it took up too much ramp space while providing no more
refueling stations than the 767. They considered the A330's somewhat greater
offload irrelevant for the tactical refueling mission; they were concerned with
the number of booms/drogues on station while minimizing the ground footprint. If
that logic is valid, then buying dual rather than single-point capability is
even more valuable as a way of minimizing the ground footprint. See below.
snip
So what? Your "source" says the USN *requires* multi-point tanking
capability--and that plainly is NOT the case.
For most of the deeper missions, including most of the combat missions
that have
been flown from DS on, they do. If they aren't going very far, and/or are
using
small strike packages at fairly wide intervals, they don't. Neither has
been
typical of USN combat ops for the last 14 years.
Then maybe they need to fork over some bucks for some additional multi-point
pods for the KC-135R's... In actuality, that would probably be the best
solution anyway--they would get their improved support capability a lot more
quickly that way (versus waiting for the 767's to come on line).
I completely agree.
So is the
USN really concerned about the level of tanking support they can count on,
or are they just posturing for the purpose of budget fighting?
As I said, there's a question of interservice budgeting, and who pays for what.
Another
thought--the USN has been buying C-40's of late--if they are so keenly
worried about their refueling capability, why did they never think about
including a secondary tanker role for that aircraft, or that class of
aircraft, such that they could help themselves out? Probably not, because
that would have required them to spend their own part of the budget
pie...much better to have the USAF spend their money, eh?
I'm sure they think so. OTOH, FAIK the USAF would have fought against any such
proposal with tooth and nail. The navy has in the past considered buying their
own land-based tanker fleet, but ISTR that SAC (at the time) in effect said
"over our dead body." IIRR the Tradewind was an attempt to get around that;
after all, the USAF could hardly complain about seaplanes.
I imagine AMC would act similarly proprietarily today, but the point (to me, at
least) isn't which service provides the capability, but that it be provided.
snip area of general agreement
Clearly you can
get a force of tankers in theater a lot faster than a force of tankers
PLUS a
force of fighters and all their support.
Can you? I am not sure about that (note how quickly we got the lead
squadrons of the 1st TFW into Saudi Arabia in 1990), especially since
getting all of those tankers into the theater is only going to do you some
good if the fuel for them to haul is also present, or readily available, at
that operating location.
The 1st TFW had an A/A role, IIRR deployed with a full loadout of missiles on
thea/c and could fairly easily bring an adequate number of reloads with them, or
fly them in later. A/G ordnance can be a very different matter, although PGMs
help that aspect. I can't remember if it was the A-10s or F-15Es, but in one of
Smallwood's books (I think), aircrews described just how limited their A/G
ordnance options were right after they deployed. Fuel, OTOH, is relatively
available anywhere a commercial airliner is able to operate from. Maybe you
need to haul in JP-5/8 for the tactical a/c, but the tankers themselves should
be able to operate on Jet A/A-1.
How much more trouble is it for the USAF to put a
force that could easily surpass the per-day delivered-tonnage capability of
a CVSG (given your premise that the CVN is having to operate from extended
range itself)?
If they've got sufficient time to get set up in advance, fine, but crises often
don't provide that kind of time. We've been lucky that most of our wars in the
past decade and a half (OAF somewhat excepted) have given us some lead time to
get ready.
Three or four B-1B's or B-52's alone can acheive that.
And provided you're willing to send them in without any SEAD at the start of the
war, and multi-hour cycle times are no problem, great.
OEF
demonstrated the use of both F-15E's and F-16's in conducting pretty long
range strike operations (from the PG around Iran, up to Afghanistan and back
again, at greater range than the CVN-based strikers were enduring).
Sure did. Using those USAF tankers with booms to maximise the transfer rate.
And it helped that we were already set up in the area flying Southern Watch
sorties. But we're not there now, although we do still have some presence in
the 'Stans, IIRC.
Worried
about an enemy air threat? Then you have your standoff attack systems, along
with B-2's. Yes, there are other issues (hauling in the bombs, etc.), but
they are not insurmountable (i.e., we still have a surface transport
capability, augmented by air transport assets).
Should we can the CVN's? No, of course not. But they can continue to operate
a few more years with the support of KC-135R's and KC-10's without HAVING to
have the 767's *optimized* for their very own use.
Provided we have sufficient space for all those tanker a/c in theater, fine, but
it's still wasteful to use two a/c and crews to do the job of one. Of course,
if you're cycling flights of two constantly through the tankers, no big deal,
but gorilla packages are another matter. And we may well need to help tank our
allies (assuming we have any). Many of them are buying their own multi-point
drogue tankers now, which helps both of us if they're along for the ride.
Guy
Old May 10th 04, 05:25 AM
Kevin Brooks
Kevin Brooks wrote:
snip
puts
issues.
Yep.
Single
they
limit
first
that the
last guy is done.
Yep.
with
dual-point,
but
preferred,
tanker is
F-18E/Fs
their
strikes
when they do so.
USN,
have
In
multi-point
And that help has been appreciated. But that does not really imply that we
have to optimize *all* of our aircraft to perform multi-point refueling
right *now*.
planned
to
upgrade
have to
few
it,
open
That's
arguable.
Firstly, "only a few years ago" was before we (again) had to surge tanker
support for two recent operations--that eats into remaining lifespan
(operating hours for the tanker force being about a third higher than they
were pre-9/11). Second, if you are going to replace the engines (and
associated controls), you are talking about a sizeable investment (witness
the never-ending debate over the wisdom of reengining the B-52's, C-5's,
etc.) right there. Then you have to remember that the E models have also not
undergone other avionics updates due to their age/limited lifespan
remaining, so if you want to keep them around you are going to have to do
the whole PACER CRAIG thing, etc. In other words, turn them all into R
models--which does not sound like a real wise investment.
It is beyond argument that the E models are the anchormen when it comes to
MC rate (about 78% for the E models, versus 82% for the R models, based upon
GAO figures for May 2003). Without reengining, and taking them up to the R
standard, this MC rate difference will only grow--it drops below 75% and I'd
think the USAF leadership will really start to howl. Corrosion maintenace is
another (growing) concern, and it will eat up more and more money as we try
to stretch out the E model's lifespan. Oddly, even the GAO noted that they
recommended that the USAF start paying serious attention to replacing the
KC-135 fleet as early as 1996 (of course, in typical GAO style, they have
managed to cover their bases in all eventualities, so they can always say,
"Told ya so!" regardless of how we proceed...).
