Contest Class Development for Future Success - The Case fordeveloping the Handicapped Classes
Old July 19th 14, 09:00 PM posted to rec.aviation.soaring
Default Contest Class Development for Future Success - The Case fordeveloping the Handicapped Classes
On Friday, July 18, 2014 1:12:13 PM UTC-7, wrote:
On Friday, 18 July 2014 07:06:43 UTC-7, Steve Koerner wrote:
Speaking for myself as a 15m pilot, I really do not want the definition of 15m ruined with handicapping. And the idea posed here about having a handicap adjust to the weather is extra extra icky. 15m numbers have not been fantastic but it's still the strongest class and the numbers are good enough for sure. It doesn't need to be messed with please.
Yes, collocate with Standard is fine. That creates a good situation for Standard guys that they can know for sure that they will have a contest to fly. If they get 10, they have a Standard Nationals; if not, they can fly in 15m. No handicap.
Steve - your suggestion requires that if classes are combined then Std cannot possibly be competitive except in the weakest average weather. Its a not in anyway aligned with pilot skill comparison (the point of handicaps)with gliders that are clearly not the same - even if they are 'close'. Please refer to my post on Hobbs 2013 experience.
I'm still not sure why handicapping necessarily needs to *ruin* anything. We went limited range handicapping in Standard and it didnt change the racing experience at all - it was just too little too late to quickly bring in folks that had already self selected out of competition.
Handicapping model hasnt changed in decades and we now have data analysis tools not dreamed of when Carl Herold first started putting handicaps together - handicapping has evolved into a dirty word in some classes but no-one has actually thought about improving the handicapping to the point where it is no longer the Satan, the AntiChrist and the root of all Uncertainty in final pilot comparison. Thats why I'll be working on the therma-capping idea and running trials on past results to check it makes sense or not.
Yet another option for the Std situation may be to allow 15m to fly Std with negative flap locked out and a 9lb wingload limit for all. I cant see it happening myself until 15m also falls apart and no one wants to think about that it seems.
2T
Well if I had any dreams about being competitive in 18m class, I'm sure I would need to actually go buy a glider with 18m span since 18m is a solid class and nobody in 18m class will have one bit of a care that my little 15m glider isn't quite competitive. They'll still let me fly, of course, but certainly not with any handicap factor.
It's that same relationship between 15m and standard. I don't much care that your glider is not quite competitive (if you say it's not). 15m is still a solid class so we don't need you bad enough to mess with the good thing we have going, I'm sorry to say. Handicapping is absolutely not what I want in my class.
I hope standard class can survive for awhile. I also hope that 15m class can stay strong. It's predictable, though, that both will fade eventually. When our classes fade, there's a great place for our gliders in sports/modern/club. That's where handicapping must stay.
Old May 19th 19, 08:56 AM posted to rec.aviation.soaring
I'm intrigued by the idea of eliminating the Sports Nats, which don't have a purpose other than getting the winner a bad photo published in Soaring...I suppose you could say the same for the 1-26 Nats but they're too hard core to quit!
Old May 19th 19, 10:25 AM posted to rec.aviation.soaring
Charlie Quebec
I do quite like the handicapping they use in the F1.0 GP here in Aus.
The handicap is applied as a larger circle around the turnpoint/points in accordance with handicap.
This means speeds are directly comparable ‘off the stick”
Here from memory, we run
Multi class 15m 18m and open
Standard and Club class nationals.
Junior Nationals
20M Nationals.
Old May 19th 19, 03:19 PM posted to rec.aviation.soaring
Tim Taylor
It is time to end the Sports class and 13.5m in the US. We need to focus energy on improving the pilots we have in Club, Std, 15M, 18M and Open. We will have to see if 20M is a viable class as well. The turnout so far indicates there is not a large enough base to make it worth supporting.
The sports class serves no purpose other than a place for pilots to complete when they don't want to drive to their own nationals.
We would be better off with several handicapped contests, similar to Australia, held around the country so no one has to drive more than a day to complete in their own class.
The US process is unfriendly to those that work and have younger families. If we wish to improve the overall number of pilots that race and the quality of our pilots we need to stop pretending it is still 1960 and revise the entire process.
Old May 19th 19, 07:52 PM posted to rec.aviation.soaring
Well Tim, you are wrong below.
The sports class also gives me in my DG400 a place to compete, as well as a number of other ships that don't fall into another class to compete.
Kevin
92
Old May 20th 19, 12:45 AM posted to rec.aviation.soaring
Tim Taylor
Actually Kevin,
The DG400 can fly in 15M, 18M and/or Club class. I don't see you signed up for the Sports Class Nationals.
Tim
Old May 20th 19, 10:39 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Sunday, May 19, 2019 at 6:45:44 PM UTC-5, Tim Taylor wrote:
Actually Kevin,
Tim
Not Club Class, Tim. Those with motors have now been removed from the approved list, even if they were within the range. Also, those in range but with greater than 15 meter span were removed from the US Club Class List.
Steve Leonard
Old May 21st 19, 12:37 AM posted to rec.aviation.soaring
No, Only home for DG400 and several other birds now is in Sports. The 400 at least in the east does not climb well in 15 meter, and unless it was a 15 meter handicap class, there would be no reason to enter a 15 meter race. You could "fly" in 15 meter, but certainly not compete.
As for Club Class, it is only 15 meter now and pure gliders.
Still working for a living, so having to settle for the Seniors, Perry, and upcoming Cordele, but I look forward to flying in the Sports Class Natiionals again. Have flown in two, but my work makes it difficult, if not impossible to fly something on the other side of the country, and unfortunately, many nationals are set up so you have to take 3 weeks vacation to make it work with my work, where we cannot take individual days.
Kevin
Old May 19th 19, 04:59 PM posted to rec.aviation.soaring
Mike C
Junior Nationals
20M Nationals.
I think your F1.0 GP along with the excellent tracking system is a great format! You guys are on to something there.
Mike
Old May 20th 19, 01:07 AM posted to rec.aviation.soaring
Turnpoint cylinder based on handicap - sounds great!
Contest Class Development for Future Success - The Case fordeveloping the Handicapped Classes [email protected] Soaring 39 July 17th 14 03:35 PM
