On Sunday, July 20, 2014 11:53:12 PM UTC-4, Sean Fidler wrote:
That's crazy. Well, here is to those daring test pilots! That said, I just learned first hand that a modern glider is capable of losing significant wing water in flight. I visited the 2014 Canadian Nationals this summer was shocked to learn that a brand new ASG-29 returned to the airport with a bit of a surprise. The cockpit was half full of water upon landing. The pilot/owner could not be sure what had happened or how. Was it the fuselage tank or the wing, etc? We suggested that he put the wings up on horses and refill it (before attempting to fly again). He did and sure enough one of the wings leaked, alot! The inboard tank seal (a 3x4 panel on the very inboard part of the wing thru which the ballast dump valve control rod runs) somehow failed during the flight. So, the wing water tank had definitely been draining into the cockpit at some rate during flight. Additional water was likely draining out the gap between the wing and the fuselage as well (depends on the tapes ability to withstand the water I suppose). How much total water that was out of that wing we will never know. It certainly was possible that the leak was large enough for the glider to have lost all of the water in that one wing. Scary, scary stuff. I sure hope that scenario never happens to me (or anyone else). That said, I feel better knowing the manufactures are testing that scenario for us. Are all manufactures testing for spin recovery with a full and empty wing? I never would have imagined that that condition could be recoverable. I am impressed that the JS1 (or anything else) could pass that test albeit with a test pilot who knows that one wing is indeed empty (and which wing that is)...... Does anyone know what failures are possible (or that have happened or are known) with other manufactures wing water systems? This is a very interesting side topic actually. No this does not mean that Punchaz comments are back on the table again ;-)! Thanks in advance. Common stuff includes not putting in the little drain plugs in the root rib area of some gliders with integrated tanks. Valves and bladders can fail and leak. One very useful thing to do is leave about 1 inch of the trailing edge not taped. This lets small amounts of water drain without going into the fuselage and can provide a warning that attention needs to be paid to a problem. UH |
Houston crash today | [email protected] | Soaring | 50 | July 17th 14 08:49 PM |
Houston'ers- EYQ or IWS? | Shawn | Piloting | 11 | June 15th 04 05:52 AM |
Houston Area Air Crash | Ludlow Johnson | Piloting | 2 | November 20th 03 03:10 PM |
Wildcat crash in Houston | Wright1902Glider | Home Built | 3 | October 27th 03 09:24 PM |
Wildcat crash in Houston | Wright1902Glider | Restoration | 0 | October 21st 03 03:38 AM |