ASAP
critical.
got
KC-767
The lease came about because it (a) allowed the USAF to recapitalize the
oldest portion of the tanker fleet in the most rapid fashion, and (b)
because it was also beneficial to Boeing in terms of keeping the 767 line
open. Don't act as if the latter is a "bad" thing--we have paced procurement
programs to keep assembly operations going for decades, be it the C-130 or
the M-1 tank. Consider how much MORE it would cost to *buy* the 767's if we
drag this out through the usual (overly long) procurement cycle, and the
line has in the meanwhile shut down; restarting a line is not going to be
cheap. Some folks cry that this is a "help out Boeing" deal--I don't agree,
at least completely, as it also helps out the USAF in getting timely
replacements for the aging KC-135 fleet; and to be honest, even if it *were*
more of a "help out Boeing" deal it would not concern me greatly, as I see a
necessity in our keeping alive the kind of combined commercial/military
transport production capability that we NEED to have, unless you are willing
to be 100% reliant upon a foreign provider for our future tanking and heavy
transport needs (I for one would hate to see the French government in a
position to slow down or stop delivery of such a critical asset merely
because they would want to show us they could do it).
It's clearly an
for
big
KC-135Rs
for
fuel
Correct
replace,
they?
of
rather
buying
rates
to have
That does not necessarily hold true. If the requirement to provide
hose/drogue capability in-theater is 8that* important in a given case, you
send the KC-10's and multi-point 135R's forward, and use the other aircraft
(i.e., these pre-improvement 767's) to handle the usual airbridge su[pport
operations into the theater. So what you really seem to be saying is that
the 767's, even without initial multi-point capability, offer an improvement
to the current level of support that can be afforded to the USN?
was
even a
wingspan.
there is
be
capable
two
_booms_.
than
USN
support...that
USAF, apparently).
that
largely
know
Whoah there, hoss. If the R&D is being picked up elsewhere (by virtue of
those foreign sales you mention), that advantage does not go away because we
dicide not to implement the multi-point system up-front. That R&D effort is
still applicable. And you are avoiding the fact that it will slow the
delivery timeline if we have to go with this optimization up-front.
Good? I disagree. So does the USAF, from what I have read.
do
against
greater
with
footprint. If
is
below.
In the long run, yes. But is it worth slowing delivery up-front even further
than it already has been slowed?
snip
that have
are
using
has
been
multi-point
more
I completely agree.
So is the
on,
what.
Another
because
such
their
that;
me, at
provided.
But they oddly don't have a problem with the USMC buying C-130J's to augment
their current tanker fleet. Personally, I doubt the USAF would have put up a
fight if the USN had said they wanted to incorporate a secondary refueling
capability in their C-40B's; just as the USN has been strangely silent over
the USAF talking about recreating an in-house stand-off jamming capability.
Clearly you can
tankers
PLUS a
some
at
on
them, or
PGMs
one of
relatively
you
should
As to fuel availability, I was referring to the ready availability of the
JP-8 in bulk form--and it won't necessarily be there (always) in the
quantity you want at those "remote" bases you refer to unless we haul it in
ourselves. Usually meaning by ship. A second ship can haul quite a few
pieces of ordnance, right? If you are tied to getting basic resources into
the TO, you might as well be "in for a penny, in for a pound". And yes, the
use of PGM's has resulted in a drastic reduction in the volume of ordnance
that has to be transported into the TO (ISTR Franks noting that during OEF
we were effectively engaging as many targets per day as we did during ODS,
with about 10% of the average daily sortie rate compared to the earlier
conflict). As we move towards use of the 500 pound JDAM, and even moreso the
SDB, the need for ordnance (in terms of volume/weight) will shrivel even
further.
of
extended
range itself)?
often
in the
time to
get ready.
I'd posit that using the basing options we already have in-hand (Guam, Diego
Garcia, Fairford, and CONUS), the B-1, B-52, and B-2 can acheive this pretty
much anywhere in the world *now*.
of the
I was playing devils advocate a bit here, but if you areally want to get
down to details, yeah, they could still provide a reasonable option. Use of
ALCM's to target IADS nodes/assets during the initial phase, with the
pending "electric" B-52 providing standoff jamming support, B-2's doing
their thing, and then as we start taking down the defenses, we can move a
bit closer and start using the other standoff systems (i.e., JASSM). Given
the range we saw the F-16's operate at during OEF, it would not be beyond
the realm of possibility for the F-15C's and E's to get into the ballgame at
long range, either (if they had to). As I have said a couple of times, I do
see a use for the CVN's--but barking that they just *have* to have every
tanker in the USAF at their beck-and-call does not do much to support the
argument that they are such a critical resource, does it?
OEF
long
back
rate.
Watch
in
the 'Stans, IIRC.
And are getting ready to relocate our NATO-assigned assets further east,
too, to places like maybe Hungary and Rumania, etc. In the Pacific we have
Guam, the ROK bases, Okinawa. Diego Garcia in the IO is the one that is
truly the most limited in terms of ramp space, but the bases in the -stans
you mention make it a bit less critical than has been the case in the past.
Worried
along
but
operate
HAVING to
fine, but
course,
deal,
tank our
multi-point
That last bit is true. But I think you may be forgetting that during
contingency operations we tend to have to operate a number of tanker tracks
a long way from the TO (i.e., the Atlantic air-bridge, or a Pacific version,
depending upon where the TO is), so those 767's could be a major contributor
without even having to enter the local airspace. The real issue is how long
we can drag out the 135E fleet; there are 131 of them remaining in service
now, with engines that were stripped from old commercial transports some
fifteen or twenty years ago as an "interim" fix, corrosion concerns, and
obscelescent avionics. Their MC rate can only really continue to drop, which
is why yes, we can replace 131 aircraft with 100 newer aircraft and come out
in pretty good shape. Do we have the time available to dally around with
optimizing the 767 in all manners before we order them (and run the very
real risk of seeing the line shut down in the meantime), or do we take the
money we have now and order the first 40 (which is the number the USAF has
tossed about as the first firm order volume) with the lesser hose/drogue
capability, and then implement the multi-point system on the following
aircraft, with the originals being upgraded at a later date? I see the
latter as an option that makes as much, if not more, sense than the former.
Brooks
Guy
Old May 13th 04, 08:44 AM
sid
"Kevin Brooks" wrote in message:
Brooks
Still clinging to the past I see Brooks
With the DSB report out the point is pretty much moot.
http://www.nytimes.com/2004/05/13/bu...partner=GOOGLE
With no civil orders forthcoming, Boeing isn't likely to keep the 76
line open beyond whats been ordered. Already marginalized in the
budget process, that does not bode well for the E-10 either.
Its time to move from the concepts of the last century anyway. As the
report says...
A page of the report, for example, calls for the Air Force to "work
with major airframe manufacturers to develop new tanker options" that
would have "more modern airframes" than the "20-year-old 767 design."
Instead of sinking money into old, orphaned airframes, it would be
much better to invest in something like the "MACK" or BWB that could
be optimized to operate and survive in tomorrow's ari threat
environment.
Potential adversaries are realizing that we are concentrating a very
signifcant part our ability to mount offensive operations into
rehashed airliners...even if the august members of this board don't
see it. They are doing something about it too...
http://www.indiadefence.com/collab.htm
Designed to fulfill the BVR (beyond visual range) role for "outer-air
battles", an aircraft usually of Sukhoi-27/30/35/37 "Flanker/Super
Flanker" family, equipped with KS-172 (also referred to as Article
172) would be able to engage ultra-high-value airborne platforms like
AWACS (airborne warning and control system), IFR (in-flight
refuelling) and LRMP (long range maritime patrol) platforms, without
necessarily having first to deal with their fighter escorts.
http://www.ainonline.com/Publication...1agatpg85.html
If used on a long-range missile airframe, the ARGS-PD could give an
opposing air force the ability to take out strategic targets at
distances outside of the normal interception envelopes of U.S. or
other NATO fighters. Boeing E-3 AWACS or E-8 JSTARS aircraft–platforms
that U.S. forces depend heavily upon in time of conflict–would be
vulnerable as never before.
http://arms.ashst.com/missiles/s400.htm
The S-400 system is intended to engage current and future air threats
such as tactical and strategic aircraft, Tomahawk cruise missiles and
other type missiles, including precision-guided ones, as well as AWACS
aircraft, at ranges of up to 400 km.
http://in.news.yahoo.com/031020/43/28nkk.html
"The FT-2000 surface-to-air missile (SAM), commonly known as the
'AWACS killer', designed by Chinese experts are considered to be the
most appropriate option if the U.S. refuses to provide the same kind
of Airborne Warning and Control System (AWACS) to Pakistan being sold
to India by Israel," The News said.
Old May 14th 04, 05:14 AM
sid
"Kevin Brooks" wrote in message ...
Brooks
report says...
environment.
Old May 14th 04, 07:32 AM
Guy Alcala
Sorry for the delayed reply -- it's been a busy week.
Kevin Brooks wrote:
snip
with
dual-point,
but
preferred,
tanker is
F-18E/Fs
their
strikes
when they do so.
USN,
have
In
multi-point
right *now*.
I never said they _all_ had to be optimized right _now_, but I can see no reason
not to buy new tankers set up that way from the start, as our need for drogue
tanking is clearly inceasing (cf. the proposed USAF F-35B buy).
planned
to
upgrade
have to
few
it,
open
That's
arguable.
were pre-9/11).
Yes, an increase from an average utilization of 300 hours/yr. to 435 hrs/year.
Even at the latter rate the KC-135Es have a fatigue lifespan of 82 years (36,000
hrs., vs. 39,000hrs for the KC-135Rs), and they're just a bit over halfway
through that.
We don't know that's the case, as we haven't done the assessment. Indeed, the
Defense Science Board just came out (see
http://www.airforcetimes.com/story.p...25-2904714.php
with a report that apparently says that upgrading some Es into Pacer Crag Rs may
well be the most cost effective solution, while we take a couple of years to do
a proper tanker requirements study. We apparently never finished the one we
started in 2001, and we're now talking about doing one that will run from 2004 -
2006. What the DSB has said is that there is no need to imminently replace the
Es - we've got time to look at our options. If you google on news and search
defense science board tanker
you'll come up with several sources that provides sniuppets of detail. The
actual report isn't available yet on the DSB website, apparently because it
hasn't yet been briefed to Congress.
The corrosion problem is apparently under control. See the URL above. From
what I recall of the GAO report, the O&M costs for the Es was averaging $4.6
million a year vs. $3.7 million for the Rs
ASAP
critical.
got
KC-767
One of the things I object to is the assumption, without any analysis, that the
767 buy is essential (the DSB says it isn't), or that it's the most
cost-effective solution (we don't know). Another thing that worries me about
rushing into a 767 buy is that we'll be buying an a/c that is essentially out of
production except for the USAF. The KC-135s were bought at the opposite
extreme. These a/c are going to last us at least 50 years, so spares are going
to be a real problem down the road, as the commercial operators are already
starting to look for replacements. Italy and Japan won't have a problem,
because they're each only going to buy airframes in the single-digits so they'll
be able to buy adequate spares from cannibalised airframes, but the USAF is
talking about buying at least 100, possibly with more to come.
When the 767 deal was first mooted, it was really the only in-production (US)
a/c in the size class available in the proper time frame. That is no longer the
case, as the 7E7 will be entering service in 2008 (this is a commercial a/c, and
unlike the military, missing production and/or performance guarantees cost the
company big bucks). We need to see if it makes more sense to buy 7E7s at the
_start_ of their production cycle, rather than 767s at the end of theirs. Which
is better suited for the role? Is the extra M0.05 in cruise a major advantage?
Does the higher composite content significantly decrease the corrosion issues
down the road? How about the 20% better fuel efficiency? Respective runway and
ramp space requirements? PFI vs. military? Etc.
snip
Correct
replace,
they?
of
rather
buying
rates
to have
I think KC-10s are too important as deployment tankers early on in a conflict to
use them in the tactical role. After all, that's what we bought them for,
precisely so we could get to the Middle East from the US non-stop, if we were
refused landing/overflight rights. Let's face it - being on good terms with
Portugal (Lajes) and Spain (Moron) has become more important to us than ever.
Besides, KC-10s take up a lot of space, and need stronger runways than 135s or
767s (don't know how the 7E7 stacks up), which may limit its deployment options.
Yes, they do, but the question remains, are 767s rather than upgraded Es and
later 7E7s the best way to go; what's the best mix, what % of tankers need to
do which roles, how will the advent of UCAVs affect the need for tankers and the
type mix, what effect will USAF F-35 buys have, etc. This needs to be properly
studied.
snip
than
USN
support...that
USAF, apparently).
that
largely
know
I'm aware that the R&D will still apply, I'm worried about the materiel costs,
which are only going to go up. If we need the capability, then let's just buy
it and get the purchase out of the way, instead of paying inflated prices later.
The DSB doesn't, and Rumsfeld said that he was waiting on a couple of reports,
including theirs, before making a decision.
do
against
greater
with
footprint. If
is
below.
According to the DSB, we have the time.
snip
Another
because
such
their
that;
me, at
provided.
Of course not, because a KC-130 (any flavor) clearly isn't a replacement for a
jet tanker. It meets USMC needs for a STOL tanker/transport that can also
refuel helos (AFSOC too), and for countries that also operate C-130s it's a
relatively cheap, easy way to get some A/A tanking capability; it's certainly
better than nothing, as Argentina can attest. But it's a relatively inefficient
tanker for fast jets, lacking range, speed, cruise altitude, and offload
capability.
There is no way in hell that the USN would pay the R&D NRE for a tanker mod for
their C-40s, with all their other needs.
Clearly you can
tankers
PLUS a
some
at
on
them, or
PGMs
one of
relatively
you
should
ourselves.
JP-5 presumably, if they're refueling navy a/c that are operating from CVs. At
least, that's my understanding, but maybe some of the KC-135 people here can
comment.
Sure, but getting fuel to an airfield is relatively easy (pipelines); moving
ordnance tends to require a lot more handling and surface transport.
further.
PGMs certainly help, but the problem is the variety of A/G ordnance that may be
required. A/A, there's two types of missiles and gun ammo. A/G, even with PGMs
there's lots of different kinds, and the usage rates are far higher.
of
extended
range itself)?
often
in the
time to
get ready.
In that case, let's dump the fighters altogether ;-)
of the
No one (or at least, not I) is claiming that they every USAF tanker has to be
available to support the USN, but clearly, an increase is required. IIRR, the
GAO report stated we used 150 KC-135s in OAF and OIF; given the large percentage
of USN/Marine plus allied sorties in both of those ops, having at best only 40
KC-135s with dual point drogues seems to be inadequate.However, if the tanker
requirements study says we don't need more, I'll accept it, but the study needs
to be _done_.
OEF
long
back
rate.
Watch
in
the 'Stans, IIRC.
The $64 million question being whether those bases will be available to us when
we need them. Last I checked there'll all in muslim countries with regimes that
are more or less unstable. Given our current unpopularity in the muslim world,
I don't think we should count on such bases being available.
snip
operate
HAVING to
fine, but
course,
deal,
tank our
multi-point
Or it might make sense to upgrade them all to 135R/Pacer Crag; I read one quote
somewhere of the cost savings going that route compared to the 767 buy -- AIR
it was a couple of billion dollars over the life of the deal. But that all
needs to be studied so we know.
As I've pointed out above, I think an even more fundamental question is should
we be buying the 767 at all, rather than some other option. The 767 lease is
looking more and more like roadkill, so it may be moot. However, even if we
decided to go the 767 route, there's no reason why we couldn't buy 35 of them
(or whatever the $ work out to) with wing drogues, rather than 40 without.
Guy
Old May 14th 04, 03:11 PM
Kevin Brooks
Kevin Brooks wrote:
snip
inland
with
dual-point,
but
preferred,
boom
tanker is
F-18E/Fs
their
strikes
when they do so.
USN,
won't
have
critical
it's
USN?
In
plus
multi-point
we
right *now*.
reason
drogue
That reason would be (another) delay in delivery. Why do you think it will
be such a major fiasco if the first forty 767's delivered come in without
the multi-point capability? IIRC the first contract is projected to cover
that number of delivereies. Letting a spiral handle the multi-point
capability in the subsequent 60 aircraft is not acceptable?
isn't
planned
regards
to
upgrade
have to
Only a
few
years,
face
it,
line
open
tankers?
That's
arguable.
tanker
they
were pre-9/11).
hrs/year.
(36,000
through that.
You are forgetting the corrosion problems with the E models--corrosion tends
to reduce fatigue life, too, IIRC from my long-ago materials science
classes... It sounds to me like the only way you are going to get that long
a life from the E's would be if you also replaced some structural components
(meaning you are going even further than the old R model mods, IIRC).
(witness
not
do
Rs may
to do
we
2004 -
replace the
search
e
it
Wait a second--spend *more* money on trying to upgrade E's, while doing
*another* study to determine if/when/how we replace the E's? That sounds
like a fine...bureaucratic solution? Even the GAO was saying in the 1990's
that the USAF needed to get off its duff and start planning the replacement
of the KC-135E fleet. Studies are great--unfortunately, they have a tendancy
of becoming an ends-unto-themselves. We have a good proposal that the USAF
has supported--it puts new airframes into the mission much more quickly than
if we follow the "usual" method of purchasing new aircraft (of course, you
could use the F/A-22 or F-35 model...which would mean if we started that new
study right now, we might plan on seeing some new tankers around what...2015
at best?), and it takes advantage of an existing excess production
capability/inventory at the only US company currently building aircraft of
that class--sounds like a good plan to me.
to
upon
R
I'd
maintenace is
try
From
$4.6
That is an additional $130 million bucks each *year* in operating cost (not
exactly chump-change...but even that is a "lowball" figure...). What would
be the operating cost of the 767? Less than the 135R (two engines versus
four, better fuel economy, more maintenance friendly subsystems, less
likelihood of inspection-and-repair work, more stringent (and more frequent)
inspections, etc.), that is for sure. So your operating cost per year
differential measured against the 767 is going to be greater. Add in the
cost of bringing those E's to a full PACER CRAIG R model level, and the cost
is going to be significant, to say the least. Not a wise investment plan,
IMO. If you managed your personal auto program in this manner, then you
would still be driving (only--no newer cars allowed) a 1960's era car, and
one which you had paid to drop new engines in, along with paying to modify
the emissions system to keep it in compliance (like the noise requirements
the KC-135's face), and here in 2004 you would be saying that instead of
buying a new vehicle, you'd be better off paying to essentially completely
rebuild the one you have and drop *another* new engine in it, along with
updating the other systems in the dash, maybe a new trannie to be compatible
with that new engine, etc. I don't think you would endorse such a plan (I
made the mistake once of trying to extend the life of a noble little Nissan
pick-up at the 170K point by dropping a *used* engine in it, and that was
*not* cheap--and I found that within 10K more miles I was *had* to break
down and buy a new vehicle).
As to corrosion, in March 2003 the USAF's Deputy C/S for
Installations/Logistics testified before Congress: "Within the air refueling
fleet, the KC-135E-models have experienced the most maintenance and
corrosion problems and are more costly to maintain. With an average
aircraft age of 43 years, the KC-135E fleet is the oldest combat weapon
system in the Air Force inventory. It is also the oldest large fleet of
heavy jet aircraft in aviation history...The second critical measurement
that defines aircraft life is physical age. In this fleet, corrosion is a
function of age. Accurately predicting the extent of corrosion is difficult
and this lack of predictability severely limits the ability to efficiently
sustain aging fleets...the KC-135 is particularly challenging since its
1950s design, materials, and construction did not consider corrosion
prevention measures...The most critical KC-135 tanker metric is age, and the
most pressing KC-135 problems are corrosion and stress corrosion
cracking-both age related. Stress corrosion cracking is one of the most
difficult structural failures to predict." Are you saying that all of these
problems have been solved since that date?
have
say,
service
ASAP
in
bringing
critical.
already
got
KC-767
line
procurement
or
we
be
agree,
*were*
see a
willing
heavy
that the
Well, the DSB also says the corrosion problem is something we can easily
discount, and has apparently decided that *outsourcing* the tanker mission,
or buying second-hand aircraft, is the way to go. Outsourcing may be great
for the RAF, etc., but the USAF is another story, IMO. Then there is the
"spend the money on already used aircraft" approach--wonderful! As if
tossing more money down the O&M pit for the E model is not enough, we should
take the money we have and buy older airframes than we can afford? (And yes,
we can afford new tankers under the current deal being offered)
about
out of
going
already
they'll
is
The biggest things you have to buy spares for are the avionics (which are
more plug-and-play than they were in the 135 era), and engine related
systems. There are a lot of 767's that will remain in service in the
civilian sector for decades to come--they will need spares too, and in the
end they become another source for spares for the KC version. I don't see
this as a deal-breaker.
(US)
longer the
a/c, and
Which
Not likely.
issues
down the road?
Maybe, but doubtfull, as corrosion awareness was better incorporated into
the 767 manufacture than it was in the 135.
Sounds good, but then again you have to examine the interval between the
time the 767 would be available and the (elsewhere not mentioned, AFAIK) 7E7
tanker version (expect what, a five or six year period at best before the
first tanker 7E7 could be available?)...I'll be kind and use a five year
period, at 131 E models costing maybe $2 million each more per year in
operating costs than the 767, that works out to around $1.3 billion in extra
operating costs? That is a hell of a lot of gas...
Lose the outsourcing option from the get-go, IMO. Won't work for an
organization with the scope of tanking requirements that the USAF has.
snip
Correct
replace,
either, do
they?
types
of
rather
also
buying
rates
refueling
silly
to have
you
aircraft
su[pport
conflict to
were
with
ever.
135s or
options.
I said, "If the requirement to provide hose/drogue capability in-theater is
*that* important". We have the capability of providing substantial
hose/drogue capability if we have to--if we really need more, then buy more
kits for the existing R's. No matter how you cut it, the decision to not
initially provide multi-point capability in the first forty 767's is not
going to be a critical, or even serious, failure in terms of our operational
capability.
improvement
and
need to
and the
properly
studied.
Again with the neverending studies? :-)
snip
further
than
(the
USN
support...that
in
does
USAF, apparently).
front
that
is
largely
we
know
because we
is
costs,
buy
later.
Even if it delays entry further, meaning you are also going to be paying
that higher O&M cost for the remaining E's even longer...?
reports,
I am not as impressed with the summary of the DSB report as you are (but
then again, I tend to weigh the advice of the folks actually tasked to fly
the missions a bit more than I do the DSB, GAO, etc).
can
do
arguments
against
more
greater
concerned
with
footprint. If
capability
is
below.
further
The DSB that claims, contrary to what the USAF LTG testified last year, that
the corrosion problem is readily in-hand...? And thinks out-sourcing tanker
requirements is a fine idea? I am not buying into either, at this point.
snip
Another
keenly
about
of
because
any
such
buying
their
that;
(to
me, at
provided.
augment
for a
a
certainly
inefficient
capability.
I remain unconvinced that AMC would throw a hissy fit if the USN wanted to
include a secondary tanking capability to its C-40B's.
refueling
over
capability.
mod for
Exactly. So the lack of multi-point refuelers must not be such a critical
one, eh?
Clearly you can
tankers
PLUS a
since
you
some
available,
at
missiles
on
with
them, or
although
PGMs
in
one of
A/G
relatively
Maybe
you
themselves
should
in
ourselves.
CVs. At
can
comment.
I thought we had standardized on JP-8 across the force--ISTR this came up
before, but I can't remember the final outcome. Regardless, be it JP-5 or
JP-8, you can't count on it being available in a remote operating location,
in the volume required, unless you plan on being able to haul it in
yourself.
moving
Lots of trucks available for lease out there in the world, even in a lot of
"remote" areas (any remote are having a pipeline capability likely has a
decent truck inventory available in the general area)--or you could use a
transportation company (60 line haul tractors and 120 40-ton trailers) from
the Army (one of our TC companies that was attached to my old BN HHD did
exactly that to support B-52 operations out of Saudi Arabia during ODS). If
none of this is doable in your opinion, then IMO you have just shot your
"gotta have multi-point capability" in the foot as well, since it would mean
that we can't plan on being able to operate the tankers within range of the
receivers in the first place.
ordnance
OEF
ODS,
further.
may be
with PGMs
I'd think if we have the ability to provide both categories of support
within the confines of a CVN and supporting TAKO (isn't that the acronym?)
for the assualt predicated, we also have the ability of transporting the
same quantity of fuel and ammo to an airfield on dry land. The increasing
use of PGM's even makes it a realistic option to deliver ordnance to the
base by air--something that was unrealistic in the dumb-bomb age (witness
the poor ability to do so over The Hump for the B-29's trying to operate out
of China during WWII).
capability
of
extended
range itself)?
crises
often
wars
in the
time to
get ready.
Diego
pretty
No, but consider maybe the option of letting the CVN provide only the
fighter and EW support (both requiring less tanking support than if they had
to provide the complete strike package), and you acheive even greater
tonnage of ordnance delivered per strike, and reduce that hose/drogue
requirement to boot... :-)
start
of the
of
a
Given
beyond
ballgame at
do
be
percentage
only 40
tanker
needs
to be _done_.
Then your cheapest, and quickest, solution goes back to merely buying more
multi-point kits for use by additional 135R's.
OEF
long
and
back
transfer
rate.
Watch
presence
in
the 'Stans, IIRC.
have
the -stans
past.
when
regimes that
world,
Then we adjust, and we have the CVN's as insurance--with those additional
modified R models, if needed.
snip
operate
HAVING to
fine, but
course,
big
deal,
tank our
multi-point
ride.
tracks
version,
contributor
long
service
which
out
quote
AIR
all
Argh! More study? Hell, just go ahead and plunk down the money and make them
all R's--we'll continue to pay the higher operating cost (even the R is
going to cost more to operate than the 767) for the next forty years--unless
wings start falling off, or the operating budget gets cut (not like that has
not happened, and rather recently (1990's) too), etc. Personally, I don't
see that as the best option.
Brooks
has
former.
should
is
we
them
Guy
Old May 15th 04, 12:37 AM
sameolesid
budget process anyway, that does not bode well for the E-10 either.
report says...
environment.
Old May 15th 04, 04:14 AM
Kevin Brooks
"sameolesid" wrote in message
om...
them
years--unless
has
don't
Well, you seem to be changing--your ID, that is. You still get plonked,
though.
Brooks
Old May 15th 04, 03:52 AM
Guy Alcala
snip, trying to keep the length down to a reasonable level)
In
plus
multi-point
we
right *now*.
reason
drogue
This assumes we need 767s at all, so I'll try and consolidate the discussion
below instead of handling everything piecemeal.
snip lead-in re 135 age versus 767
tanker
they
were pre-9/11).
hrs/year.
(36,000
through that.
classes...
Corrosion is an issue with any a/c -- certainly the KC-135Rs as well, which
(after all) were 135As before, just as the Es were.
Why is corrosion and fatigue on the Es supposedly so much more serious than the
Rs, when they all started out as 135As?
(witness
not
do
Rs may
to do
we
2004 -
replace the
search
e
it
What do you mean, _trying_ to upgrade the Es? We know perfectly well how to
upgrade them -we've got 400+ prototypes in service, after all, with the R&D all
paid for.
That sounds
Sure. It didn't say what to replace them with.
Who says we need new airframes _right_ now? As we both agree, buying more pods
and converting more Rs to carry them is the best solution in the short term to
the navy/Allies problem, while converting Es to Rs _may_ be the best solution
for increasing our tanker force in a hurry. Or it may not be, butsince the USAF
never did an Analysis of Alternatives (AoA), we don't know.
to
upon
R
I'd
maintenace is
try
From
$4.6
If most people maintained their cars the way that the military does its tankers,
and only drove them 1/10th as much as the average 'driver', then upgading
themwith new componenets might well be the most cost effective solution for the
long-term. The numbers I have seen quoted for the E to R (plus Pacer Crag)
conversion vs. new 767 comparison imply that the conversion is indeed the most
cost-effective option, but without knowing every assumption made I'll withhold
judgement.
Apparently they've been ameliorated to a considerable extent, so that this is no
longer a driving factor. And again, why is the E's corrosion problem supposedly
so much worse than the Rs, when they started from exactly the same airframe?
snip old ground
that the
discount,
Actually, I believe what they said was that the facility responsible for dealing
with it has learned to handle it so well that they are able to do the work much
quicker and cheaper than expected. I can't find the quote, unfortunately, but
I'm still looking.
They've said that it _may_ be the way to go, and:
"The report by the Defense Science Board says that, contrary to Air Force
claims, corrosion of the aging tanker fleet is "manageable" and several
options exist to refurbish the fleet.
If officials are willing to tolerate increased maintenance costs, "you can
defer major near-term . . . investments" to replace the tanker fleet, the
report said.
"There is no compelling material or financial reason to initiate a
replacement program prior to the completion of" a lengthy analysis of
alternatives and other studies, the report said. "
[Quoted from the Oregonian's Web page, May 13th. Sure will be nice when we get
access to the actual report, rather than summaries of it flitered through the
news media]
about
out of
going
already
they'll
is
Given that airlines are already looking to replace their 767s ( a 20-year old
design, let's remember) with the next generation, and given that world oil
production is predicted to peak sometime in the 2007 (the pessimists) -- 2040
(the optimists) period, considerably improved fuel consumption may well drive
the mass replacement of older a/c, just as the post 9/11 slump did. It's
definitely an issue.
(US)
longer the
a/c, and
Which
Not likely.
Depends on the specific mission, and more importantly, what percentage of the
mission spectrum does that particular mission occupy. There are missions now
where the faster KC-135 is better suited than a KC-767 would be, and others
where the latter comes out ahead.
issues
down the road?
And will be even more incorporated into the 7E7, especally since (AFAIK) there
is no corrosion of composites yet known.
Check out how much the KC-767 tankers cost.
Perhaps yes, perhaps no. Air bridge and training tanking doesn't require
military crewing. It's certainly an option worth looking at for at least some
tanking requirements, if not all.
snip lead-in, about fewer a/c to provide the same number of drogues
you
aircraft
su[pport
conflict to
were
with
ever.
135s or
options.
capability.
We agree that buying more kits for the Rs and/or modifying more than 45 Rs to
use them is probably the best idea in the short-term.
improvement
and
need to
and the
properly
studied.
What never-ending study? The USAF failed to do such a study in the first place,
especially an AoA. The latter was predicted to take about 18 months, but the
head of AQ&L (Wynne) says they'll probably push it and complete it by December
or so.
snip lead-in about buying multidrogue capability up front rather than adding it
later
because we
is
costs,
buy
later.
If that allows us to make a better decision for the long term, sure. We can get
upgraded Es (Pacer Crag Rs) into service faster than we can get 767s.
reports,
Seeing as how the DSB works for the Pentagon, and Rumsfeld is the guy who tasked
them to do the study back in February, I put a bit more weight on their advice
than you do. Especially since opponents of the 767 deal (McCain to thefront)
believed that the DSB was much too cosy with the military and Boeing (the DSB
Chairman had to recuse himself because he was also a paid Boeing consultant and
had been mentioned in internal company e-mails back in Dec.2002/Jan. 2003 as
willing to help push the deal), and fully expected them to support it. I
believe McCain's words were something along the lines of a "fox guarding the
chickens." So yeah, when even they come out and say they that we've got time to
do the study and the corrosion is manageable, I'm inclined to believe them.
can
do
arguments
against
more
greater
concerned
with
footprint. If
capability
is
below.
further
the DSB's claim is based on the USAF unit doing the corrosion controls data,
let's remember. The situation isn't static, and they've gotten better at it
since last year.
They're saying it's a viable option, it should be looked at in an AoA, and we've
got the time to do so. No more, no less.
Until the AoA is actually done, we have nothing to base a decision on other than
"because I think so," which IMO is a pretty poor way to spend billions of
dollars.
snip
augment
for a
a
certainly
inefficient
capability.
More likely, they'd suffer a rupture from laughing at the USN devoting such a
large proportion of its budget to paying the NRE for so few a/c of such limited
performance (as tankers).
refueling
over
capability.
mod for
one, eh?
Since no one else is even considering buying 737s as tankers, and the navy is
only buying a few (somewhere between 5 and 8, as best I can tell), the navy
would have to be nuts to make that kind of investment for so few a/c, even
assuming that they would be reasonable tankers. Given their limited
payload/range and performance, I have my doubts they would be, but it's moot.
fuel to forward bases
in
ourselves.
CVs. At
can
comment.
I believe either here or on s.m.n. someone stated that a/c couldn't be struck
below if they;d beenfueledwith JP-8, until they had been refueled several times
with JP-5. For land ops (training) the navy has gone to JP-8.
yourself.
Sure, which is why you'll need a tanker (the ship variety).
moving
Moving ordnance by truck requires offload from ships and lots of handling
equipment (Ro-Ro helps here), whereas every airfield of adequate size to handle
a jet tanker will already have a fuel delivery system in place. We'd only need
(assuming it's not a military field) to supply the fuel, not the delivery
system. Even assuming that the logistic infrastructure exists to move the
ordnance, it's still relatively slow, and requires a lot more organizational
effort to get things going than just pulling a tanker up to a pipeline terminal
and starting to pump.
ordnance
OEF
ODS,
further.
may be
with PGMs
In what time frame, and why would you want to move them again, when the CV
already has the infrastructure in place, lacking only sufficient tankers to
reach the targets? Down the road, sure we can start to bring in ordnance for
land-based air, but early in a conflict we've usually got the navy plus long
range USAF assets.
The increasing
They certainly allow us to start some level of sustained ops sooner, but we'll
need ship-transported ordnance quantities if we're having to deal with major
attacks.
snip
Diego
pretty
Certainly worth looking at, although the navy might object to having to convert
all their shiny new F-18Fs to F-18Gs already;-)
snip
do
be
percentage
only 40
tanker
needs
to be _done_.
And I've already said that I'm in agreement with this, especially so we can look
at if we even need the KC-767 vs. some other option. We apparently have 33
drogue kits for 45 KC-135Rs, so upping the number of kits to more closely
approximate the KC-135R MC rate, rather than the .73 rate indicated by the
above, should certainly be looked at for starters. Converting some Es to Rs and
adding the drogue kits at the same time won't take any Rs out of service.
snip
have
the -stans
past.
when
regimes that
world,
Agreed that more Rs is likely the best answer in the short run.
snip
fine, but
course,
big
deal,
tank our
multi-point
ride.
tracks
version,
contributor
long
service
which
out
quote
AIR
all
Argh! More study?
No, the same one that the USAF shoud have done back in 2001, but didn't.
I'm sure the operating cost will be higher, but then the purchase cost is a hell
of a lot lower. Fuel burn between a 135R and a KC-767's probably a wash;
CFM-56s in one and CF6s in the other, with the total thrust higher in the case
of the CF6s.
Guy
Old May 15th 04, 06:25 AM
Kevin Brooks
In
Hornets,
plus
_their_
multi-point
that
we
refueling
right *now*.
no
reason
drogue
will
without
cover
discussion
tanker
than
they
were pre-9/11).
hrs/year.
years
(36,000
halfway
through that.
tends
classes...
which
components
than the
I'd assume they are both going to exhibit corrosion problems, but didn't the
R's go through a significant IRAN as part of their upgrade? The USAF, per
those comments from the three-star last year, seems most concerned with the
E's.
(witness
C-5's,
also
not
to
do
R
Indeed,
Crag
Rs may
years
to do
one
we
from
2004 -
replace the
and
search
Th
e
because
it
to
R&D all
paid for.
No, no, no--that was not what I meant. My point is that at this point
tossing *more* money into the upgrade of the E models seems a bit
shortsighted, when that same money (along with the savings accrued from
cheaper operating costs) could go towards purchasing new-build airframes. We
did not have that option (or the money to make it happen) available back
when the original R program started--we do now.
That sounds
1990's
replacement
Nope. The USAF has said what they want to replace them with--you have no
trust in the USAF?
USAF
than
you
new
what...2015
of
pods
term to
solution
the USAF
Upgrading to R's does not do a great deal towards "increasing our tanker
force"--it instead is more of a "spend some money now to reduce O&M costs in
the long run, and keep the force from being *reduced* as E models break". Of
course, the 767 option does ptretty much the same thing--albeit with an even
greater reduction in operating costs, and a significantly better possibility
of future upgrades (at what point does it become impractical to keep trying
to modernize a 43 year old airframe?).
comes
to
based
upon
R
and
I'd
maintenace is
we
try
From
averaging
$4.6
(not
would
frequent)
cost
plan,
and
modify
requirements
completely
compatible
(I
Nissan
was
tankers,
for the
Crag)
most
withhold
judgement.
I don't buy that. My personal experience was in the more mundane area of
military trucks (we used various models in the combat engineer units). As a
company commander (late eighties/early nineties) I had dump trucks in my
unit that were manufactured in the late sixties and had pretty low mileage.
Somewhat like the KC-135 fleet, but a bit younger. Guess what? We still had
problems resulting from *age* (sometimes less use is not a *good* thing for
mechanical equipment, especially anything that has hydraulics), and we soon
(not long after I gave up command) faced a "train wreck" in terms of
supportability (the Army found it uneconomical to continue carrying the
spare parts inventory for the oldest trucks)--with no replacements
immediately available. Not unlike the situation facing the KC-135, IMO. If
the military services managed equipment like civilian entities do ( run it
to the point of best return in terms of depreciation, then unload it and buy
new equipment), the KC-135 would have been gone long ago, before corrosion
(among other factors) ever became a serious concern. That would be one
extreme, IMO--the other being what we are doing, in acting as if the KC-135
(or the B-52, for that matter) will be able to fly forever. We stretched the
KC's by doing the R conversion a few years back, when there was no option to
buy new airframes. Now there is an alternative to our continuing to slap
hundred-mile-an-hour tape on old equipment in hopes of keeping it viable
forever, and "carpe diem" would be an advisable course of action IMO. Again,
at what point do you stop tossing money into trying to keep the E models
viable, and instead commit that money to recapitalizing the fleet?
refueling
a
difficult
efficiently
these
is no
supposedly
airframe?
Again, age and , I suspect, a pretty extensive (and comparitively costly)
IRAN process during the upgrade. Can we conquer the corrosion process in the
E model? No doubt we can--but would it be worth the cost of doing so for a
43 (or more) year old airframe?
snip old ground
that the
discount,
dealing
much
but
I'm still looking.
Hopefully this corrosion revelation came after the LTG quoted above gave his
testimony--a quick google on the subject did not give me any hits on sites
that indicate the corrosion problems are licked.
great
should
yes,
Manageable at what cost?! Ask the DSB members how many of them are driving
even twenty year old cars that they find economical to periodically strip,
inspect, repaint, and replace corroded parts as necessary--I'll bet it won't
be many, if any. That they are proposing outsourcing the tanker role seems
to me to be unrealistic for the USAF, and is indicative of a study probably
done by "experts"--not the flying kind, or the kind that even manage the
fliers, but the other kind (what we used to sarcastically define as, "an
expert is an SOB from out of town with a briefcase". Again, at what point do
you think it is unwise to keep dumping money down the tube in an effort to
keep the 135E viable, versus using that same money to help purchase new
airframes with lower operating costs and greater potential for future
upgrade?
report said.
Guy, that is a telling statement. I suspect the USAF folks are as afraid of
that statement as I would have been when I was on the green suit
side--because they know that when the money does get short, the first thing
that usually ends up getting cut (or really stre-e-e-e-tched) is usually the
O&M money. Those "increased maintenance costs" (for an aircraft that is
already the most expensive in its class, the E model?) represent an
increased chunk of a finite pool of O&M money. Not to sound like a broken
record, but at what point is enough enough, where you start using that money
to instead buy into newer, less costly (to operate and maintain) airframes?
Hooray! "There is no compelling material or financial reason (of course,
you'll have to foget about that whole "increased maintenance costs" part of
what we just said), so like the bureaucrats we be, let's study it...and
study it...and analyze what we studied, and then study it some more...while
you guys keep paying out those "increased maintenance costs" you should be
oh-so-happy to "tolerate", not to mentioon having bitten the bullet and sunk
the requisite funds into belatedly upgrading the E models to R as (if?) you
secure the funding to do so..."?
we get
news media]
me
about
essentially
out of
opposite
are
going
already
problem,
so
they'll
USAF
is
are
see
old
2040
drive
But you find the improved fuel consumption of the 767 versus the R models,
and especially the E models, to be a non-issue?
in-production
(US)
longer the
commercial
a/c, and
cost
at
theirs.
Which
Not likely.
now
others
Sorry, but I can't buy that the extra five one-hundredths mach is going to
be an issue either way.
issues
down the road?
into
there
But you have been claiming that corrosion is not a problem withthe 135 any
longer--now you want to use corrosion as a deciding point between the 767
and an aircraft that has yet to even fly, much less become available in a
tanker form?
7E7
extra
You were talking gas, right? OK, lets be more realistic and say that if we
canned the 767 proposal and started from scratch, we'd likely not see a new
tanker enter the inventory until 2011 or so. That would be six years to the
*start* of replacing the E models. Of course, that pretty much forces you
into converting those to R's--GAO estimates the cost for that to be some
$3.6 billion. If we work *really fast* to do that, we can maybe get it done
over about a four year period, so for the last two years of that period up
to 2011 we can use the cheaper O&M cost of the R model ($3.7 million per
year per aircraft) which is (we'll assume, based upon KC-10 operating costs,
which would likely be a bit more than the 767) maybe $1.5 mil per year
greater than the 767 cost. Two years times 131 aircraft times $1.5 mil is
about $400 mil. Of course, we have that earlier period (four years)when the
E's (or the ever decreasing number remaining of them as they undergo upgrade
to R) are still flying as is, and that would add maybe another $600 mil. Say
a billion bucks total versus the operating cost of the 767's (yeah, I know
we would not get all of the 767's delivered in lump sum, but I am trying to
keep this simple and fair as well, so I am not going to figure the post-2011
additional operating cost of the 135R's versus 767 into the mix to try and
keep things even). That is a total of $4.6 billion you have just dumped into
keeping the 135E's flying just until 2011. At $200 mil per 767, that is the
equivalent of some 23 new 767's right there--over half of what the USAF is
asking for in the first lot. If you go the lease route with the first forty
tankers, you could cover a significant part of the overall lease cost with
that money. And you are getting an aircraft that carries more fuel to boot.
some
I am not crazy about the idea of having a portion of the tanker force
unavailable for use in the T/O (and no, this is not the same as my below
posit regarding using the 767's for these roles--those 767's could just as
well extend to the T/O where they provide full capacity tanking to USAF
assets, even with their (initially) marginal USN tanking support
capability).
case,
you
aircraft
su[pport
conflict to
for,
we
were
terms
with
than
ever.
135s or
deployment
options.
is
more
operational
capability.
to
improvement
Es
and
need to
tankers
and the
properly
studied.
place,
December
or so.
I was referring to your DSB folks..."studies" was the term they used. As in
"more than one".
adding it
later
virtue of
because we
effort
is
materiel
costs,
just
buy
prices
later.
can get
And pay some $3.6 billion for the privaledge of then having the longest
serving remaining KC-135's committed to an even longer period of service.
IMO, not a wise course of action--only to be used if the 767 deal gets
trashed due to both Boeing's stupid handling of what should have been a done
deal by now and the involvement of politicos-with-axes-to-grind, like
McCain. IMO, if that is the way it plays out, we will see the conversion to
R's, then a mindset of, "What? You want a *new* tanker, after we just sank
all of that money into upgrading those last E models? Maybe next year we
might authorize a *study*..." set in, leaving the USAF in the lurch with an
open-ended KC-135 tanker force, and the BUFF's being replaced before they
are.
reports,
fly
tasked
advice
thefront)
DSB
consultant and
as
time to
them.
Then we will have to agree to disagree on this point.
anything we
can
do
arguments
against
no
more
somewhat
greater
concerned
with
footprint. If
capability
is
See
below.
further
that
data,
it
since last year.
You left out that whole "tolerate higher maintenance cost" part of the DSB's
corrosion solution--I don't think that is a "minor" part of the equation
here, though the DSB apparently does given the off-hand way they worded that
statement.
we've
If you "tolerate higher maintenance costs" you have that time.
other than
dollars.
DSB did not say they *thought* keeping the E models would be more expensive
than what we are already paying--they said we would have to tolerate higher
maintenance costs, period, while the "studies" (plural) take place.
snip
augment
replacement
for a
also
it's
a
certainly
inefficient
offload
capability.
to
such a
limited
Then the critical USN "requirement" that led off this thread...must be more
of a "desire" than it is a "requirement".
refueling
silent
over
capability.
tanker
mod for
critical
one, eh?
is
navy
moot.
They (C-40A--I goofed with the "B", which is one of the USAF models) are
replacing the C-9 in the USN; from what I gather, the plan is to replace 27
C-9's, and I doubt that 8 C-40's can do that. I read where one of the
military lobbying groups noted that the CNO wants to procure three per year
(unspecified total delivery). I am not sure the 737 would make a superior
tanker, either--my point was more in the line of, "If the USN is *really*
worried about tanking capability for its aircraft, why have they not moved
to increase their own in-house capability beyond buddy tanking and C-130's,
especially when they have recently begun procuring a new dedicated land
based logistics support aircraft?" In other words, this a BIG priority for
them--as long as somebody else is footing the bill, that is. Otherwise, the
priority seems to be somwhere down in the weeds...
of
haul it
in
ourselves.
CVs. At
here
can
comment.
up
struck
times
location,
yourself.
moving
of
a
from
If
mean
handle
need
organizational
terminal
yes,
ordnance
during
OEF
during
ODS,
earlier
moreso
even
further.
that
may be
with PGMs
acronym?)
to
for
long
range USAF assets.
The increasing
(witness
out
we'll
major
attacks.
snip
(Guam,
Diego
this
pretty
had
convert
snip
do
every
support
has to
be
IIRR,
percentage
only 40
tanker
study
needs
to be _done_.
more
can look
33
Rs and
snip
east,
we
have
is
the -stans
past.
to us
when
regimes that
muslim
world,
additional
snip
theater,
fine, but
Of
course,
no
big
deal,
help
tank our
multi-point
ride.
tracks
version,
contributor
how
long
service
some
and
drop,
which
come
out
one
quote
uy --
AIR
that
all
Argh! More study?
years--unless
has
don't
a hell
case
of the CF6s.
Guy
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Highest-Ranking Black Air Force General Credits Success to Hard Work Otis Willie Military Aviation 0 February 10th 04 11:06 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Air Force announces acquisition management reorganization Otis Willie Military Aviation 0 August 21st 03 09:16 PM
